Cattman 3" Catback Exhaust - Order Here!
Old Jun 28, 2012 | 04:06 AM
  #2081
CMax03's Avatar
Yeah Im bouts to do the same on Coils, Plugs, and Fuel Filter, since I dynoed my car and it was obviously off on power up top....
Yeah fuel strainer is the next thing as well for me.....
Old Jul 10, 2012 | 04:19 PM
  #2082
TSelanne's Avatar
Hey guys, I have an install question. '01 AE/SE manual 87xxx. I bought the full cattman setup. I met w a shop owner today. He said welding the ports for the o2 sensors is no problem, but he recommending a new wiring setup as opposed to cutting&soldering the wires. He said it will eliminate the risk of throwing codes due to the solder joint (because even when solder joint done properly it messes w the resistance and thereby the signal to the ecu). Any you experts have thoughts on this? If his advice rings true w you guys, where would one find such an item?
Old Jul 10, 2012 | 04:34 PM
  #2083
Grand_hustle17's Avatar
it wont... plenty of folks cut and solder and it works fine... you will be good with cutting and soldering
like an orger said on another thread... o2 sensors is kinda "it either work or it dont" kinda thing... cut n solder
Old Jul 10, 2012 | 05:23 PM
  #2084
Rods03Max619's Avatar
Agreed....did the same with mine and they are fine unless he doesnt know how to solder....
Old Jul 10, 2012 | 07:49 PM
  #2085
TSelanne's Avatar
Thx.
What's a reasonable time frame to complete the job? It's all stock right now.
Is there advice anyone might offer on tuning afterwards? Any good threads so I can read up would be appreciated.
Old Jul 10, 2012 | 07:54 PM
  #2086
Originally Posted by TSelanne
Thx.
if you are installing all at once it will be about 5-8hrs lol... man if you were local id be ur best friend lol... did you get a quote on how much the install is going to run you???
um tuning is up to you dont know how much of a DIY'er are you... id say go do your research n search up the different options... lets not ***** this thread up... but you can go as simple as an AFC or as complex as Haltec
Old Jul 10, 2012 | 07:55 PM
  #2087
Chris Gregg's Avatar
Get Off My Lawn
Hate to disagree with two knowledgeable people, but I must. Not to say cut and solder won't work, it's just that the mech is right, it doesn't always. It's a risk. A risk that cannot be fixed without buying new, expensive sensors.
I'm not as familiar with the 5th gen as the 5.5, but can the sensors not be extended like in the 5.5?
I'm also not sure what the mech is referring to as a new wiring setup (as you stated it).
Old Jul 10, 2012 | 08:03 PM
  #2088
i believe he is talking about extending his o2 sensors lol... making them longer... this is something always done and work... why all the sudden wont it work??? same process with any o2 sensor of any make n model car lol... unless somehow he is all the sudden talking about something else
Old Jul 10, 2012 | 08:42 PM
  #2089
Get Off My Lawn
Absolutely, cut/solder works. Im only saying there is indeed a chance cutting/soldering won't work, as the mech stated. I've seen it fail at least in four instances. Not sure why in those cases, could had been quality of work, but in those instances a new sensor had to be bought. I'll add this, if the mech suggests not do it, I wouldn't be too comfortable letting him do it unless you know him and the quality of his work very well. I've found sometimes these recommendations are more about a mechs comfort/skill level than anything else.
But my question remains unanswered, is there not another option on the 5th gen to cutting/solder? Do they HAVE to be cut/soldered? Again, I ask because I extended my two primaries simply by cutting the harness and pulling the wire out, then re-taping. Others have successfully done this as well without cutting wire or damaging anything. Personally, that seems easier and safer than cutting wire and soldering.......if that's an option.
Still don't understand what the mech meant by new wiring setup.....unless he means what I am suggesting as pulling the stock wires from the harness and re-routing. If so, I am adamant that is the better way to go.
Hopefully I was more clear this time.
Old Jul 10, 2012 | 08:46 PM
  #2090
either or... whichever the mechanics prefer i guess... you could go the universal o2 extender route... havent seen anybody do that, its $30'ish for the extender... you could also ask someon to just extend it for you and all the mech has to do is connect lol... that can be another route
Old Jul 11, 2012 | 02:25 PM
  #2091
TSelanne's Avatar
Thanks for the reply. Yeah I wish you guys were local; as a newb I'm stuck playing the 'I hope this mechanic knows what he's doing because I don't' game..... "You're gonna need a Johnson rod in there".
His computer quoted 10 hrs for everything. He's $85/hr. Says he'll charge actual though, computer is just a guide.
