Can i borrow a stock catalytic Converter
Old 05-21-2010 | 07:07 PM
tbergma1's Avatar
Currently i have a CC from warpspeed it s magna flow hi flow CC. My #'s on the smog are twice the legal limit. The CC does not work good enough. The smog guy said to put the stock one back on.
I do not have one, is there anyone close to temecula Ca, that i can borrow for the test.
I have cattman headers, so that means no pre-cats. Does anyone think that the stock CC will work good enough to past the test?
Old 05-21-2010 | 07:15 PM
With the stock CC you should pass. GL.
Old 05-21-2010 | 07:38 PM
tbergma1's Avatar
I tried to purchase a CC from kragen and said there not available. Will a CC from a 97 max work?
Old 05-21-2010 | 10:54 PM
I doubt it but .
Old 05-22-2010 | 12:21 AM
Sam o nela's Avatar
You can get one on Feebay for pretty cheap:
http://shop.ebay.com/?_from=R40&_trk...All-Categories
My Legend had a high flow cat that would put out high numbers also, but you litterally had to get it very hot by revving it for 30 seconds or so just before the test started...then it would work right...
Old 05-22-2010 | 01:40 AM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/west-coast-13/
Old 05-22-2010 | 04:35 AM
HotshotVQ35's Avatar
cali emissions FTMFL...here in ny, as long as there is on ses, car passes..good luck
Old 05-22-2010 | 04:40 AM
Nismo215's Avatar
^^^haha i like how they do things in NY
Old 05-23-2010 | 11:05 PM
tbergma1's Avatar
Bump, anyone? I need to borrow a stock catalytic converter for my test, i will bring it back to you when i'm done. PleeeeeZ
Old 05-24-2010 | 02:09 AM
Gemner's Avatar
i might need to do this too. I bought a new cat, not even a high flow one, but I didnt pass. Running rich from headers FTMFL. Maybe if you get the cat so hot its almost on fire it will pass. Thats my plan
Old 05-24-2010 | 06:32 AM
TallTom's Avatar
http://forums.maxima.org/5th-generat...many-part.html
Old 05-24-2010 | 07:06 AM
NmexMAX's Avatar
dot dot dot ...
So you didn't pass because your too rich? I didn't know that was criteria for failure.
Old 05-24-2010 | 03:17 PM
Gemner's Avatar
high HC, relatively high but passing CO and extremely low NOx = rich
Old 05-24-2010 | 03:26 PM
NmexMAX's Avatar
dot dot dot ...
Makes me think your car wasn't @ operating temp, i.e. closed loop still (coolant below threshold for open loop crossover, less than ~70ºC, IIRC)
Old 05-24-2010 | 04:11 PM
Gemner's Avatar
yes, I dont think it was warm enough. that plus having 5 miles on a new cat I think were large contributing factors. unfortunately, now I have a short somewhere on my harness that takes out the vias and a few other things, throwing a code, so I wont be able to find out if warm/hot cat will work any time soon
Old 05-24-2010 | 05:17 PM
MAXIMA_STYLE's Avatar
damn im glad i live in ct, like ny as long as no ses light is on we pass lol
Old 05-24-2010 | 06:52 PM
Gemner's Avatar
thats just dumb. you could take the SES bulb out and pass?
Old 05-25-2010 | 05:29 AM
mist max2000's Avatar
they hook up a special scan tool... lol ...
Old 05-25-2010 | 06:11 AM
TallTom's Avatar
They plug in an OBDII scanner for the test. PA is the same way.
Old 05-25-2010 | 11:17 AM
machinehead131's Avatar
Not usually, to my knowledge they use a hook up the scanner to the OBD port and scan for codes.
Old 05-25-2010 | 04:09 PM
kbohip's Avatar
Here in Colorado Springs they stopped doing all emissions tests for all cars except diesels many years ago. It's really nice not having to worry about that nonsense anymore.
Old 05-25-2010 | 04:27 PM
NmexMAX's Avatar
dot dot dot ...
There are no tests here either ...
Old 05-25-2010 | 10:02 PM
Scottwax's Avatar
That's Mr. Detail to you
You can have mine if you pay shipping. The main cat isn't monitored by the ECU and here in Texas they only check for codes. What is weird is the only thing they physically check is the gas cap.
aw11power
10-10-2021 05:57 AM
04-16-2020 06:15 AM
09maxshawn11
09-30-2015 11:28 AM
sliptap
09-30-2015 06:57 AM
jaydot901
09-29-2015 02:18 PM
