Changed motor mount = no more vibration
Old Mar 26, 2010 | 03:19 PM
exodusx187's Avatar
A while back i posted about heavy vibration during 1-2 and 2-3 shift at around 2000 rpm to 3500 rpm. after seeing several members were having the same issue, i purchased a rear motor motor off ebay and removed the old mount. the vibration i was experience is now GONE....what a difference changing the motor mount made. the old mount was seriously damamged as you can see from the pics below. low gear shifting is now way smoother. i did notice however, that the rubber in the front mount is starting to crack. would i be able to change the front mount without having to remove the entire cross member and rear mount again?
old mount pics
Old Mar 26, 2010 | 06:59 PM
auveeb's Avatar
Where did you buy the mount? I'm having a similar problem, especially at idle.
Old Mar 26, 2010 | 07:29 PM
sergofast's Avatar
did you replace with a stock or poly energy suspension mounts? also how the HECK did you get a wrench up between the trans and the mount to remove the bolt that goes through the engine block on the rear mount????
Old Mar 26, 2010 | 07:48 PM
nismopc's Avatar
You can get the rear off eBay for $36 shipped...
...this is the one I purchased for my '02 SE. It's the same for all Maxima's from 1995-2003.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Nissan part # 11320 - 40U01
Old Mar 26, 2010 | 07:59 PM
nismomaxgtr18's Avatar
Nicee. How's the quality of the new one?
Old Mar 26, 2010 | 08:08 PM
nismopc's Avatar
The one I purchased is identical to OEM...
...check out this thread for comparison pictures...
http://forums.maxima.org/5th-generat...lled-pics.html
Old Mar 26, 2010 | 08:57 PM
wyche89's Avatar
i need to change my front mount as well.. anybody have an answer??
we won't have to remove the crossmember, but we might have to support the engine with something.. i dont know though.. do we need to support it if we're changing only the front mount??
Old Mar 26, 2010 | 10:47 PM
ZGadson's Avatar
How easy is it to change the mount? Say, on a scale from 1 to 10 (1 being a light bulb, 10 being an engine swap).
Old Mar 27, 2010 | 04:48 AM
TDotMax's Avatar
I highly recommend ES motor mount. Here's a vid of a dyno pull from last year with my ES mounts. As you can see there is no motor movement.
Old Mar 27, 2010 | 06:26 AM
wyche89's Avatar
i'm gonna stick with the stock mounts and try that nwp torque link bar
Old Mar 27, 2010 | 07:34 AM
essential1's Avatar
My axles cry for mercy...
URL=http://s291.photobucket.com/albums/ll320/Ghost_54/?action=view&current=MVI_1351Tothemax1.flv][/URL]
Impressive, If the ES mounts didnt drop the transaxle assembly by half an inch i'd get it. I ride too low as it is so I need the motor to sit as high as possible, lol
Old Mar 27, 2010 | 08:47 AM
exodusx187's Avatar
the mount that nismopc posted is the exact one that I bought. quality is pretty good compared to my old mount lol. the job was a pain in the as*... the hardest part was getting the rear mount bolt to line back up during reassembly. I had a friend help me hold the cross member while I tried to realign the bolt. other than that it's an easy job. takes some patience to get to the rear bolt due to limited space. I used an air tool which also helped. later I will post pics of the tools I used if that helps
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
