max with mmi and es subframe bushings step in
i got es mmi in my max with nwp torque link but my subframe (or cross member) bushings r shot.... any have es mmi with the subframe bushings...is their a great improvement or a waste of 20 bucks?? i might buy the sub. bushings if their worth it or do a 4$ washer mod wea u replace the bushings with washers and the motor doesnt move at all!
jus wanna kno ur reviews b4 i buy the sub. bushings
do the bushings, not the washers. Trust me. I managed to melt the bushings out of the crossmember like an idiot and had to drive washers style. If you keep the radio turned up its fine, but the wierd sounds you will be hearing otherwise will freak you out
would this be the reason i still feel like the motor is hopin around if i let go of the accelerator when at cruising speeds???? So these are them and i only need one set for front and back???? http://cgi.ebay.com/ebaymotors/ES-Su...Q5fAccessories
JoshG
51
09-21-2015 10:41 PM
