Problem while installing NWP Spacers
So I'm new to opening the IM. So I started unbolting the UIM. While I was there I wanted to change my spark plugs. So I opened all of them and last one on top right side I pull that coil out. Soon as I did I see oil dripping out of it. So I cleaned it out. Spark plug was covered all in oil. So I took it out cleaned the coil and put the spark plug and bolted it. I was doing the spacers install. So I after I got everything bolted up and ready to start. I crank my car and smoke started coming out of my exhaust. Now at that point I thought that it was that oil I saw from the coil that drop in the engine might be burning off. So smoke stop after awhile and I go press the gas pedal to rev it up. It hesitated when I press the gas pedal. It's like it's almost dying before it revs up. But, It stays idle good. What's the problem??
your rear valve cover is cracked. So oil will keep building up in that pocket.
Check all your connections, I've done this install 5 times and there are lot's of connections you can forget. Did the SES light come on? Double check you plugged in the MAF sensor correctly. Check all the hoses. SOunds like you forgot one and may have a vacuum leak.
Yeah there is one hose that got tore up by me trying to take the damn hose out. I got the clamp over it where it got tore up now it don't hesitate so much like it use to. My a/f ratio is jacked up. It use to read 14.5 - 14.9 at idle. Now its like 15.7 - 16.9. I've messed with vafc to get it back in between 14.5 - 14.9. There is only hesitation around 750rpm-850rpm. After those rpm range pass car is powerful.
Yeah I thought about the valve cover cover is cracked. I order the part but it was in back order so I'm going to dig up on it again soon as I get it back. Since I took it apart this time now it's easy for me to do it again.
Sup kevlo long time I heard anything from you.
I probably just get a different hose from like hardware store and use that. It's the hose that connect to the elbow right underneath the Throttle body.
Yea if it's at the tb then thats the prob. Don't make any afc corrections at idle, no point. Fix the vac leak first.
Yeah I get it done today. Yeah I'll come down. How long you going to be in town? I ain't been in DeFuniak for long time. I probably try to make it next week. I want to check your car out.
All summer. Till late aug. Im in gville this week so just lemme know when you come next week .
This might be a stupid question but, did you use RTV on the spacers? I think there was another .org'er that installed them without the RTV and had problems.
Also, did you email Aaron? He seems to be an upfront guy and more than willing to help.
BTW did you do the TB and idle relearn after the swap? How dirty was your TB?
After my install I had just enough vacuum going through the TB to make the throttle plate stick. After a liberal spraying with seafoam deep creep with someone holding the throttle open (Car off of course) took care of that problem. If you do this restart the car at night, it'll get a little smoky for a bit.
As for the oil going into the engine due to the VC leaking, Yea don't worry about it, it'll burn off.
That would be me, however that wasn't NEARLY what my problem was. I had a HUGEEEE leak, because I misread and forgot to take the bracket off the rear..... Gl op. Just check for connections if you're 100% you did the instal correctly. There are tons of sensors and hoses that look to be in place but actually aren't.
I use the RTV Gasket Maker just like what it said on paper. So I fixed the pipe that was broken by me while doing this install. But there is still something wrong with my car. I dunno what it is. Bad a/f ratio too lean. Performance wise it was good on highway. I hear air sucking in back of UIM (HSSSSSSSSSSSS). All the pipe is connected like they were supposed to be. I don't know what else could it be?
If this does boil down to a vacuum leak you can use ether or an unlit propane/butane torch to find the leak.
Just make sure you do that in an open outdoor area. Trust me being in the center of an explosion is not fun.
One of the things these spacers do is increase the velocity and in turn volume of air that enters the engine so yea the idle volume reset is a good idea.
At least that is the way I'm going to do it.
What do you mean what bracket? Is the bracket you talking about is the one that holds the UIM from firewall? Because I took those two bolts out to remove the UIM. Do I need to completely remove the bracket?
You should, the spacers will make it not line up anymore and possibility screw up the fit of your intake elbow.
Maxboy23
Aug 11, 2015 11:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
