Car pulls weird on slicks... ?
On my 24.5 x 8.5 slicks the car is pulling on the track to the left. I had an alignment done everything looks good. I just am at a loss for understanding what could be causing the car to pull so hard to one side only at the track. On street tires given they are small 215/45, you can not feel any pull at all on the street. Track is far away and I can't just keep going there to find out that the car is acting weird. Anyone else ever experienced this issue? I am new to drag racing. Could my M&H tires be warped or something? I have brand new steel wheels 15s, if you swap the wheels from one side to the other the car still pulls to the left. I just don't get it.
I think you're correct. Easy to check. Pull onto some grass, (not yours), And hammer the throttle. Check the spin marks. Then do the same on dry pavement. I'll bet your limited slip is slipping.
Damn, still cant keep it straight huh?
http://forums.maxima.org/1-4-1-8-mil...nterested.html
PM aaron and see if there's a possibility that these will work for the 6 speed, or if there can be one manufactured for the 6 speed.
Perhaps you have exceeded the limits of the oem hlsd with that much hp.
I have a 01 the 3.0l engine with great tires and if I slam the gas my car pulls to the side like crazy.
I don't know about slicks, and (sadly) don't have HLSD on my 6MT, but I always thought torque steer in our cars pulled to the right, not the left.
Is that right, or does HLSD change the dynamics so much that it could be to either side?
Yeah, that would be a pretty awful choice for a DD
and yes, you get "torque steer" in a straight line
Certainly. Particluarly after the last few mods, and since I started running with Eagle F1's. But always pulling to the right. While I'm used to it, I imagine there would be a small learning curve for the uninitiated driving my 6MT at full throttle.
This. That's me. When I read the OP's comments about pulling to the left, it didn't compute. Thanks for the sanity check, Sooner.
I forgot this was a daily driver. My bad.
But anyways, you have to know when to draw the line between race car and daily driver, once you start to run into these situations, you might have to tell yourself...
"ok, this is the max the car can do in street legal form, let me leave it as is before I kill myself."
OR
"ok, this is the max it can do in this configuration, if I want more out of it, I need to get another daily driver and designate this as my track car."
I'm not saying he should do either one, but there is just only so much you can get out of a car before you have to make it into a real track car.
OR
Found that one of the bushings on the control arms is pretty beat up. I just ordered a new arm with bushings since they come packaged together. Should arrive sometime this week or next. Anyone know is nismo still makes that hard rubber bushings kit for the sentra?
Lakersallday24
03-20-2024 11:22 AM
Lakersallday24
06-16-2019 01:35 AM
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
Jcof88
08-03-2015 10:43 PM
