Oil soaked spark plug hole Help!
Old Mar 14, 2010 | 06:59 PM
VQA32SE_L's Avatar
Hey guys I really need ur help, I turned on the 5th gen today and I was getting a huge misfire. So at 96,000 I decided to go ahead and change the spark plugs to see if it would resolve the issue. So the front ones were pretty much toast, but when I got to remove one of the rear ones I pull the coil out and its soaked in oil!... ok so what do I have to do now to tackle this issue??
I really need ur help thanks!
Pics...
Spark plug covered in oil...
Old Mar 14, 2010 | 07:01 PM
perkman87's Avatar
typical 5.5 problem. Switch over to the 6th gen valve cover and gasket. Problem solved, Mine was the exact same
Old Mar 14, 2010 | 07:11 PM
rroderiques77's Avatar
Demodded and Forgotten
what he said ^^^^^^^^^
Old Mar 14, 2010 | 07:25 PM
VQA32SE_L's Avatar
I only plan on keeping the car another year or so before buying a 6th Gen. Will changing the valve cover gasket hold up? thanks guys...
Old Mar 14, 2010 | 08:05 PM
VQA32SE_L's Avatar
Do u guys have Part #'s for the 6th gen valve cover? this will be a direct fit with no modification needed to install??
Old Mar 14, 2010 | 08:08 PM
Child_uv_KoRn's Avatar
Bad *** Newb
someone didn't even spend 2 secs searching
Old Mar 14, 2010 | 08:21 PM
VQA32SE_L's Avatar
Didn't know what to search for exactly but I got it now... found a good Write up by EPACY
Thanks for all your help guys...
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
Need help
23
Oct 2, 2015 08:56 AM
