Custommaxima FSTB
Old Mar 9, 2010 | 05:40 PM
jowo9's Avatar
Custommaxima FSTB
Ok, so the FSTB on custommaxima.com is only $35... as opposed to the Stillen at $187... I realize the Stillen FSTB is going to be better quality, but it's a pretty simple structure, so I'm thinking the custommaxima one probably yields similar improvements. Anyone tried the custommaxima FSTB? What does everyone think?
Old Mar 9, 2010 | 06:01 PM
a33i30's Avatar
Get a vibrant racing one, mine was around $50 shipped and it's built just as good as the stillen one.
Old Mar 9, 2010 | 06:15 PM
thestartingline's Avatar
The strut bar on my 4th gen is a custommaxima.com one and after a couple of years the paint is peeling pretty bad. Other than that it works fine.
Old Mar 9, 2010 | 08:00 PM
BLUEMAX01SE's Avatar
Had the Custom Maxima FSTB on my 01 AE since 2003, no problems at all! no complaints! Definitely worth the $$
Old Mar 9, 2010 | 08:32 PM
zero2sixtyZ's Avatar
You embarrass me.
Idk if they released a new one, but I have one I purchased back in 06. It does it's job. Back then, my $59 were spent better than on a Stillen FSTB, so I'm happy with mine.
Old Mar 9, 2010 | 08:53 PM
a33i30's Avatar
Both of yours are the Vibrant Racing one they had before this new one.
Old Mar 9, 2010 | 09:05 PM
M1RAG3's Avatar
Ive had my custommaxima.com FSTB for about a year and I think it as worth every penny. I dont know if the one they are currently selling is the same version but mine is a nice, soild bar, and the mounts are pretty solid too...I noticed turn-in and stability during high speed cornering (>70 km/h) was also a lot better with the FSTB
heres a pic:
Old Mar 10, 2010 | 04:49 AM
NissanMan97's Avatar
im going to fab my own. A lot of the ones now (whether you spend $30 or $200) dont have the thick brackets like they should...aside from the Cattman Ti-bar if you can find it.
I had a CE bar on my 4th gen for 4 years...that was a good bar. Ive seen the new ones CM sells..not the same quality
B
Old Mar 10, 2010 | 12:51 PM
knight_yyz's Avatar
Toolie
vibrant doesn't make the FSTB anymore, the old custom maxima one was made by vibrant BTY
Old Mar 10, 2010 | 01:08 PM
when they were CE?
that was a good bar
B
Old Mar 10, 2010 | 01:12 PM
Rochester's Avatar
Um... Racingline Performance.
But if you do fabricate your own, document the process. It would make for good reading. Maybe you'll start a trend.
Old Mar 10, 2010 | 01:15 PM
rroderiques77's Avatar
Demodded and Forgotten
for Racingline. I've had mine for years.
Old Mar 10, 2010 | 01:18 PM
that does look like a good one.
I wouldnt be fabbing my own if i couldnt do it for free. of course its going to be all steel. so weight will be an issue but again for free itll be a fun experiment
B
Old Mar 10, 2010 | 01:38 PM
Rochester's Avatar
That's because they're using my engine bay pic on their website. (heh heh)
Shameless... I know.
Old Mar 11, 2010 | 05:25 AM
really? thats cool.
wanna help me out by giving me some measurement if you have time?
B
Old Mar 11, 2010 | 05:34 AM
Rochester's Avatar
Sure, no problem. What kind of measurement are you referring to?
Old Mar 11, 2010 | 06:12 AM
the length of the bar
that height of the stacks (for lack of a better word) on the brackets
that angle of the stacks
the angle of the bar at the ends that sit in the brackets
the distance between the bottom of the bar and whatever sits underneath it
the thickness of the bar and brackets
the width between the stacks on the brackets
that should be about it.
B
Old Mar 11, 2010 | 06:33 AM
Rochester's Avatar
B
Holy crap. I can't do all that. I can take some simple measurements, and some close-up pictures... but "angle of the bar"?
Dammit, Jim, I'm a doctor, not a mechanical engineer!
The thing immediately under the bar is the upper intake manifold. More specifically, it's where the upper IM and the intake plenum meet. That gap varies from FSTB to FSTB, and it can also vary depending on your engine mount bushings. Clearance is a common concern, particularly with phenolic spacers. Although really, it's rarely an issue.
[edit] Here's a thought: buy a really cheap FSTB off ebay, and use that as the baseline for fabrication of a more sturdy design.
