Cooling Fans
Old 04-20-2010, 12:45 PM
MaxJay's Avatar
Cooling Fans
I am hoping you guys can help me out a little. I have a 2002 Altima 3.5 SE and the cooling fans are nearly always on. The car does not over heat and the coolant level is where it should be. It just doesn't seem like they should be running that much. It doesn't matter if I am in the city or highway, they just always run. Any ideas?
MaxJay is offline
Old 04-20-2010, 12:53 PM
dot dot dot ...
NmexMAX's Avatar
They run based off of coolant temperature and/or AC compressor on. Either a relay for your compressor is shot, of, your ECT is shot, or, it's just warm ECT's.
NmexMAX is offline
Old 04-20-2010, 01:10 PM
MaxJay's Avatar
Everything still works including the AC. I did notice that the heat seems like it could be warmer. What is ECT? What places do I need to check?
MaxJay is offline
Old 04-20-2010, 01:17 PM
Demodded and Forgotten
rroderiques77's Avatar
Engine coolant temperature.
Get yourself an infrared thermometer and measure the temperature before and after t-stat. If your fans are on constantly, then there is a chance they are being commanded to do so.
rroderiques77 is offline
Old 04-20-2010, 01:42 PM
CraigSE's Avatar
I had this same thing happen to a 2000 maxima after doing the water pump. It was just low on coolant. It did not overheat, but I'm guessing the water control valve saw lack of flow and turned the fans on full speed.
CraigSE is offline
Old 04-20-2010, 02:51 PM
dot dot dot ...
NmexMAX's Avatar
Or the engine coolant temperature sensor is
NmexMAX is offline
Old 04-20-2010, 06:43 PM
MaxJay's Avatar
Lol I like that emoticon. Where is the engine coolant temp sensor?
MaxJay is offline
Old 04-20-2010, 06:57 PM
CraigSE's Avatar
Have you checked the coolant level?
First thing to check...
CraigSE is offline
Old 04-21-2010, 06:10 AM
MaxJay's Avatar
Yep. Checked it again last night. When the car is completely cold it is sitting at the minimum level in the overflow tank.
MaxJay is offline
Old 04-21-2010, 06:26 AM
dot dot dot ...
NmexMAX's Avatar
Maybe add a smidge.
NmexMAX is offline
Old 04-21-2010, 07:17 AM
MaxJay's Avatar
Is adding some distilled water ok you think? Or should I go buy coolant?
MaxJay is offline
Old 04-21-2010, 07:29 AM
dot dot dot ...
NmexMAX's Avatar
Either way .. or mix them in the appropriate ratios
NmexMAX is offline
Old 04-21-2010, 07:46 AM
MaxJay's Avatar
Still wondering where the ECT sensor is located. Just in case the water/coolant doesn't cut it.
MaxJay is offline
Old 04-21-2010, 10:19 AM
Somewhere on the block. Usually right by the t-stat. I dont that a FSM on me right now.
EDIT: Just looked it up in Mitchell. It is located just to the right of front valve cover, attached to the block.
Old 05-28-2010, 06:35 PM
Nelsito65's Avatar
MaxJay, any update on this? Are both your cooling fans still working almost all the time? What was the solution, if you did solve it?
I have a similar issue; when my fans operate, they both come on at the same time, regardless of whether I'm using the A/C or not. It is a new fan assembly (same brand and model as the one before), but I don't remember the previous one behaving that way.
Nelsito65 is offline
tarun900
19
12-20-2021 06:57 PM
Miket2006
03-01-2021 03:55 AM
magiconthetire
10-26-2015 09:03 PM
BobTX10
10-07-2015 08:43 AM
Quick Reply: Cooling Fans
