Belt Noise
Old Jan 25, 2010 | 06:17 PM
showstoppa01's Avatar
Belt Noise
Hey guys .At times I notice a sound by the drive belts...like a sheeeeeeeeee sound or something like an old school printer printing paper...Do they need to be replaced or is it some other issue?? I dont notice it all the time though
Old Jan 26, 2010 | 05:22 AM
mandyfig's Avatar
Belt tension. Adjust it. Maybe loose.
Old Jan 26, 2010 | 09:19 AM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
i have the same problem, i searched.....and if you already changed your belts they are loose. if you haven't check them and change if needed.
Old Jan 26, 2010 | 10:06 AM
Phantom-V's Avatar
same here, same problem after i had replaced mine. They are loose bro. just find that sweet spot and tighten it there.
Old Jan 26, 2010 | 11:58 AM
mandyfig's Avatar
While running, adjust your belt tensioner. Until you do not hear the noise. Do it slow. Nice and easy.
Old Jan 27, 2010 | 12:46 PM
mandyfig's Avatar
Note that you have to loosen the 14 mm bolt on the idler then you can turn the bolt to adjust. Once done, tighten the idler bolt.
I screwed up on this. Now I understand how they strip the strut hat bolt.
Old Feb 2, 2010 | 04:12 PM
mikroehl's Avatar
can't create a new post
since i can't create a new post hopefully this will work. I was changing my belt with my neighbor when he twisted the belt tensioner until it snapped and broke the tensioner. My question is,
will a 04 tension fit on on 03? I found one for sale but it is from a 04 maxima.. i know the model changed.. any help is greatly appreicated
Old Feb 10, 2010 | 10:52 AM
adrenaline_rush_fanatic's Avatar
Sorry to steal post, but I replaced belts (no thanks to Haynes manual) which was a pain in my a$$.
They were squealing before b/c stretched... Now, it sounds like I have a supercharger...
The main drive belt is louder... Sound coming from front of motor.
120k on car... Do I need a belt tensioner or are my belts too tight?
They DEFINITELY aren't loose.
Thanks so much!
Old Feb 10, 2010 | 11:37 AM
Nelsito65's Avatar
Thanks so much!
You can try adjusting the tension while the car is running and see if noise goes away.
Old Feb 10, 2010 | 02:44 PM
mandyfig's Avatar
Plus 2^. What happened, all resolved?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
