DASH LIGHT COMES ON EVERYTIME I HIT THE BRAKES
Old May 11, 2010 | 04:27 AM
cmd26's Avatar
I went to the carwash yesterday thats when I noticed the dashboard light. Its in the lower lefthand corner it looks like headlights with a slash between them, I only see it when I hit my brakes.
Old May 11, 2010 | 04:50 AM
auveeb's Avatar
I had a similar problem except I think it was the airbag light. I would check fuses to make sure that the ones associated with your tail light are not blown.
Old May 11, 2010 | 05:57 AM
03VQMAX's Avatar
That means one of your brake light bulbs is out.
Old May 11, 2010 | 06:15 AM
NmexMAX's Avatar
dot dot dot ...
Have someone press the brake while you go out back & check which light is out ( L or R).
Old May 11, 2010 | 07:17 AM
SoonerFan's Avatar
Cletus
<---- takes a deep breath
read your freaking owner's manual!
Old May 11, 2010 | 07:44 AM
cmd26's Avatar
ok, soonerfan i couldnt find my manual lol
Old May 11, 2010 | 07:53 AM
NmexMAX's Avatar
dot dot dot ...
http://www.courtesyparts.com/pdf/2003-Nissan-Maxima.pdf
Old May 11, 2010 | 08:04 AM
SoonerFan's Avatar
Cletus
sorry...im deployed...have extra time on my hands...so i slum in the 5th gen forum
Old Aug 12, 2014 | 08:44 PM
Tiggity618's Avatar
brakes
I'm having the sane issues with my 2003 Nissan Maxima, and no it's not a tail light out. My brake pedal are solft and my e brake is loose when I pull up. I've checked fluids and replaced brake pads, could a bad caliper cause these problems?
Old Aug 12, 2014 | 10:14 PM
Maxterror's Avatar
have you had this car for a while...changed your brake bulbs recently? If you did then you could possibly put in a bulb that the car thinks is weak and thats why you get that dash light.
my brake lights are brand new LED bulbs and my "bulb out" light comes on when i touch the brakes..basically the car thinks theres nothing there
Old Aug 13, 2014 | 08:56 AM
DennisMik's Avatar
You need to have 2 things done.
You need to bleed the brakes at all 4 wheels, following the proper sequence because of the ABS system. If the pedal is still soft, the master cylinder is bad.
The parking brake needs to be adjusted, but first check that the brake pads are not worn out.
Matt93SE
May 24, 2019 02:58 PM
AnsonJ
Jun 2, 2017 01:35 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
homeyclaus
Sep 3, 2015 06:15 PM
