What do you do to make your engine look pretty? :)
Old Aug 14, 2010 | 04:05 PM
  #241
Rochester's Avatar
Originally Posted by knight_yyz
throttle body harness and I think IACV harness.
No, not the TB. I'm asking about the sensor that's bolted to the UIM near the TB. There's a 1/2" vacuum line going in from the VC (I think) and out to the UIM. Now, I know I need to get schooled on the IACV, but all the relevant threads are discussion the 5.0 gen, not the 5.5. And then there's this:
Originally Posted by P. Samson
The VQ35 is fly by wire and has no IACV.
So what is that thing?
Old Aug 14, 2010 | 04:36 PM
  #242
knight_yyz's Avatar
Toolie
it's another evap sensor. You can hook up some sort of diagnostic tool to the port under the green cap
Old Aug 14, 2010 | 11:18 PM
  #243
rroderiques77's Avatar
Demodded and Forgotten
The green cap is an evap port in case one wants to smoke the system for leaks.
Old Aug 14, 2010 | 11:58 PM
  #244
whiteSE's Avatar
keep it clean. scrub away the dirt.
i need to work on mine
Old Aug 15, 2010 | 05:40 AM
  #245
Rochester's Avatar
Thank you, Roy. Page EC-37 in the Field Service Manual.
It's the "Evap Canister Purge Volume Control Solenoid Valve".
I was just wondering... this would look a lot better if it were relocated under the engine cover.
"The evaporative emission system is used to reduce hydrocarbons emitted into the atmosphere from the fuel system.
This reduction of hydrocarbons is accomplished by activated charcoals in the EVAP canister. The fuel vapor in the sealed fuel tank is led into the EVAP canister which contains activated carbon and the vapor is stored there when the engine is not operating or when refueling to the fuel tank. The vapor in the EVAP canister is purged by the air through the purge line to the intake manifold when the engine is operating.
EVAP canister purge volume control solenoid valve is controlled by ECM. When the engine operates, the flow rate of vapor controlled by EVAP canister purge volume control solenoid valve is proportionally regulated as the air flow increases. EVAP canister purge volume control solenoid valve also shuts off the vapor purge line during decelerating and idling."
Old Aug 15, 2010 | 11:49 AM
  #246
CMax03's Avatar
Upgrading to hardpipes would look better and decrease your boost lag....
Old Aug 15, 2010 | 01:46 PM
  #247
Rochester's Avatar
You know something, 5.5 Gen owners... take that engine cover off, and there are like 2 dozen rusty old bolts all over the engine which could be swapped out for something new and stainless steel. The left valve cover bolts, for example. And a whole bunch of retainer brackets bolted here and there.
An idea which takes this engine bay make-over one step further.
Step 1: Open the hood, look at the bling.
Step 2: Remove the engine cover, look a the bling.
Step 3: Profit.
Old Aug 15, 2010 | 01:48 PM
  #248
Rochester's Avatar
It does look better. Check it out:
http://forums.maxima.org/5th-generat...yone-done.html
Old Aug 16, 2010 | 09:59 AM
  #249
Rochester's Avatar
Any of you guys ever replace your Negative Battery Cable with something new and clean? It looks like a rotting old garden snake strapped to the tranny.
YIKES! I just looked it up: the OEM negative battery cable is almost $50!
In fact, the more I look at my engine bay (been doing a lot of that lately no ish) the more I'm observing how the various ground connections to the frame are corroded. Hmm. I should probably unbolt them, sand them down, and bolt them back up again. Yes?
And what about the dozen or so wiring harness connectors? I can't even begin to name them all, but they're all dirty, with 8 years of grime deep into the nooks & crannys and individual wire inlets.
How do you clean those? I'm guessing you disconnect the battery first, and let the car sit for a day so the connectors dry before firing things back up. But again, how do you clean all those things?
Old Aug 16, 2010 | 10:16 AM
  #250
doublea's Avatar
It may sound weird, but while re-assembling my car ( a 2K1 max ) I cleaned all the connectors/socket with some WD40 and a tooth brush, it work like a charm and restore them like they are brand new. Off course that wont get rid of the rust on metal connection (that's another story ) but I also cleaned many rubber hoses with the WD40 and it remove all the dirt and make them shine and look like brand new.
There might be a specific product, but on a late night ( store were closed ) I just picked up a can of WD40 laying around in the garage and find out it does a pretty good job.
Sorry I forgot: As for the ground, I simply use a dremmel with a metal brush and get rid of the rust fairly quick. Good luck.