Old Mar 11, 2010 | 06:40 AM
LOL....thats understandable. simple measurements are a big help. but if you could take a measurement of the entire length of the bar and then the length of the bar where it starts to angle...with that i can use SOACAHTOA and come up with the angles myself
B
Old Mar 11, 2010 | 06:59 AM
vball_max's Avatar
John, thats pretty sweet they used your bay for their demo pic.
Do you know whose engine bay the other picture is? Check out the intake and snorkel. Pretty sweet system.
Sorry to get off topic.
Old Mar 11, 2010 | 07:16 AM
Rochester's Avatar
I don't know what that is. (Could that be an Altima SE?) It's got the 5.5 engine cover, but everything else is not quite right. The radiator brackets are different, there's some kind of material around the strut towers, the battery is sideways, and that snorkel is nothing I've ever seen before.
Old Mar 11, 2010 | 07:23 AM
vball_max's Avatar
OMG.....I didnt even realize it wasnt a maxima :
I just noticed the snorkel and intake and thought it looks like a decent CAI setup.
Old Mar 11, 2010 | 12:41 PM
knight_yyz's Avatar
Toolie
it's a 6th gen, or at least he has a 6th gen rad
Old Mar 11, 2010 | 12:56 PM
CMax03's Avatar
That FSTB from Racingline Performance is a decent price....
Old Mar 11, 2010 | 02:44 PM
Rochester's Avatar
Some pics. Excuse the winter crap, and the rusty strut nuts. (New struts in a few weeks, so...)
Old Mar 12, 2010 | 05:12 AM
do you think the fact that the bar is bolted in to the brackets is a key component or just simply done that way for ease of install?
i would think one welded piece would be stronger and allow for more resistance...thoughts?
B
Old Mar 12, 2010 | 05:21 AM
Rochester's Avatar
You know, I don't think it matters. But I'm no mechanical engineer.
Old Mar 12, 2010 | 05:24 AM
mandyfig's Avatar
I have an 00, where do I get a decent, well priced FSTB?
Nothing fancy. Just want to know if this thing works well with our Max.
Old Mar 12, 2010 | 05:26 AM
vball_max's Avatar
B
I've thought about that as well. As long as you tighten the bolt enough that it wont slip under load, its just as good as welding. But what the required torque is to achieve that is anyone's guess.
Old Mar 12, 2010 | 05:46 AM
i was thinking along those same lines. now i just need to take some measurement under my hood, find a think piece of steel and get to fabricating.
would everyone agree that the angle of the end of the bar appears to be between 15-25 degrees?
B
Old Mar 12, 2010 | 08:22 AM
mandyfig's Avatar
CustomMaxima still sells the FSTB for $50 shipped.
Fleabay has them for $30 shipped. Are the Fleabay ones any good?
For $20 difference I can see how sturdier the the CustomMaxima is.
Old Mar 12, 2010 | 08:23 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
I have the Custom maxima one, have had it since 2001 so no complaints... Buy CM and save the rest of the money.....
Old Mar 12, 2010 | 08:30 AM
mandyfig's Avatar
I am a Mechanical Engineer and I can tell you that the above is robustly designed, comparing it to the ones I have seen earlier and the ones being sold in fleabay.
However I can not tell if one is really outperforming the other. You would think that it will. Robustly designed means tha factor of safety is higher, means it will do the job guaranteed. Whether the one being sold by CustomMaxima or Fleabay is doing the job...it might well be.
Old Mar 12, 2010 | 08:34 AM
mandyfig's Avatar
Comparing CustomMaxima and Fleabay FSTB, there's not much difference. One uses a flat stock and the other a billet (round) bar.
The forces on a strut bar can be downward and upward. More on upward when you are turning. The whole body is leaning on the strut. This upward force is being transferred via the FSTB link to the other tower, making it rigid and one piece. Hence better handling. JM2C.
Old Mar 12, 2010 | 08:41 AM
can you answer my question about whether welded or bolted is better?
B
Old Mar 12, 2010 | 08:50 AM
mandyfig's Avatar
Bolted is a better design. Welds can break. Keep in mind the frame that holds the bolts are welded to the body-link eventually.
Old Mar 12, 2010 | 09:00 AM
i dont understand what you mean by the last part...im slow...lol
B
Old Mar 12, 2010 | 09:18 AM
mandyfig's Avatar
You have 2 parts. The frame-link and the strut brace. The frame has to attach to the brace. This is by bolts and should have a way to adjust, length wise, you will see a bolt for adjustment.
The brace connection is welded. That's what I meant. Do not make a brace that is all welded.
Old Mar 12, 2010 | 09:39 AM
mandyfig's Avatar
Vibrant racing? Any links? Thanks.
Old Mar 12, 2010 | 09:42 AM
mandyfig's Avatar
Rochester, what's your FSTB? Yours is the best design.
