Cheap/easy 75MM ID aluminum maf adapter
Old Apr 11, 2010 | 09:56 AM
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Spectre 3" aluminum maf adapter roughly $15-20 if you order online. Measures about 5mm bigger ID than the stock maf adapter. The kit doesn't come with an adapter that fits our maf, so it must be made to fit.
Stock maf tube ~$15-20 used on forums, or free if you hack up yours. I just cut off the MAF adapter right where the screw holes end and then sanded it smooth and flat.
Used the black VHT ceramic paint. I would bake it if not for the plastic maf adapter.
Pardon my messy work bench
Taped off for painting (I like to keep a clean non painted surface for the couplers)
Paint drying
Finished
Old Apr 11, 2010 | 10:11 AM
CMax03's Avatar
How much sensor penetration are you getting now? Is the sensor still in the main airstream, not to close to the edge where the boundary layer air sets and doesn't move quite as fast?
Old Apr 11, 2010 | 10:13 AM
nismopc's Avatar
Excellent mod!!!
Slight confusion. How did you get the MAF adapter to secure to the aluminum housing? I see no screws holding it there...
Old Apr 11, 2010 | 10:24 AM
Originally Posted by nismopc
Excellent mod!!!
Glue. Strong CA. Has worked pretty well in the past for me binding metal and plastic.
It is marginally less than the stock location. Maybe 1/16". I don't foresee any problems. I will have to adjust the A/F anyway.
Old Apr 11, 2010 | 10:31 AM
DCZC's Avatar
link to this?
Old Apr 11, 2010 | 10:41 AM
nismopc's Avatar
Originally Posted by DCZC
link to this?
I found it here, but am sure it's cheaper elsewhere:
AutoZone Spectre MAF Adapter 9405
Old Apr 11, 2010 | 10:42 AM
link to this?
Ok, I'll bite.
LINK TO THIS
Old Apr 11, 2010 | 01:13 PM
essential1's Avatar
My axles cry for mercy...
I've seen these but never bothered to try it since it didnt fir our MAFs. But This is a good idea.
Old Apr 11, 2010 | 01:45 PM
I had the extra maf tube, and I got the maf housing off a friend for cheap... I have been considering what I would do with my MAF, and this seems like the best for the price.
Old Apr 12, 2010 | 08:30 AM
nismopc's Avatar
sparks,
Two things:
1. I found 3M products that refer to CA adhesives. What type did you use and is it heat safe? I've gotten something I'd like to try (plastic to metal).
2. Would you think there would be any tuning needed if someone went to a complete 75mm intake pipe to throttle body? Or would the ECU compensate for the slight difference in increased air flow?
Old Apr 12, 2010 | 09:06 AM
mandyfig's Avatar
This is excellent! Great DIY!
Old Apr 29, 2010 | 02:06 PM
Rods03Max619's Avatar
Agreed but wont be doing it for now
Old Apr 29, 2010 | 02:53 PM
NmexMAX's Avatar
dot dot dot ...
Well good.
TallTom
57
Oct 14, 2025 05:16 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
lux97Max
Sep 28, 2015 11:18 PM
