What parts should be considered for replacement on a suspension over haul
Old Feb 4, 2010 | 05:37 AM
Colonel's Avatar
Old Fuddy Duddy
Since I was cluttering up another members thread, I created this one. The discussion I was trying to get at are what parts are ok to reuse, which one should be replaced regardless and which ones are a judgement call.
I swiped a .jpg from the original thread.
1) Nut
2) Nut
3) RH strut
4) LH strut
5) Paper gasket
6) Spring
7) Strut top hat(?)
8) Bolt plate(?)
9) Nut
10) Bearing
11) Lower spring isolator
12) No idea
13) Strut boot (?)
14) Bolt
15) Upper Spring isolator
I am a DIYer, just trying to figure what pieces are necessary and not necessary for replacement. I was trying to make it R/R so that my "fight" would be with all the salt rusted frozen bolts and not trying to carefully remove intricate parts from the suspension for reuse. But if throwing money at it (which seems to be the implication) isn’t the smart move I am smart enough to follow that logic train!
I have seen thread after thread of clunking this squeaking that and so forth on suspension replacements. I am trying to the best of my ability NOT to short cut the system and get it done right the first time so I can enjoy another 10 years of trouble free suspension.
OK…lets rephrase this:
What parts should be replaced regardless?
What parts, if money is available, should be considered for replacement?
What parts are just a throw away of money replacing?
One thing to consider in my feeble request is that I live in an area where salt is thrown down so regularly during the winter my silver car is usually salt white.
Old Feb 4, 2010 | 05:41 AM
Colonel's Avatar
Old Fuddy Duddy
Originally Posted by Originally Posted by Colonel
However I am unclear about one part. Spring isolators. I will be purchasing Moog tops, Illuminas and Eibach springs and EOM dust boots (per recommendation above).
Most aftermarket springs come with replacements. I typically reuse isolators for OEM setups. For those that are ****, or require them for purposes of building entire assemblies, the dealer is where to get them.
Originally Posted by Originally Posted by 2slow
A rubber tube comes with the Eibach springs which should be able to take the place of the spring isolator (#11). Although none of the listed parts come with a replacement for the upper isolator (#15).
I never replace #15 either.
Ok, I guess I thought I knew what I was doing, but in reality its apparent that I dont.
I am trying to create a R/R situation. I want to build the replacement assembly outside the car and just basically pull the old assembly off and install the new assembly without having to disassemble the old assembly.
7,8,10 are part of the Moog assembly. 15 is the upper isolator which needs purchased outside the "kits". But what is 12?
#8 is NOT part of the Moog assembly. Unless you break a stud, you don’t need to replace this. #12 also does not need replacing unless it is completely rusted through.
OK, given your advice and threads in the suspension forum, I dont want to disassemble the old stuff. Its salt encrusted, rusted parts, and I dont want to have to muck with it for another 10 years (like the OEM is currently floating along the highway).
Part #8 and #15 require dissassembly of the old parts to obtain or a purchase of a new part? And the recommendation for getting those in new parts is OEM?
As far as I know, these are only available from Nissan. Consequently, you will pay dearly. The old parts will be fine to reuse, and if necessary clean, prime and repaint them.
10 Chars
Old Feb 4, 2010 | 06:59 AM
djfrestyl's Avatar
Suspension Yoda
#7 (Mounts)
#10 (strut bearings)
#13 (dustboot/bumpstop)
#5 (paper gasket)
#11 (isolators)
For these two items, new ones are more of a "nice to have" than a necessity.
Everything else
Old Feb 4, 2010 | 07:00 AM
Colonel's Avatar
Old Fuddy Duddy
Mounts, bearings, boots.
#5 (paper gasket), #11 (isolators)
Everything else
Is there something special to the material of the gasket? Is it an OEM purchase only?
Old Feb 4, 2010 | 07:23 AM
djfrestyl's Avatar
Suspension Yoda
It's like a plasticky paper material. I don't think it's too expensive, maybe about $6 or $8. And, it really only could be replaced if the original was worn. I've seen PLENTY of cases where the gasket is viable. Wouldn't be surprised if yours was in great condition.
Old Feb 4, 2010 | 07:32 AM
foxy curls's Avatar
Great!! Thank you for the picture!
Old Feb 4, 2010 | 07:34 AM
Nelsito65's Avatar
I bought a roll of gasket material for about 5 bucks and made gaskets, using the old ones as templates, for all four struts/shocks. I re-used the old spring isolators, wrapping electric tape around all spring isolator tips to reinforce them and prevent them from sliding off.
Old Feb 4, 2010 | 08:01 AM
bigpopaj369's Avatar
this needs to be stickied asap
Old Feb 4, 2010 | 08:46 AM
2slow's Avatar
#7 (Mounts)
#5 (paper gasket)
#11 (isolators)
Everything else
Exactly, but don't forget the struts (#3 & 4), and if torn or otherwise is poor shape, consider replacing #15.
