FRONT STABILIZER LINK
Old Apr 29, 2010 | 09:26 AM
  #41
auveeb's Avatar
Where would one grease the endlinks? I'm assuming right over both threads?
Old Apr 29, 2010 | 10:15 AM
  #42
Nelsito65's Avatar
Through the grease fittings, for those that have them.
Old Apr 29, 2010 | 10:17 AM
  #43
Rochester's Avatar
What? No, use a grease gun over the fittings (nipples), and "pack" the boots with grease. It's kind of old school.
Old Apr 29, 2010 | 01:45 PM
  #44
cmd26's Avatar
You may want to check other suspension pieces (i.e. wheel bearings, lower control arm, strut, etc...).[/QUOTE]
Yes i will be doing that because I do think more components might be worn out.
Old May 1, 2010 | 03:31 PM
  #45
cmd26's Avatar
I got the car in the air checked everything it was all tight. I think my strut os bent no really sure, but the sway bar link had no play or anything all other components felt tight. Can i be missing something?
Old May 4, 2010 | 03:03 PM
  #46
2slow's Avatar
Ive been meaning to reply...
If you are experiencing free play in the suspension, the end links were the wrong place to look. I know you said you've checked everything, but you should've inspected the struts, strut mounts, tie rods (inner & outer), steering rack, LCA balljoints and LCA bushings. These points define suspension and steering geometry, and likely hold the source of your issues.
Old Jun 6, 2010 | 05:23 PM
  #47
iSeriesDude's Avatar
I'm curious. Just replaced the stabilizer links today, left and right sides, with a set of moogs from Advanced Auto.. I noticed that the hole in the control arm where the link mounts to the control arm is a lot larger them the threaded shaft itself. I checked the Hayes and FSM and did not see any indication of any type of bushing, nor was there one when I removed it. Curious if anyone else has seen this in their replacement of these parts?
Old Jun 6, 2010 | 06:03 PM
  #48
2slow's Avatar
That's normal for a stamped through-hole. Just ensure when you tighten the new MOOG endlinks they have adequate clearance to the control arm. The MOOG endlink's ball-joints are larger and can interfere with the control arm due to the through-hole's tolerances.
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
