Car pulls sharply left when turning left - help
Old Mar 19, 2010 | 06:45 AM
WMASSMAX's Avatar
So when making left hand turns, when I reach a certain radius in the turn, the car will suddenly tug hard to the left and feels like it's going to skid out if I don't straighten out and let off the gas.
Just under a year ago I had front sway links, bushings and both outer tie rods replaced. Also had all bushing replaced. I'm hoping that none of these parts are damaged, or if there are other things at play.
I am also experiencing faster than normal wear on the inside of the front tires.
I'm bringing the car in for an alignment tomorrow am, and hopefully that will do the trick. Does anyone thing I'm wasting my time and have a bigger issue at hand?
Old Mar 19, 2010 | 07:02 AM
TallTom's Avatar
Had that same issue with a Ford Tempo after NTB replaced a tierod. They f'ed up the install and forgot to install a bushing. Went back twice and they couldn't find the problem. Had to take it to my mechanic to find the problem.
Long story short, NTB reimbursed me for all the work from both mechanics.
Old Mar 19, 2010 | 07:11 AM
WMASSMAX's Avatar
Thanks. This problem seems to have developed sometime in the past 6 months or so I'm not sure if that would be the culprit. You're also talking about a completely different car....I'll look into it though.
Old Mar 19, 2010 | 10:20 AM
5 ltr. beater's Avatar
i had that same problem on an older maxima and my rack and pinion was on its way out. replaced it and no more sudden pulls to the left or right.
Old Mar 19, 2010 | 04:17 PM
WMASSMAX's Avatar
Wow that sounds like a big job. How much did that cost?
I just tugged on the wheel and felt a knocking. The more I tugged the less I felt that knocking. Starting to think it may be something else.
Old Mar 19, 2010 | 10:29 PM
it was like $400 parts and labor.
Old Mar 22, 2010 | 07:28 AM
WMASSMAX's Avatar
everyone was wrong. lower ball joints were shot.
Lakersallday24
Jun 16, 2019 01:35 AM
trasmadean
Feb 1, 2017 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
kirkhilles
Aug 8, 2015 10:53 AM
