Front brake overhaul
Old Jul 4, 2010 | 07:22 PM
ColtMax's Avatar
As promised!
Ill put the instructios tomorrow.
Old Jul 4, 2010 | 07:26 PM
ColtMax's Avatar
Old Jul 4, 2010 | 07:38 PM
Feldman's Avatar
Nice! how much did the rebuild kit run you?
Old Jul 4, 2010 | 07:39 PM
The6spdMax's Avatar
Wow, great detail pictures.
Old Jul 4, 2010 | 07:50 PM
BENMAX03's Avatar
What are you doing to the spindle? Cleaning it up?
Old Jul 4, 2010 | 10:12 PM
Gaijin's Avatar
GREAT PICS! You almost don't need instructions with those!
If you don't have access to an air chuck/air compressor, what would you recommend for getting the pistons out?
(Should be stickied when you get done, too.)
Old Jul 5, 2010 | 03:59 AM
ColtMax's Avatar
If you dont have a compressor, you could try by pumping brakes until the piston is released. But this will be messy and you will be able to do only one side.
A lot easier with the compressor. Be very carefull when applying pressure, the piston will shoot as a bullet if you go to hard on the air nozzle. Make sure to put a wood piece to protect and retain the piston. Watch your fingers!
I could not find another way to get the new boot on the piston, the compressor is a must for this rebuild I would say.
Price for the rebuild kit from nissan is 57 CND, so I guess you could get it for 40 ish in the states.
For those who are wondering what am I doing with the spindle assy on the bench, it is beacause I am rebuilding the entire suspension and swapping to ES bushings.
Old Jul 5, 2010 | 05:47 AM
foxy curls's Avatar
Well done!
Are you planning to swap to 6th gen BBK in the future? I've done the swap (I own a 5th gen) to 6th gen brakes and it's day and night!
Keep up the good work!
Old Jul 5, 2010 | 06:27 AM
ColtMax's Avatar
Originally Posted by foxy curls
Well done!
Well actually, I will keep this brake setup for a while. When maintain in excellent shape, it brakes as new and it is sufficient for my daily driving.
Old Jul 5, 2010 | 09:57 AM
rj6031570's Avatar
Front Suspension mods
Like your front suspension bushing mods. Do you have it installed yet to describe if it changes the ride quality (to harsh with these bushings vs rubber bushings?).
Thx
Old Jul 5, 2010 | 10:28 AM
ColtMax's Avatar
Thx
Actually i am waiting for a few parts before getting her back together.
- Tokico Illumina
- Half shaft support bracket
And I am also considering dropping the subframe to do a bit of clean up and maintenance.
HOKUSMAX
Nov 13, 2017 04:34 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
