I cant find the rattling in my car can you?
Old Mar 30, 2010 | 03:16 PM
hot_wax_tree's Avatar
There is this rattling sound in my car(interior). it sounds like something rattled loose. It sounds like it is on the inside but none of my passengers or I can find where its coming from. when it rattles is when I first start up and basically any time im at a higher (1500+) RPM. I have a fart can so it puts out some good vibrations. this sound was there before the exhaust.
So is there some sort of plastic or metal peice that tends to come loose on our maximas that would make this noise?
I have a 02 SE cloth interior, non bose, and no sunroof
Any suggestions or comments on stuff I left out to eliminate things are appriciated
Thank you
Jake
Old Mar 30, 2010 | 03:28 PM
wyche89's Avatar
my front cup holders rattle notoriously.. try that
Old Mar 30, 2010 | 03:49 PM
Ghost_54's Avatar
Front glove box will rattle ... center arm rest lid will rattle ... back sub deck platform can rattle ... seat beat covers on the back deck can rattle ... rear plastic side panel can chatter against the rear window ... pretty much if you can remove it then it can become loose and irritate the hell out of you.
Best fix is locate the source of irritation and then use 3m foam tape to cushion that source
Old Mar 30, 2010 | 04:00 PM
ReasonableDoubt's Avatar
This might be a stretch, but do you have a pair sunglasses in the holder? Just a suggestion...
Old Mar 30, 2010 | 08:46 PM
Scottwax's Avatar
That's Mr. Detail to you
Same here. I am about to remove the console and take out the door over the cup holder because that is what is making all the noise. No problem if it is closed but if I have a drink in the car (and since I work outside, I always do), it buzzes and rattles.
Old Mar 30, 2010 | 08:48 PM
Mr. Brett's Avatar
My coin holder likes to rattle like mad at idle. I have the same issue with rattling drinks in the cup holder as well.
I'm also starting to notice some rattle somewhere in the B-pillar. All thanks to my catback.
Old Mar 30, 2010 | 09:19 PM
wyche89's Avatar
EXACTLY!! that drives me cazy man.. how do you think we can fix that?
Old Mar 30, 2010 | 09:20 PM
Mr. Brett's Avatar
Sound deadener is about the only thing you can do.
Old Mar 30, 2010 | 09:23 PM
jeff5347's Avatar
yup i have some rattle in my b pillar area on the passenger side. it may be that or the glove box. only happens from a dead stop while turning right..
ive taken everything out of the glovebox and it is still there. I tell my wife and she says.. i cant hear it or don't worry about it. yea right i hear anything out of the norm and i go into fix it mode.
Old Mar 30, 2010 | 09:36 PM
Feldman's Avatar
I had something similar to this except it was more of a creaking a piece of felt wedged between the dash and b pillar cover took care of mine.
I also get some rattling from my coin holder or cubbie under my cd player at the right rpm if i have the right (or i guess wrong) stuff in there. Just touching the cubbie or coin holder makes the noise stop for me, then i can move or adjust whatever is causing the noise. You might want to try this technique yourself if you haven't already
Old Mar 30, 2010 | 11:20 PM
i've tried the cup holder i have not done the b pillar thats next. I will check all of the pillars just to be safe
Old Mar 31, 2010 | 06:10 AM
wyche89's Avatar
what is that and how do you use it?
Old Mar 31, 2010 | 06:45 AM
Chris Gregg's Avatar
Get Off My Lawn
I have what sounds like a plastic rattle. Though, mine seems like it is coming from the dash around the defrost vents/light sensor.
Sound deadener? Cut to size/strip you desire, then remove paper backing like on a sticker, then apply to a clean/dry surface.
Old Mar 31, 2010 | 07:13 AM
Mr. Brett's Avatar
Basically, anything like Dynamat. There are cheaper brands around, just look for them. Dynamat is good for sound systems. Other deadners can be had cheaper for just stopping rattling, etc.
Like Chris Gregg said, basically, it's just an adhesive-backed pad that absorbs sound.
As far as buzzing and rattling, you can use get away with stuffing foam pads in between the rattling parts sometimes, too.
Old Mar 31, 2010 | 08:04 AM
merovi's Avatar
I had a small rattle that sounded like it was coming from the front dash vent area, right below the windshield. Only would happen when my fan was on setting 3 or 4. Also had a random rattle from what I thought was the passenger vent/glove box. Never figured it out. It was just so random that I ignored it. Never could find it and wasn't about to rip my entire dash apart for what would most likely me a small piece of plastic or a screw.
Old Mar 31, 2010 | 08:51 AM
jeff5347's Avatar
found mine.. it was my sunglasses in the sunglass holder. didnt even sound like it was in that area. i just started removing things and viola
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kingw323
20
Oct 21, 2015 08:36 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
kirkhilles
Aug 8, 2015 10:53 AM
