Concerned 5.5gen Owner
So I've been hearing a rattling type noise from my car for like the past few months. It only happens between 1.5k-3k RPMs. So i go pick up my little brothers s13 convertible and he decides to drive my car since his car has no a/c. While driving next to him i realized that the noise is much louder than i originally thought. It sounds sorta like a valve chatter. Now ive done plenty of reading on the forums and dont think i have found the cause for my problem. It doesnt do the noise if there isnt any load so i cant just accelerate while in park and hear it. And seem to respond differently every day. Its either quick and has some spunk or it feels flat. Also the car has 160k and the car has been in the family since roughly 90k. Any thoughts? Pre-cats? Timing chain? Valves? replace motor?
Oil was changed not to long ago and the level is fine. It only rattles if the car sits for like a few days on startup. Only Mod i have at the moment is the block off plate and its been doing it way before i put the plate on. The noise only happens when im at maybe 20% load between 1.5k-2.5k. Would the cats also explain the sporadic loss of power? And somewhat crappy gas mileage reading at about 19.5mpg on the cluster. And the pre-cats have never been changed. Now should i spend 500-600 on new precats or save an extra few hundreds and order some cattman headers?
These engines like to knock even if you're running 91 or 94 octane in that rpm range, especially in humid weather. If the car runs fine at other times, just let it be. Not ideal, but most likely everything else is okay.
Got the same problem at low speeds but when I step on it goes away but crusing and push on the gas a little you hear it mainly like 20 to 50mph!! But dont know where its coming from?
So what i am getting is that its either the pre-cats or the chain hitting the timing cover due to low oil. If it were oil would an additive like Lucas help? Also where is the cheapest place to order some pre-cats?
an additive will not help...its bad rings...i tried everything and it didnt help
Had the same issue.... Added oil mentioned above and the noise faded away. I have read that 5.5 Gen Maximas do indeed burn up oil in some thread here! It might be an easy fix like ours!!!!???!!!???
not a big fan of Lucas i dont find that it helps. what oil and weight do you use? a lot of us live by amsoil products
Yes, I have this particular issue also, it only happens when i let off the gas, when under load it does not make the noise, say i rev to 3k in neutral, as rpms drop the rattle occurs. My oil level is not low either. Running 5qts of Eneos 5w-40. I'm hoping its the precats or catalitic converter! Noise can also be heard when in 1st gear engine braking(basically same as revving and letting rpms drop)
i had a similar rattle n could not figure it out till i bought a catback system and went to remove the old exahaust i was surprised that my muffler was not even connected to the car the pipes were all in tact from a quick glance but where the pipe loops over the back cross bar n connects, onto the rest of the exahaust was rusted out n was just looming over the conncetion spot. it was a simple replace once all disconnected.
hope this helps.
hope this helps.
all discussed in depth in my 10 page thread
i think the low oil explanation is right on the money...i just purchased my 5.5 gen and right away i noticed the rattling in that rpm range..did an oil change over the weekend and the rattling stopped after about 2 blocks from the mechanic
knight_yyz
Nov 1, 2015 01:34 PM
has only 43K