I know nothing about DIY'ing, I'm at the mercy of a mechanic. Sorry didn't mean to clutter but wasn't sure where to post - figured in here in case something of value could be helpful to others - I'll start another thread if have more questions.
Kinda makes me nervous... don't want to spend more $$ if I don't have to.
He meant he would find another harness that is factory built that is long enough to reach without modification. So there wouldn't be any solder joints anywhere along the wiring path - no cutting. I wasn't clear as to whether or not this would be a nissan part or if other 'brands' would work. In his words, if I want a no-risk solution, that would be it.
Not sure where that leaves things though.....?
Old Jul 11, 2012 | 05:58 PM
  #2092
Get Off My Lawn
I'm on mobile forums. Where are you located? There may be someone near you that can offer some help.
$85 an hour....sounds typical but geez, soboring reminder of why I do 90% my own work.
Old Jul 11, 2012 | 06:45 PM
  #2093
Yeah that is insane 850 bucks to put on, you should just ask for the Headers and Y pipe install and you do the exhaust yourself to save some money....
Old Jul 11, 2012 | 07:06 PM
  #2094
BobPezz's Avatar
You could probably get 2 of these O2 sensors w/ 39" wires.
http://www.boschautoparts.com/Vehicl...part_num=13374
With 2 of these 30" extensions.
http://www.casperselectronics.com/store2/product_info.php?products_id=1527
Almost 70" of wire should be long enough to reach.
Old Jul 11, 2012 | 08:52 PM
  #2095
TSelanne's Avatar
Chris- I would love some help.... would gladly pay someone to teach me how to do this stuff.... I mean I'd have to pay someone anyway. I would love to learn how, but lack tools & experience. I asked the guy if I could work along side of him to learn, but he didn't like that idea. Can't really blame him, if I cut off a finger or something he'd be liable if I were the suing type.
Bob- Thx for the parts link, I might just go that route. Anyone know if 70' will reach for sure? Id hate to buy the thing and be an inch short.
Old Jul 11, 2012 | 08:59 PM
  #2096
Just did mines me n a fellow other... Total cost was about $100 n thats with using a lift... Def a hard thing to do no doubt but $850 at the total end price I could've had a SC on my AE n tuned lol
Old Jul 11, 2012 | 09:02 PM
  #2097
lol u sure that works... The sensor that needs to be extended is the rear primary... This is the reason I didn't get this because it shows only for the secondary o2's... Primary connector is different
Old Jul 11, 2012 | 09:43 PM
  #2098
Chris- I would love some help.... would gladly pay someone to teach me how to do this stuff.... I mean I'd have to pay someone anyway. I live in Milwaukee. I would love to learn how, but lack tools & experience. I asked the guy if I could work along side of him to learn, but he didn't like that idea. Can't really blame him, if I cut off a finger or something he'd be liable if I were the suing type.
Here man check out this thread and PM some people might be near you to give you a Hand, 200-300 bucks can buy you a Mechanics Set from Craftsman, a Jack, Jackstands, thats all I needed for install had the 94pc set and got her done, your only dropping and replacing.....And have you ever took off the intake manifold...
http://forums.maxima.org/upper-midwe...milwaukee.html <<<<Click Me
Old Jul 12, 2012 | 05:14 PM
  #2099
BobPezz's Avatar
I think the OP is re-locating the secondary sensors to after the main cat. If not this primary O2 sensor should work. It's got a wire almost 26" long.
http://www.boschautoparts.com/Vehicl...part_num=13350
Old Jul 12, 2012 | 09:37 PM
  #2100
TSelanne's Avatar
Yes
Old Jul 14, 2012 | 05:50 AM
  #2101
02whitemaximase's Avatar
Chris is absolutely correct. He helped me over the phone with my header install. NO WIRE CUTTING NECESSARY!! Check out my install thread with pictures of the entire process. Still no cel after thousands of miles.
https://maxima.org/showthread.php?t=...t=Obx+comments
Old Aug 3, 2012 | 06:33 PM
  #2102
CMax03's Avatar
HTTP 404 Not Found!!!!!!!!
Old Aug 3, 2012 | 06:44 PM
  #2103
CMax03's Avatar
I installed a Dual O2 sim on the secondary O2 sensor bagged them and relocated them under my battery tray.....been there for at least 4-5 years no CEL(s) ever regarding that.....I've had 2 CEL(s) since owning this car since new.... first was a def cam sensor and recent after I used too much RTV on my NWP intake spacers cleared and removed my intake spacers and installed them with double gaskets and it resulted in a clean trouble free install....Back to the O2 sim install it will be easier to extend the chassis harness...Chose to extaend the actual O2 sensor wiring so that all he connector looked undisturbed and factory! The method I used to splice them was metal crimps, them soldered them after crimping and sled heat shrink over the soldered/crimped wires, then placed them in High temp wire protective sleeves.....
