Anyone ever replace the gasket around the oil pan?
Old Jan 29, 2010 | 10:34 AM
KJVA67's Avatar
STUCK IN ATL
From: JACKSONVILLE, FL. STUCK IN ATL FOR THE TIME BEING
I've got leaking oil all around that area. Stealership wants 3-4 hundred to unbolt it and replace the gasket. Is it something a local shop can handle? Is it a simple do-it-yourself job?
Old Jan 29, 2010 | 10:58 AM
Rochester's Avatar
They must be replacing the whole pan, not just the gasket. Pan, gasket, oil, filter and labor... it's possible that could add up to north of $300. It doesn't make it right or reasonable, but does explain the math. Instead, buy a pan online and have it shipped to your door. Then have a local mechanic do the install. I think you'll spend about half.
I'm pretty sure this is the right link from Courtesy Nissan, but call to confirm. Courtesy is asking under $80, and my dealership quoted me $150... so, yeah, big mark-up.
http://www.courtesyparts.com/11110a-...3-p-52507.html
As to the DIY... only you can answer that question.
I'm in on this because I believe my oil pan needs replacement in the Spring, too. (Dented, rusty hunk of crap right now.) So it's been on my brain.
Old Jan 29, 2010 | 07:14 PM
knight_yyz's Avatar
Toolie
is there a gasket? i thought it was rtv sealant.
Are they replacing the aluminum pan (upper) or the steel pan (lower). The upper is a PITA as you have to remove exhaust, and a few sensors. Lower is just a bunch of bolts and RTV sealant according to the fsm
Old Jan 29, 2010 | 07:52 PM
Stereodude's Avatar
I can speak from firsthand experience. There is no gasket there. It's all RTV.
I had to replace the lower oil pan on my Maxima last year when it rusted through and started to leak. The job is pretty easy to DIY.
Old Jan 29, 2010 | 08:04 PM
vastmax's Avatar
Mine DID have a gasket there, i replaced it and added rtv to make double sure. Bring it to my house and i'll charge you 1/2 that price, this is a cake job....
unfortunately, this didnt fix my leak, i had to replace the oil cooler o-ring, now my garage is clean again...
Old Jan 29, 2010 | 08:35 PM
diverdown3's Avatar
The lower (steel) pan is a cinch. Be careful not to strip the pan bolt holes if not using a torque wrench and factory service manual specs as your threading into the aluminum pan. No gasket, just hi-temp, oil resistant RTV.
Your leak may not actually be from the pan though. I thought mine was, but later determined it was originating from the oil cooler base on my 5.5 gen (5th gens have no oil cooler). If you have a 5.5 gen, you should probably check my oil cooler leak thread with pics, including what to look for to determine if your leak is at the cooler.
Good luck.
PH98I30
Jan 9, 2025 08:08 AM
Matt93SE
Apr 8, 2018 09:23 AM
iflexsteel
Sep 15, 2015 03:37 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
maxima297
Aug 3, 2015 12:50 PM
