Gas Mileage is Gone to Hell...Who's to Blame?
Hey all,
As you may or may not know, I recently installed a set of OBX V2's on my Max. However, in the process my gas mileage has gone from 25.5 (that's combined highway and city) to about 19.8.
First things first, I cleaned the MAF earlier tonight. So we'll see how that helps, if any, in the morning. I realized that I'd recently re-oiled my filter, and figured maybe that was the culprit. Coupled with the fact that while inspecting my filter tonight, I found a small hole had been worn through it, so it looks like it's time for a new one.
Now for the questions. During the install, I extended the primary O2 sensors with some 14-gauge wire and heat-shrink crimps, and wrapped everything up snug in electrical tape. Also, the rear primary was damaged (the outer shell was bent slightly) during removal from the old manifold. Could either of these be responsible for a poor A/F ratio? Or is it possible that a loose O2 sensor could be causing my issue?
Both my O2 sensors looked pretty rough when I pulled them out, so I'm wondering if it'd just be in my best interest to replace them.
If it's worth noting, my car doesn't feel sluggish or unresponsive. It's running fine, no high or low idle, doesn't smell like it's running rich, or anything of the sort.
Also worth noting, I threw a P0123 code earlier tonight, something about TPS Circuit High Input? If anyone has some insight into that.
But I don't see that contributing to my bad gas mileage considering the SES light came on yesterday, and my mileage has been anything but good since the install a little under a week ago.
Oh, and for the record, I've not been heavy on the pedal. I was at first, but after seeing my MPG go to ****, I've been driving like a granny to see if it helps with the mileage at all. Any input would be greatly appreciated...
But I don't see that contributing to my bad gas mileage considering the SES light came on yesterday, and my mileage has been anything but good since the install a little under a week ago.Oh, and for the record, I've not been heavy on the pedal. I was at first, but after seeing my MPG go to ****, I've been driving like a granny to see if it helps with the mileage at all. Any input would be greatly appreciated...
So are you using the trip computer to judge your gas mileage? We all know that it isn't completely accurate. Best way to measure MPG is drive till you're at less than a 1/4 tank, fill up, reset your trip meter, drive again, refill and divide the amount of miles you drove by the gallons you put in. Now, another factor could be that your tires are not properly inflated. Have you checked that recently? I wouldn't imagine that it would make THAT big of a difference, but it could be attributing to your reduced MPG.
When's the last time you checked mileage before the change? You know blended gas is like 10-30% less efficient? Are you burning the same gas you were before? Have you went to heavier wheels since? Lower PSI? Diameter?
Sounds like a sensor problem though.
ef9
Oct 4, 2015 08:43 AM
I even had the battery disconnected a few days ago, so the MPG gauge was reset to zero when I started back up. I've been driving slowly since. Still no good...