Necessary:
#7 (Mounts)
#3 & 4 (struts)
As needed/if money permits:
#5 (paper gasket)
#11 (isolators)
#15 (upper isolator/spring rubber)
Old Feb 4, 2010 | 10:11 AM
kukx30de's Avatar
Necessary:
#7 (Mounts)
#3 & 4 (struts)
#5 (paper gasket)
#11 (isolators)
I compared my upper isolator with a new one when i did my springs at 130K and then again at 170K. they do take a beating. Overtime the rubber compresses enough to start allowing for metal to metal type noise between the spring and top hat. They dont cost much when spending the money to redo suspension.
My rule of thumb is if you are doing any suspension work after about 40-50K miles replace all rubber parts in that area you open up. It sucks to go back to replace something you did not do the first time. 50K miles is enough for the rubber to be done with the best years of its life!
Old Feb 4, 2010 | 01:49 PM
HDB Audio's Avatar
Hi everyone, I was looking at this thread and make me think that I have to change my dustboot too! I just want to know if anyone know where I can buy some except from the dealer because I live in Montreal and they sell the dustboot for 36$ CAD each!!!!! If it can help you, the part number is 54050-2Y001
Old Feb 4, 2010 | 02:05 PM
arcueda's Avatar
this is perfect, exactally what i needed
Old Feb 4, 2010 | 04:51 PM
2k0to2k3's Avatar
wow my tokico blues are on the way in the mail and man am i glad i found this thread!!!!! just hit 100k and definately want to do it right and hopefully get another 100k out of it.
so where can i get these needed parts? i know at performancepeddler where i bought the struts they had eibach mounts for like 34 a side i think, but will that work with tokico? can i just go to local parts store or is there a better brand or place that some experienced orgers may know of?
thanks again for any help
Old Feb 4, 2010 | 05:37 PM
HDB Audio's Avatar
If you are talking about strut mount, I know that MOOG have good quality for that and yes it's gonna work with your tokico blues, like it's gonna work with everything else...
Old Feb 4, 2010 | 09:21 PM
ridinwitha35's Avatar
As for those paper gaskets, my front ones were in pretty good condition. The rear ones were pretty dirty though. They're practically just orange pieces of paper...you can see the side of one in this pic (along with the strut mount [#7] upside down).
and FWIW, #8....rusted yeah, but the important part is to make sure the studs are fine & secure:
Old Feb 5, 2010 | 04:53 AM
djfrestyl's Avatar
Suspension Yoda
For the rubber isolator, yes they compress. In fact I've even seen cases in which the end of the spring compresses the isolator so much that it nearly pierces rubber.
HOWEVER, I still never purchase new ones. I just spin them so that the end of the spring touches a fresh part of rubber. Never had a problem, and doubt I ever will.
2slow - the struts themselves are a given
Old Feb 5, 2010 | 05:50 AM
kukx30de's Avatar
Gr8 Idea.
I would surely do that if I had say just about 30-35K miles. With the miles on my max i.e. 135K the old isolators were pretty much the same thickness all around. First time, I still reused them when I switched to H&R's. However in about 15K miles, the springs had ripped through them.
You need to be extra careful since the H&R's have an abrupt end unlike the stock springs which are flat at the top. I am going to switch back to my stock SE springs since I have not been a fan of the H&R ride quality I know its just me. I will take some pics to add to this thread.
Old Feb 5, 2010 | 06:28 AM
DrVenkman's Avatar
I personally replaced everything but #5 & 15. Either way for the smaller parts, good or bad, your looking at a total of an extra $100. I just went new all the way through.
Old Feb 5, 2010 | 06:48 AM
Tippy Toes's Avatar
I just talked to Dave B at south point nissan.
#5.The paper gaskets run $18.
#10 The bearings run 19.02 for the front 2, which you only need.
#11-#15The upper/lower front isolators run 10.50 per upper and lower. The rears just have lower isolators from what I was told and run 6.75.
Old Feb 5, 2010 | 06:00 PM
djfrestyl's Avatar
Suspension Yoda
^^Prices went up.
Old Feb 6, 2010 | 03:21 AM
vastmax's Avatar
get MOOG strut mounts, they come with bearings
Old Feb 6, 2010 | 08:49 AM
djfrestyl's Avatar
Suspension Yoda
Old Feb 16, 2010 | 09:51 AM
arcueda's Avatar
ok so saturday i orderd tokico illuminas and stechs off ebay.455 for the struts and 208 for the springs.ouch. now im pricing out everything else and this is what i have come up with/have questions on:
priced out from daveB today-
Front strut mounts -39.14pc x2 Rear Strut mounts - 42.12pc x2
Front Isolators(upper and lower) - 10.64pc x(4?) Rear Isolators 6.76pc x4?
