OEM HID Ballast Information
Old Mar 16, 2010 | 10:09 AM
Prophecy99's Avatar
Is it correct to assume the 5.5 OEM HID ballasts are 35 watt ballasts knowing the OEM HID D2R bulbs are 35 watts themselves?
That being said is it correct to say when using any kind HID bulbs you want to match the wattage of the bulbs with the ballast?
Or am I looking at it all wrong?
Thanks for any info.
Old Mar 16, 2010 | 03:21 PM
03VQMAX's Avatar
Yes, you should have the same 35W bulbs paired with the 35W ballast, I've personally never mismatched them like 55W bulbs with 35W ballast or the other way around so I am not sure what will happen, and yes the oem ballast have a 35W output 85V.
Old Mar 16, 2010 | 03:34 PM
glockfanbob's Avatar
I'd be interested to hear what other people have (i.e if anyone uses 55w bulbs in the 35w ballast).
Old Mar 16, 2010 | 04:05 PM
n3985's Avatar
大陆弟弟
55W bulb with 35W ballast = same thing as if it were 35W bulb
35W with 55W ballast = over driven bulb which outputs more light but shortens life, this is done frequently with OEM 35W bulbs as aftermarket ones overheat and destroy chrome in the projectors/reflectors
Old Mar 16, 2010 | 08:39 PM
grip1968's Avatar
Can the 2003 Headlights fit on my 2000 maxima, I love the projector
headlights on the 2003.
Old Mar 16, 2010 | 08:40 PM
n3985's Avatar
大陆弟弟
1. Yes
2. 02-03 are REFLECTOR style headlights, the glass ball is projector
Old Mar 17, 2010 | 05:29 AM
Prophecy99's Avatar
Thanks 03VQMAX.
Thank you n3985 makes sense.
I am thinking about using an extra set of OEM ballasts I have for a fog light set up.
Old Mar 17, 2010 | 06:27 AM
n3985's Avatar
大陆弟弟
You could re-use the OEM ballasts if you buy D2R to AMP converter cables, since the plug going to the bulb on OEM ballats is different than aftermarket ones.
Old Mar 17, 2010 | 07:50 AM
03VQMAX's Avatar
Thanks 03VQMAX.
Not a problem, I'm actually in the process of doing that same conversion also, I'm just waiting for my oem fog lamps to arrive so I can do it in one shot.
Old Mar 17, 2010 | 10:00 AM
Prophecy99's Avatar
Awesome. Also something I definately needed to know. Thanks
Interesting, Lets get in contact when we both are closer to doing it then.
So it seems that all I need would be 35watt H3 HID bulbs, the D2R-AMP convertor cables, and additional wires for power supply to the ballasts.
Old Mar 17, 2010 | 10:07 AM
03VQMAX's Avatar
Exactly, What type of OEM ballast are you going to use?
Old Mar 17, 2010 | 10:15 AM
Prophecy99's Avatar
ones straight from 5.5 headlights. What are you using?
Old Mar 17, 2010 | 11:47 AM
03VQMAX's Avatar
Oh OK, I'm using the dark gray Matsu s h i ta Ballast from the 04-06 Maxima's and are on many other Nissan and Infiniti vehicles as well. The 5.5 gen ballast looked complicated to I didn't even bother.
Old Mar 17, 2010 | 12:05 PM
nalc's Avatar
02-03 ballast is a second generation Matsu****a.
It's not super complicated, there's just that extra black box on the cable.
On the 04+ maxima, it's a third generation Matsu****a ballast, which has that extra black box integrated into the main box. So it's a bit more compact.
Performance should be identical.
The rounded grey one from 04+ is waterproof except for the connector on the top. The square silver one from the 02-03 may not be waterproof, I'm not sure. Hit it with some silicone to be safe.
Old Mar 18, 2010 | 08:31 AM
Prophecy99's Avatar
Thanks for the info, good to know. Knowing that I will definately silicone to be extra safe I would guess the 04+ Ballasts are more $$ too.
Old Mar 18, 2010 | 03:20 PM
03VQMAX's Avatar
Depending who you get them from, ebay has a bunch of them for sale.
Old Mar 18, 2010 | 03:27 PM
zzmmrx0xmzz's Avatar
you can put aftermarket hid bulbs onto the oem ballast without a problem
as long as theyre d2r bulbs
Old Mar 18, 2010 | 04:56 PM
03VQMAX's Avatar
Yea we know, but we are talking about retro fitting other aftermarket bulbs like H3, 9006 etc.. to make them work with OEM Ballast.
Old Mar 18, 2010 | 07:12 PM
nalc's Avatar
Ballasts are a crapshoot. I've seen some matsu****as sell for $30, other identical ones sold the same day for $150.
$100 per pair is about average though.
Old Mar 18, 2010 | 07:20 PM
03VQMAX's Avatar
Got my pair for $70, but yea they have a big range of prices.
Old Mar 18, 2010 | 08:37 PM
Prophecy99's Avatar
Yea we know, but we are talking about retro fitting ..... ..... bulbs ......... to make them work with OEM Ballasts.
+8
knight_yyz
Nov 1, 2015 01:34 PM
sliptap
Sep 30, 2015 05:57 AM
atriuum
Sep 28, 2015 01:19 PM