Old Aug 4, 2012 | 11:11 AM
  #2104
CMax03's Avatar
New experiment....Resonator for 3" on the right (Magnaflow 12649)
Old Aug 15, 2012 | 10:31 PM
  #2105
CMax03's Avatar
Got 6" round Magnaflow muffler, SCE 3" ID Copper gaskets, now waiting on....... T304 exhaust tubing and CRS 3" flanges....!
Old Aug 16, 2012 | 11:57 AM
  #2106
Get Off My Lawn
ETA?
Old Aug 16, 2012 | 12:19 PM
  #2107
CMax03's Avatar
How about ETC? Going at a wait on this or that schedule....hopefully I can get it tig welded this weekend not sure got 2 birthdays too celebrate!
Old Aug 17, 2012 | 05:52 AM
  #2108
2003sandstoneSE's Avatar
It is still for sale. I want to buy one for my 03.
Old Aug 17, 2012 | 06:18 AM
  #2109
Get Off My Lawn
Call Brian at Cattman. His contact information is in his posts.
Old Aug 17, 2012 | 12:32 PM
  #2110
CMax03's Avatar
would like a 3" or 2.5"? Cattman is only building 3" catbacks now.....18007699920.....I've got a 2.5" Cattman possibly for sale if the 6" round resonator is a successful cure.....for lower in town cruising volume!
Old Aug 18, 2012 | 09:48 AM
  #2111
CMax03's Avatar
Who ever complained about Cattman's catback pricing should feel good seeing this:
http://www.perrinperformance.com/spe...xhaust-systems
Old Aug 18, 2012 | 09:53 AM
  #2112
Get Off My Lawn
+1
And there is a much larger market for those.
Old Aug 20, 2012 | 11:04 PM
  #2113
CMax03's Avatar
Well got everything for the New Cattman 3" resonator, time to get the chop saw out and start fitting this new resonator so I can get this assembly Tig welded:
1. 6" Round Muffler x 18" length, 3" in/out
2. (2) Corrosion Resistant Steel 3/8" thick, 3"- 2 bolt flange
3. 12" length, 3" OD T304 SS tubing
4. (2) 3" ID-2 bolt, SCE Copper gaskets
Old Aug 22, 2012 | 06:29 PM
  #2114
Whats the part number for the Gasket, and the fee need a couple....
Old Aug 23, 2012 | 01:31 PM
  #2115
TSelanne's Avatar
instead of the 4" round x 20" long Cattman...I'm trying a 6" round x 18" Magnaflow....volume wise it's Cattman's 251.36 Cu in vs Magnaflow's 508.68 cu in which is twice the sound reducing volume than the Cattman resonator!!!!!!!
I quoted you from another thread.... question for ya: when installing your new resonator, how do you make up for the lost 2" of pipe?
Old Aug 23, 2012 | 07:09 PM
  #2116
CMax03's Avatar
Just in case you're unaware the Resonator section is flanged and so will my new resonator section...The Overall length flange to flange is 30.625"....That's why I have the muffler/resonator, 2 flanges, 2 copper gaskets, 12" of 3" O.D. T304 SS tubing.....I don't chop up my ****.....I do it right so it's a bolt-on feature....
Old Aug 23, 2012 | 07:20 PM
  #2117
CMax03's Avatar
SCE-9447 @ summit....$12.01 (ea)
Old Aug 26, 2012 | 09:34 AM
  #2118
CMax03's Avatar
Well I'll shoot for this week or upcoming weekend with my resonator section.....buying school supplies and school clothes this weekend it appears! But I still be working behind the scenes getting it ready for welding!
Old Sep 9, 2012 | 09:21 AM
  #2119
CMax03's Avatar
Well I pushed it back to 9-15-12, 11:59 pm....Should have that New resonator section done by Saturday night at the latest! It should be quieter off the bat but it should quiet down even more once the carbon settles inside the SS wool! This should be a repeatable procedure and maybe I can make a jig to setup a few more for those of you interested....how much do you think it's worth? The parts alone retail prices including welding, are $180.12....This doesn't including shipping!
Parts
1. Magnaflow 12649 6" round x 18" long muffler- $99.64
2. 12", T-304 SS, 3" OD, 16 guage, straight tube-$10.50
3. 2 ea Mild CRS 2-bolt, 3" ID universal exhaust flanges- $19.98 ($9.99 ea)
4.Welding-$50
Total: $180.12
extra chrgs will be included using SCE Copper 3" ID 2-bolt exhaust gaskets (2) @ $12.01 ea
Old Sep 9, 2012 | 09:22 PM
  #2120
TSelanne's Avatar
I'm in.