Front Bumpstop 13.66 pc x2 Rear bumpstop - 26.82 pc
gaskets run 8.24pc
moog mounts from rockauto.com are going for 172.76 for all for includding shipping to me
question is, what parts are neccessary to have oem, which should consider upgrading to moog or kyb.does energy or anyone have universal isolators or anything like that?
i bought my car like 2 years ago and it was dropped on eibachs and stock struts
now its clucky and squeeky.
respect everyones opinion on here so i figured id ask before i made any further moods so thanks again.
also big thanks to daveb, always very friendly and very helpful, id recommend him to anyone and everyone
-jason
Old Feb 16, 2010 | 09:55 AM
djfrestyl's Avatar
Suspension Yoda
You don't need to replace rear mounts.
You don't need front upper isolators. You may not even need isolators at all.
Moog mounts - get them from amazon. Cheapest, and free shipping. Fronts only. Bearings and hardware are included.
Get OEM dustboots/bumpstops.
Old Feb 16, 2010 | 10:57 AM
arcueda's Avatar
thanks for the fast response..just what im looking for
is there anyway i can take my wheel off and see if the isolator is any good?
i know u can get energy isolators but you have to have the dimensions i think
Old Feb 16, 2010 | 12:14 PM
djfrestyl's Avatar
Suspension Yoda
Yes, it's visible when you remove the wheel.
Old Feb 17, 2010 | 02:53 PM
arcueda's Avatar
just got my stechs today......is the brown rubber the isolator i need, or is more like plate shaped rubber like in the diagram
illuminas, moog mounts, and oem bumpstops on the way
Old Feb 17, 2010 | 04:23 PM
IHAVEA2KMAXIMA's Avatar
Is the paper gasket necessary to replace if torn? What would happen w/o it?
Old Feb 18, 2010 | 06:22 AM
djfrestyl's Avatar
Suspension Yoda
Yep, the brown part is the spring isolator. MOST aftermarket springs include them.
Not necessary to replace if torn. I sometimes reuse it even if torn. But not if it's in multiple pieces.
The gasket is there to prevent metal on metal noise in case there is movement (there really shouldn't/isn't any movement). I've installed suspensions without it and haven't had a single adverse symptom.
Old Feb 19, 2010 | 01:16 PM
ghostrider17's Avatar
So - #'s 12 & 15 (rubber isolators).
Safe bet to buy these OEM -- or is that the ONLY opt. for these pieces??
I'm thinking I should REALLY replace these next time around also.
thks,
gr
Old Feb 19, 2010 | 01:43 PM
djfrestyl's Avatar
Suspension Yoda
You don't need to replace #12 unless it's rusted through (doesn't happen often), and you never need to replace #15.
Old Feb 19, 2010 | 03:06 PM
I thought #12 was rubber too!
I swear #15 was ripped/torn last time I swapped springs. Are you SURE you never need to replace it?
Wouldn't a worn rubber boot at the top of the spring allow the spring to make metal on metal contact?!
.....i'm just sayin'....
Old Feb 20, 2010 | 04:45 AM
perfectmax's Avatar
arcueda; what did you finally end up ordering, from where and what did it end up costing?
I am going to be doing this same project in a few weeks. Right now I hear clunking everytime i hit a bump. Those noises have to go!!
Old Feb 20, 2010 | 06:03 AM
glockfanbob's Avatar
Good thread, I've learned a lot so far. Tagged
Old Feb 20, 2010 | 06:46 AM
2slow's Avatar
#12 is metal; it connects the spring's top to the strut mount.
Old Feb 20, 2010 | 07:19 AM
Roger-roger.
I remember now -- it has the OUT stamped on it.
Done this at least three times now...you'd THINK i'd have remembered that!!??
Gawd - I can't wait to tighten-up my clunking suspension!! And here comes another 6-10" of the white stuff tonight!!
gr
Old Feb 20, 2010 | 07:59 AM
arcueda's Avatar
yea mine makes alot of noise and can really feel the wind at higher speeds, im sure this is the begginning of my suspension overhaul
lets see:
Stechs were $208 ebays was the cheapst i could find, hooked up with a great seller..shipped in like 3 days
tokico illuminas were $455 also off ebay, cheapest i could find
moog strut mount around $83 rockautodotcom
still have to order my bumpstops from daveb. im not in a huuge rush to do mine,roads still su*k in my area.
Old Feb 20, 2010 | 08:00 AM
arcueda's Avatar
i agree, id like to thank everyone once again, id be lost without this forum
Old Feb 20, 2010 | 12:42 PM
djfrestyl's Avatar
Suspension Yoda
Please tell me the strut mounts were $83 for BOTH. And, where's the strut bearing that it's supposed to come with?
Old Feb 20, 2010 | 01:30 PM
arcueda's Avatar
ya front 2, bearings in a plastic bag not pictured, sry should have included
vingodine
45
May 21, 2016 12:46 PM
Rage Maximus
Sep 3, 2015 12:26 PM
KristyKarina
Aug 23, 2015 09:53 AM
Balkins
Aug 12, 2015 06:39 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
