starting warm car issue.
Old Dec 10, 2001 | 08:17 PM
Greek to the Max's Avatar
Last year I posted a problem with my 2001 maxima se 5spd. I was mentioning that when I started my car when it was warm, it wouldnt turn over on the first turn of the key. This was a common problem, and apparently dissapeared after 5000km on the vehicle. So the car now has 23,000km and it occassionaly does it. To top it, it now begins to idle low and makes some knocking sounds from the back, which is probably the exhaust....That began after I got my 24,000 maintenace checkup last week.
Has anyone experienced anything like this?
Thanks,
Paul.
Old Dec 10, 2001 | 09:29 PM
BigDogJonx's Avatar
Man the other day, just 2days ago, my car required 5 cranks, the last crank required me to hold it about 5second and then it fired. I just moved to mobil 1 oil like 2 weeks ago on top of that.
Old Dec 10, 2001 | 09:35 PM
Maximum Velocity's Avatar
It has been a common problem. I went to the dealership one day for something and I noticed there were a lot of maxes in the service lane. And the service guys were literally pushing one into the garage area, so I asked the owner of the dealership how come there were so many maxes and what was going on. He said that there was a starting problem with the car and the car wouldn't start. They don't know what was going wrong. Even I have this intermitent problem sometimes. While not often, it seems to happen to my mom more than it happens to me (knock on wood). I have 10,600 miles on my car.
Old Dec 11, 2001 | 05:10 AM
dave's Avatar
i haven't noticed a starting problem at all in mine. ~15,000 miles
Old Dec 11, 2001 | 05:41 AM
Y2KMaxGXE-R's Avatar
one time past summer I left the car overnight for service, and it started from the 2nd time, but otherwise, knock on wood, no probs.
Old Dec 11, 2001 | 07:34 AM
greg2001's Avatar
I'm having the same problem with my 2001. ~18,000 miles. It has done this about 6 or 7 times since new.
Old Dec 11, 2001 | 09:02 AM
MaxRPM's Avatar
My friend had a 2K TL and after idling for a long period of time then turnin off then the engine then starting it again the car stall.
The Acura dealer said it was the gas boiling and screwing the EGR valve (I can't remembr the details) and they couldn't fix it so they just set the fan to stay on longer. Also after taking apart his dash, his dash lighting would flicker on and off.
After someone ran a redlight and wrote off his TL he bought a 01 Accord V6. after a year and a hlf he is now having the same problem. He just got a letter from Honda stating the problem and all they said was they would extend his warranty to 8 years.
So the problem appears to be (with Honda/Acura atleast) is that the Gas companies put additives in the fuel for winter. But when you arrive upon a warm day (it's 8C in Toronto right now) in the "winter gas" season you get this so called boiling of the gas issue.
Oh well I haven't had a problem with my 02Max and hopefully I won't.
Old Dec 11, 2001 | 09:17 AM
Draco's Avatar
Re: starting warm car issue.
Thanks,
Paul.
Yup, I can relate. I have a 2001 AE, just turned 6000 and it's done this about a half dozen times. I didn't think much of it cause it's only happened a handful of times, I hope it's not the start of a more serious issue.
I always use Mobil Premium gas, and Mobil 1 Oil.
Old Dec 11, 2001 | 09:16 PM
Max2000's Avatar
I think I have an oppsite problem... move from a warm weather to an cold weather area... 5 speed, 32,000 miles, when it's really cold outside, when the car successfully turn on, it has this short sqeeke noise(less then half a sec)... anyone have this problem when it's cold? I have been using mobil 1 oil also..
Old Dec 11, 2001 | 09:43 PM
TimW's Avatar
The silent but deadly Moderator
hmmmm...
squeak or chirp? auto? cold? engine mount
Old Dec 11, 2001 | 09:52 PM
BigDogJonx's Avatar
Re: hmmmm...
Timmeh, you always intrigue me,
What you mean by engine mount? I had to crank my bastard a 5 times last week, and the 5th time required a crank of over 5second to get that bastard started. I mean I got Mobile 1 oil too.
I got no idea what went wrong from that night to the next night.
Dixit
Old Dec 12, 2001 | 08:46 AM
aes1519
My problem seems similar to Max2000's... My 01 SE with 7500 miles wouldn't start on Monday morning. After towing to the dealer, who was finally able to look at it this morning, it started fine for them. Sunday night was the first cold night we've had, but the car was in the garage all night. Lights, radio, etc. went on, but it just wouldn't turn over -- made a smooth whining sound. Is this what has happened to others or something different?
Old Dec 12, 2001 | 04:26 PM
well guys I can think of a couple of different things that have gone bad on the car. When I do drive when it is cold the car, it revs very hard, as if it were reving at a higher rpm. Very sensitive. The gears dont care how cold it is, but the engine is very sensitive this year, unlike last. Aslo, I didnt drive the car for 4 days, and when i went to start it, the engine shook for about 2 seconds....Felt like a earthquake. Plus my shaking when the car does start when it is warm.....
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
mrgooch
Aug 9, 2015 11:00 AM
kirkhilles
Aug 8, 2015 10:53 AM