My 2 cents
Old Aug 16, 2010 | 10:25 AM
  #251
Rochester's Avatar
WD40? But that's a lubricant. IDK, man... that seems not right to me for some reason.
What about using MAF cleaner on wiring connectors? And then blow them out with a can of compressed air? (I have a can of both that I could try out.) That seems like a harmless idea.
Old Aug 16, 2010 | 10:32 AM
  #252
doublea's Avatar
Trust me it work really well with the WD40 and I never experienced a hose or a connector degrading because the product is too strong. If you dont believe me just simply try it on a radiator hose and you'll gimme news. I'll try to post some pics later tonight.
Old Aug 16, 2010 | 01:30 PM
  #253
knight_yyz's Avatar
Toolie
rochester, look for an electrical contact cleaner, It will come with the little red pipette to get into all the small places. And it evaporates very quickly. We use LPS electrical contact cleaner at work all the time. It gets rid of water too like wd-40 but doesn't leave an oily residue
Old Aug 16, 2010 | 01:33 PM
  #254
Rochester's Avatar
Isn't MAF cleaner that same thing?
Old Aug 16, 2010 | 02:00 PM
  #255
Akilldema's Avatar
I'd like to see some more VQ30 pics
Old Aug 16, 2010 | 02:44 PM
  #256
I use WD40 to clean stains off carpets as well. Works like a charm.
Old Aug 16, 2010 | 02:59 PM
  #257
Who makes that battery tie-down? Never saw it before.
What's that on your upper radiator hose? Some kind of mesh? Let's see a better picture.
The red V6 3.5 is kind of cool.
A 4 megabyte sig photo... not so much.
Here you go...
http://forums.maxima.org/general-max...-tie-down.html
Old Aug 16, 2010 | 03:04 PM
  #258
Rochester's Avatar
Nobody is stopping you, champ. Go right ahead.
Old Aug 16, 2010 | 03:05 PM
  #259
knight_yyz's Avatar
Toolie
I'm not sure, I know the maf is a "hot wire" so it is probably very close. So i think it is ok to use on other electrical stuff as well. But I prefer to save the maf cleaner for the maf.
Old Aug 16, 2010 | 03:07 PM
  #260
Rochester's Avatar
That's what I was thinking, that MAF cleaner *is* electrical connector cleaner, just specialized. I've got this spray can of MAF cleaner banging around somewhere, and since my MAF is brand new, and I use a dry filter... thought I'd put it to good use.
I'll try it on something later tonight.
Old Aug 16, 2010 | 03:42 PM
  #261
spock's Avatar
How about a new ground wire kit from the member here? You can even get them in red. IIRC, it's only $55 or so.
Old Aug 16, 2010 | 03:57 PM
  #262
knight_yyz's Avatar
Toolie
the g35 guys and the 350z guys have access to chrome/aluminum anodized caps for the power steering, windshield washer and brake cylinder reservoirs. Too bad the company doesn't seem to make them anymore.
I'd post a pic but my internet security program won't let me log on to g35 forum
Old Aug 16, 2010 | 05:59 PM
  #263
Rochester's Avatar
There are simple spring-clamps on most of the little hoses... I wonder how they would hold up if they were painted? Should probably buy some new ones, and paint them with high-temp satin black. That's another idea which has been rattling around my head, looking at the engine bay.
You're right about WD40 on rubber hoses. It cleans them up with a nice, uniform black look. The result isn't so much a glossy shine, rather it's a satin black. Very subtle to the touch. I like it. Nice idea, WD40. I need to play with this some more.
MAF cleaner didn't work so well. I need to get some Electrical Contact cleaner and a few large toothbrushes.
Old Aug 16, 2010 | 06:29 PM
  #264
spock's Avatar
Contact cleaner likely won't work so well either, as it evapourates so quickly. Try the Wd-40 - spray it, scrub it, and wipe it away. Then, if you want to ensure good contact, go at the area again with contact cleaner and wipe away quickly. Reattach connection and give a light spray of WD or even better a rust inhibitor such as rust check. (Not sure if Rust Check is available in the States).
Old Aug 16, 2010 | 06:50 PM
  #265
jowo9's Avatar
K but here's my question/concern with WD40. Is it gonna attract dust if you clean hoses etc with it?
Old Aug 16, 2010 | 07:26 PM
  #266
Specd_out's Avatar
The best thing to use for detailing your bay, is to use vinyl protectant. Its give a nice muted shine dosent attract dirt, and it protects the hoses and rubber items in the car.
