H&R drm 25 mm spacers question
i already have 15mm H&R but need more so im going with the 25mm ones. but the 15mm i have were not drm style and required longer studs. granted the longer stud change was a pain in the ars but i kind of feel safer with that.
anyone know or have experience with the drm style where it has bolts already pressed in the spacer then you bolt spacer to hub then rim to the spacer? i mean im going with H&R and def trust brand but just cant help but think they are gonna, like break off or something?
any experience would be appreciated. thanks
I'm running 15mm H&R bolt on spaces and have been for 7 months. Before then I ran spacers with the longer studs (20mm spacers) with good results then 15mm with longer studs and the studs got loose in the hub and couldn't loosen the wheels nuts on both side. After two new hubs and disks on both sides I got the bolt on style.
Unclejunebug
04-02-2016 06:42 AM
