ABS light
Old May 5, 2010 | 09:37 AM
HDB Audio's Avatar
ABS light
Hi everybody,
yesterday, I start my car and when I turn the ignition to ON, just after I heard the fuel pump, I heard a strange noise (like if a little motor is running for 2 or 3 second and then stop), and my ABS light turn ON after. Since yesterday, it wont go OFF. I check my brake, everythings ok, my brake fluid is ok... Hope that someone can help me.
Thx
Old May 5, 2010 | 09:47 AM
NmexMAX's Avatar
dot dot dot ...
One of your ABS sensor is dead.
Have the ABS codes checked.
Mine does the same thing because I busted a rear sensor when installing wheel spacers.
Old May 5, 2010 | 10:06 AM
fflint_18's Avatar
Ditto
and make sure you soak the sensor bolt with PB Blaster before trying to remove it.
I have read many stories of folks snapping that bolt off.
And no good comes from that.
Old May 5, 2010 | 03:27 PM
MAXIMA_STYLE's Avatar
i got no abs either....i broke both frons while changing my spindle because the bolt came out but the sensor itself was stuck so i pulled a lil harder and the sensor came apart in 3 pieces ....make sure you get it off the proper way otherwise youre gonna be swearing up a storm
Old May 5, 2010 | 03:30 PM
NmexMAX's Avatar
dot dot dot ...
They used to be ~ 130$ ..
Old May 6, 2010 | 04:33 AM
SilverMaxima3.5's Avatar
This is deffinitly a common problem. I reciently broke mine too. I called around everywhere because I'm not really in the mood to pay $100 from the dealer. And for 1 sensor too! Unfortunitly you can't get the damn thing inspected without the light being out.
Old May 6, 2010 | 04:31 PM
MintVQ35's Avatar
Snapped the bolt on mine as well, they fit pretty snug however without the bolt so it should be ok. I went to replace mine last year and snapped the bolt then noticed I was sent the wrong sensor (for the opposite side of the car) and ever since I've been running with the ABS light on, no biggie.
That is odd you mention you couldn't get it inspected with the light on, I had originally thought the same thing in Massachusetts but it turned out to not be required and I got it inspected no issue with it on.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxie40
Sep 14, 2015 11:28 AM
maximusrising
Sep 2, 2015 09:55 AM