Here is a detailing how to i wrote on my sentra site. I sponsor the detailing section and there are a few helpful how to's on there. I hope this help some of you guys.
http://www.thespecvboard.com/vb/vbul...ead.php?t=6441
Old Aug 16, 2010 | 10:28 PM
  #267
knight_yyz's Avatar
Toolie
Paint the clips with por 15 rust paint. Its flexible wont chip or peel
Old Aug 16, 2010 | 11:38 PM
  #268
jowo9's Avatar
Hey, I just had an idea! I use "303 Aerospace Protectant" on my dashboard etc. I absolutely love the matte finish it gives compared to other protectant cleaners, and it holds up really well. I'm gonna try it on the various parts of my engine bay. I bet it'll work really well. Just a heads up to anyone who hasn't used 303 before. TRY IT! It's amazing... especially if you hate that shiny "Armor-All" finish on your dash. 303 brings out the black (or whatever color your dash is) and looks really great. (there's my product promotion for the day )
Old Aug 17, 2010 | 05:08 AM
  #269
Rochester's Avatar
Thank you, sir. Good advice.
Um, doesn't seem to come in a spray can, however.
Old Aug 17, 2010 | 03:41 PM
  #270
knight_yyz's Avatar
Toolie
no it does not. you will need a very tiny brush or an air brush.
Old Aug 17, 2010 | 03:50 PM
  #271
Rochester's Avatar
Ever use Stove Bright paints? I picked up a can at the Fireplace Store this evening on the way home from work. The paint quality is outstanding, and very even. No sputters or runny paint.
Bought a can of "Metalic Charcoal" to paint the spring clamps, and to repaint my FSTB brackets, so they all match my radiator retainers.
I'll post up a picture when they're done.
[edit]
This paint is too flat. Spring clamps look much better painted, but I think I want something metalic glossy. I'm going to hold off on painting the FSTB brackets until I find a paint I like.
Old Aug 17, 2010 | 11:16 PM
  #272
knight_yyz's Avatar
Toolie
Mine just came back from sand blasting
Old Aug 18, 2010 | 05:25 AM
  #273
Rochester's Avatar
What just came back? What were you having done?
I realized this morning that I must have done my little spray painting projects too near to the car over the last few days. There's a rough feel to the paint, which can only be overspray drifting down on to the car. This is very distressing, particularly considering how nicely maintained I've been keeping the painted surfaces.
Wax and cleaners don't seem to do a damn thing. I think I need to break out the old orbital buffer.
Kind of unhappy right now. Look away while I cry...
Old Aug 18, 2010 | 06:21 AM
  #274
tdabboud's Avatar
^ You could try to clay bar it, i had the same thing happen, i cant remember if it got it all off but worth a try i guess ha
Old Aug 18, 2010 | 06:47 AM
  #275
Rochester's Avatar
Thanks, tdabboud. I've never used clay before, but it seems pretty straight-forward, and exactly what I need to do to fix this problem. I'm pretty sure I brought this on myself, not spray painting far away enough from the car. I feel like such an idiot.
So now I've got another (unplanned) car project to tackle. Oh well... there are worse hobbies.
Old Aug 18, 2010 | 01:37 PM
  #276
knight_yyz's Avatar
Toolie
I sent my strut mounts out for sandblasting, and i plan to paint them with por 15, then I will do the rad mounts and a few other pieces. Also ordered the front two water pipes that sit in front of the engine. They will be painted with por 15 as well. And the 2 oil cooler lines
Old Aug 18, 2010 | 03:55 PM
  #277
MaximusTi's Avatar
You've already got it figured out John. Give it a Clay and you'll be good as new.
The good thing is, its not difficult and you are already a detail oriented kind of guy so you might even enjoy it !
Old Aug 18, 2010 | 04:31 PM
  #278
knight_yyz's Avatar
Toolie
Hey John, I recommend Meguiars professional clay. They have a mild and a medium. Comes in a plastic tub. Grab an empty spray bottle and put a teaspoon of dawn and fill it with water to use as your lubricant
Old Aug 18, 2010 | 04:47 PM
  #279
Rochester's Avatar
I bought some Meguiars clay and did the hood and roof just now, then over that with Meguiars Tech Wax 2.0, and...
OMG! OMG! OMG!
C L A Y B A R !
How did I ever get to this point in my life and not know how to use this?
That is all.
Old Aug 18, 2010 | 05:33 PM
  #280
tdabboud's Avatar
OMG! OMG! OMG!
C L A Y B A R !
That is all.
Ha thats great man! I am glad it worked out for you Clay bar is a magical thing, it really smooths out the paint and a lot of imperfections
