anyone ever install these lights?
Old Feb 9, 2010 | 06:28 PM
5 ltr. beater's Avatar
im getting ready to pull the trigger on a 5spd 00 SE with GLE package and im pricing out parts and mods i want to do. (as usual. how else better to spend tax return money?)
one mod that i was interested in, were these lights:
http://www.carid.com/product.php?pro...t=19147&page=1
anyone have any pics of these headlights installed?
Old Feb 9, 2010 | 06:37 PM
Mr. Brett's Avatar
I might be wrong, but I think those are the same ones that can be picked up off of eBay for around $150.
I'm pretty sure these can only take halogen bulbs, not HIDs...and they take H3 bulbs last I checked.
For that kind of money, you're better off doing a retrofit. It'd look much nicer. Or are you planning on staying with stock halogen bulbs? Either way, you'd also have to wire in a separate line for the high beams.
Old Feb 9, 2010 | 06:45 PM
If you want those just get them off eBay. Search for pics through the albums. End of thread.
Old Feb 9, 2010 | 06:55 PM
Nexus67's Avatar
You'll find almost any setup in here:
http://forums.maxima.org/5th-generat...ting-here.html
Old Feb 9, 2010 | 07:58 PM
thanx guys. bookmarked it.
haven't been on the .org forums for awhile. forgot how everything works.
Old Feb 9, 2010 | 08:19 PM
anomaly117's Avatar
you can get those on ebay. those projector lenses are junk tho. youre better off getting the lights that look like those with the plain old reflectors like these: http://cgi.ebay.com/ebaymotors/00-01...Q5fAccessories. if you were to get the projectors, your best bet would be a retro, and it would end up costing you more money and work.
Old Feb 9, 2010 | 09:55 PM
me likey! thanx.
Old Feb 11, 2010 | 05:10 AM
GilLesS72's Avatar
I have a Maxima 2000 SE and i want to get projector lights with angel eyes.... what should i do? could i find headlights of newer model like 2002-03, open the light and install angel eyes my self...
if so can i fit XENON bulb in there?
Old Feb 11, 2010 | 05:12 AM
GilLesS72's Avatar
or should i get one of those kit???
http://cgi.ebay.ca/00-03-NISSAN-MAXI...item2558ba8f08
Old Feb 11, 2010 | 07:03 AM
hove75's Avatar
dont do it they are crap u cant see **** from them had them and took them off in a hour
Old Feb 11, 2010 | 07:05 AM
hove75's Avatar
hahha i just sold mine for 80
Old Feb 11, 2010 | 09:07 AM
Mr. Brett's Avatar
In all seriousness, you'd be best doing a retrofit. The beam is so much brighter and wider. They're not that hard to do, it's just a matter of being willing to pony up the extra money to do it.
If you do it right, though, the end results are usually gorgeous.
Old Feb 11, 2010 | 11:02 AM
GilLesS72's Avatar
Ok but can you explain what's a retrofit???
Old Feb 11, 2010 | 01:11 PM
Please do some research.
Old Feb 11, 2010 | 02:30 PM
Nexus67's Avatar
Overall, you can retrofit your OEM headlights (or aftermarket ones) with a projector lens (these lenses are usually from cars that came with projectors from the factory i.e. Acura TSX, Infiniti G35, Lexus etc. etc.)
Search: 'projector retrofit' it contains much much more detail (and I believe a few write-ups as well)
you could also check theretrofitsource.com
Old Feb 11, 2010 | 03:03 PM
yeah i believe you....
i think im just gonna save up and do an 02-03 headlght swap. thanx for the heads up.
Old Feb 11, 2010 | 03:09 PM
Mr. Brett's Avatar
This is always a good decision. Kinda pricey, though.
Just be ready to have to run separate wires for the high beam. I dont think it's too difficult.
Old Feb 12, 2010 | 12:54 AM
GilLesS72's Avatar
So its possible to fit 2002-03 Maxima headlights in a 2000 Maxima???
Does it fit perfectly?
Old Feb 12, 2010 | 04:01 AM
arcueda's Avatar
info should be here somewhere.....someone else could confirm this for me, i believe the fit, but there is a small gab b.c the bumper is different?
while im on the subject, are these tsx, or just tsx wannabees lol
http://cgi.ebay.com/ebaymotors/Bi-xe...Q5fAccessories
Old Feb 12, 2010 | 04:02 AM
arcueda's Avatar
nevermind, i can tell they arnt, sry for the bump
Old Feb 12, 2010 | 08:25 AM
Z-Powered's Avatar
I'm looking for some replacement headlights because my OEM HIDs are slowly becoming opaque. I know the eBay projectors suck, but what about these reflector style ones? Are they compatible with HID bulbs? Thanks. Nevermind, they don't fit Maximas with HIDs.
Headlights
Old Feb 12, 2010 | 09:14 AM
Mr. Brett's Avatar
Headlights
Best way to clear up foggy headlights is to grab yourself some 2000-grit sandpaper and wetsand the hell out of them. Then use a real fine polish to smooth everything out, and then finally throw on a nice coat of wax to protect them.
It'll make them look like brand new. The only downfall is, once it's done, it needs to be re-done about every 6-9 months depending on the weather where you live.
If you're nervous about using sandpaper on your headlights, Brasso or Meguiar's Wheel and Mag polish are a good alternative. Just make sure you keep the stuff off your paint.
Old Feb 13, 2010 | 04:45 PM
Z-Powered's Avatar
^ Yeah, sanding my headlights would make me kinda nervous. And after taking a closer look at them, it looks like all the fogginess is on the inside...
Like when the lights are off, they look ok. But when I turn the lights on, then you can see all the haziness.
Old Feb 13, 2010 | 05:02 PM
tunafish51's Avatar
Well, with no light on the dirt cannot really be noticed, when the light is on the beam of light is obstructed by the dirt in some way. Makes sense
Old Feb 13, 2010 | 05:04 PM
nalc's Avatar
Those are "G1" aftermarket projectors. not very good.
However there are also "G3" aftermarket projectors from the same company. IIRC, they are like $150/pair including projectors bulbs and ballasts. How they wire is they stick through the bulb hole in your existing reflector. No cutting needed.
There's a guy on HIDPlanet with a hook-up for them straight from China.
Old Feb 13, 2010 | 06:34 PM
anomaly117's Avatar
SEARCH
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
