ugh time to vent...
Old May 2, 2010 | 03:46 PM
greenwood's Avatar
ugh time to vent...
so this weekend after waiting a month for my custom maxima headers to get here i undertook the task of removing my crossmember and getting the stock manifolds out. With that done i went on to start installing the custom maxima manifolds. They fit just fine and im pleasantly surprised with the craftsmanship of the pieces. Things were going well until i went to bolt the y-pipe up. It doesnt fit! The rear flange is tweaked and doesnt line up with the manifold studs. Needless to say im f***in pissed!
I knew i could expect shotty fitment for only $200 but still this is crazy. Too make a long story short, dont make the mistake i did. Save up and get the OBX or Cattman. I wish i had.
But on a positive note i did get the opportunity to press in my new ES motor mounts
Old May 2, 2010 | 03:59 PM
Grand_hustle17's Avatar
^^^ I don't believe you would've been anymore pleased with OBX... that's how it works bro... happened to me too... I tell ppl if u easily get frustrated with fitment problem the pay 4 times extra to not have it... I believe everybody knew there would've been fitment issues
Old May 2, 2010 | 04:05 PM
greenwood's Avatar
i suppose so but its just sooo close to going in and its frustrating as f***. If it wasnt stainless id be able to cut and re-weld the ish myself.
Old May 2, 2010 | 04:23 PM
Gemner's Avatar
you should have left all the bolts loose until everything was together. In fact, i would suggest doing that anyway. get everything loosely bolted together and then tighten the bolts
Old May 2, 2010 | 04:45 PM
greenwood's Avatar
gemner, if only it was that easy. ive got everything as loose as it can go without dropping a manifold on my face and it still doesnt fit right. ive tried everything so now i need to find a shop around here that can cut and weld stainless steel.
Old May 2, 2010 | 04:55 PM
MAXIMA_STYLE's Avatar
dam im glad i decided against these now...u would think cm would fit this issue
Old May 2, 2010 | 05:04 PM
e-subliminal-2's Avatar
Use a jack. Step back, Calm down. Find a jack and force it on if you absolutely have too. They make them where they WILL fit, just a complete pita to do. Not like installing headers was already pita enough.......
Take a second, Shoot some pics, and see how it is.
Old May 2, 2010 | 06:26 PM
asianstyle's Avatar
me too, i came so close to getting these for my 01 ae also.
Old May 3, 2010 | 02:00 AM
yea i was one click away then researched more and between headers a safc apexi to keep it in tune and o2 sims for the secondaries i figured 700 isnt worth it for the power gains......i rather spend 250 for warpspeed or 350 for cattman ypipe
Old May 3, 2010 | 06:37 AM
Mr. Brett's Avatar
You'll still probably need a SAFC or VAFC for the y-pipe if you want the car to run right. The reason the car runs rich with headers is because there's more exhaust flow and no precats. Same with the Warpspeed/Cattman y-pipe.
O2 sims are not that expensive. Maybe $40 tops?
Old May 3, 2010 | 07:33 AM
Puppetmaster's Avatar
Any pictures? That would be helpful for others contemplating these headers or who are attempting the same install. Is it the angle or orientation of the y-pipe flange?
Old May 3, 2010 | 01:18 PM
to the OP wanting OBX headers lol
Old May 3, 2010 | 08:00 PM
junglee Z's Avatar
damn that is nuts! same story here! my custommaxima headers came in for my I35 after a month! first of all, custommaxima.com has HORRIBLE HORRIBLE customer service.. out of 20 or so emails, i only got 5 maybe 6 replies..
ok, so i took out the upper intake manifold, heat shields, crossmember, y-pipe and manifolds, etc all the pain in the a** work at my dads shop, np with that, knowing all that is annoying to take off.. put on the new manifolds, and the y-pipe is rubbing the edge of the oil pan and y pipe is NOT aligning.. anyway, i have no idea what to do to make it fit.. i could beat the y pipe a little to clear the oil pan but the y-pipe isn't properly aligning to the rear manifold and won't bolt up..
what a waste of $210.. i shouldve just hollowed out the pre-cats instead.. this sucks.. but i did install my new ES motor mounts while i was at it too..
Old May 3, 2010 | 08:02 PM
junglee Z's Avatar
my car is sitting on the lift at the shop, so i'll post some pictures up to show you'll the problem i'm having
Old May 3, 2010 | 09:28 PM
greenwood's Avatar
you did the same exact thing as me. i got the new motor mounts and honestly im more excited about the motor mounts than the headers. im pissed cuz my car is in pieces and i wanna drive the bish
Old May 3, 2010 | 09:30 PM
greenwood's Avatar
and your right about custom maxima's service. it is absolutely horrible. it takes days to get replies and they dont reply half the time nor can they do a simple thing like keep the customer informed on their orders. it was always a guessing game.
Old May 4, 2010 | 09:18 AM
nzelinsky's Avatar
oh man that sucks... I didnt even know CM had headers for our cars.... obx ftw I had no fitment issues except for cutting out part of the crossmember and motor mount bracket... which are known issues with the obx headers. It looks so close, I cant imagine there is no way you can force that into place.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
