big maf tuning
Old Aug 17, 2010 | 01:51 PM
  #161
tedo007's Avatar
faster than you think
Got the AEM UEGO for 170 shipped brand new on ebay.
Old Aug 17, 2010 | 02:10 PM
  #162
cjandura's Avatar
not doing this mod just learning.Here is a link to a place where i just got hoses for my '09 i noticed they have upto 8" dia and connectors for those of you looking for larger intake tubing and adapters.
http://www.hiprospeed.com/
Old Aug 17, 2010 | 02:38 PM
  #163
McSteve's Avatar
Once upon a time people said catbacks don't do anything at all for our car. Then came the dyno proven results of Cattman's 3" system.
Now we see the increase of performance with the BBMAF, after I read up a little people said boring out the TB's wouldn't make any difference as well, so shouldn't all three mods in conjunction = basically pure awesomeness and super WHP?
Old Aug 17, 2010 | 02:49 PM
  #164
Grand_hustle17's Avatar
I remember those days..... but ur about right with all of the above it should be like sex
Old Aug 18, 2010 | 06:18 AM
  #165
NmexMAX's Avatar
dot dot dot ...
Instead of 'boring it out' (TB), maybe we should fine a compatible unit that's larger, say from a Mustang or something.
Old Aug 18, 2010 | 09:23 AM
  #166
McSteve's Avatar
Would finding a compatible TB be easier for Drive-by wire or Drive by cable applications?
Old Aug 18, 2010 | 10:03 AM
  #167
tedo007's Avatar
This looks interesting.
Old Aug 18, 2010 | 10:08 AM
  #168
essential1's Avatar
My axles cry for mercy...
5.5gen+ guys will have the most trouble finding an application. I know SGmotorsports used a 90mm chevy TB for their 350z with custom IM, but that car is far from stock as far as electronics go.
Us 5th gens and our 4th gen couterparts have it way easier. The mustang TB has already been done. The hardest part for us is finding a way to mount the TB to the intake manifold...
Old Aug 18, 2010 | 11:25 AM
  #169
NmexMAX's Avatar
dot dot dot ...
Originally Posted by tedo007
TBW Mustang units seem to be almost a direct fit.
Old Aug 18, 2010 | 11:49 AM
  #170
McSteve's Avatar
$300 for a tb O_0! However 70mm is a lot more than I could do with a drill press probably. That's like .8cm bigger than our OD isn't it?
EDIT: ohhh stock replacement tho... soooo a junkyard spare one + some machining time = big@$$ TB yeeees?
EDIT 2: Ahhh yes car-parts.com has some for $75.... sounds A LOT better!
Old Aug 21, 2010 | 09:02 PM
  #171
rayac88's Avatar
track should be happening on thursday, the only difference is i have a34 Nismo wheels now so i got more weight so my times may drop. for the record the setup isnt as light as people make it seem. total of 48 lbs with re40a tires. still running this crappy air filter though . money is getting tighter
Old Aug 23, 2010 | 06:29 AM
  #172
NmexMAX's Avatar
dot dot dot ...
That's horrible. 19" diameter wont help either.
My MMEV5's were 52#'s w/tire in 18" trim,
Old Aug 23, 2010 | 07:31 AM
  #173
love those A34 nismo's loose at least the 2 fronts
Old Aug 28, 2010 | 05:27 PM
  #174
rayac88's Avatar
no luck on the 1/4 mile details. the track was flooded out so no results with that.
Old Nov 8, 2010 | 10:36 PM
  #175
rayac88's Avatar
time to reopen this thread i still have some questions.
i ran a 15.8 on my 1/4, 10.3 on 1/8, 2.5 60ft... does anyone have stock 3.0 at times i can compare to?
w/ the 3.5" intake aem dryflow i feel like its taking my torque away. i have my narr lvt tuned @+39 idle then taper down to from 20 to about 8 after 1800rpm til hvt switchover. my a/f reads avg 0f 13.4 up top n 14.7 til oovi kicks in.
my pressure reading says its about 5psi until the engine hits 4500k ad shoots up to 9psi, thats WOT. i set my intake pressure scale to 0%. whats is everyone else reading out?
any advice on gaining better speed down low?
i ran w/ 17x8 41lbs total wheel weight in front and a34 nismos in back
Old Nov 9, 2010 | 12:20 AM
  #176
MoncefA33's Avatar
Get your 60 foots down, try dropping the tire pressure.
Your AFR is too lean, shoot for 12.9-13.1. What's your AFR like at idle? Is it consistent? How about part throttle and cruising?
Those A34s are light for their size, actually. Track-wise, if you wanna get off the line faster, you can run smaller wheels up front (16" or 15") and as long as you can make it stick you'll be quicker down low.
Old Nov 9, 2010 | 04:09 AM
  #177
I don't have a lot of details on times but my auto 5th gen ran a 15.0@93 with an ebay cold air intake and greddy evo 2 exhaust... that's all I had, I've been to the track maybe 3 times with that car, never went as low as 15.8 though
Old Nov 9, 2010 | 12:21 PM
  #178
rayac88's Avatar
my a/f is 14.4 - 15.2 on idle w/ the bbmaf cruising 14.7 and 13.5 partial
i dont have a problem with launching and thats whats got me stumped. a quick chirp and im off, everyone hear talks about getting the launch and even flooring it i get a chirp or two then im off.
ever since i got my WS ypipe my torque has really dropped so im debating if i should go back to stock.
i have had a lot of front end problems recently but nothing that should affect my speed.
Old Nov 10, 2010 | 04:20 AM
  #179
How'd you figure your TQ dropped???
Old Nov 10, 2010 | 04:28 AM
  #180
datdude20's Avatar
Old Nov 10, 2010 | 05:21 AM
  #181
Im willing to bet the **** had suttn to do with this smmfh!
Old Nov 10, 2010 | 05:25 AM
  #182
essential1's Avatar
You're probably pulling alot of timing... That could be the reason it feels like your TQ dropped.
Old Nov 10, 2010 | 08:26 AM
  #183
I say he needs to stop listening to his ****......
Old Nov 10, 2010 | 08:35 AM
  #184
MoncefA33's Avatar
Butt dyno FTL,
Get it on a dyno and look at the shape of the curve. A y-pipe adds torque. But adding fuel through the VAFC pulls timing since it bends the MAF signal.
At this point honestly toss the VAFC and get an SAFC2 or e-Manage Blue/Ultimate, it'll make your task a lot easier and make more power.
Old Nov 10, 2010 | 10:21 AM
  #185
Butt dyno FTL,
This ^^^... and preferably when you post anything about HP, TQ, or tune, please leave your **** out of it... it makes things more complicated and its a good way to wreck your ride and mind
Old Nov 10, 2010 | 07:49 PM
  #186
rayac88's Avatar
once i put the y-pipe on i noticed my acceleration down low had dropped horrifically but after time it corrected slightly. then i put the bbmaf on i may just ditch the vafc2 and go to a neo of SAFC. i cant see myself spending much more money on this car, but i do want it running right.
i will start leaving my **** out of it... i didnt consider since i had to tune the idle that it would effect my timing. if i found a way to advance my timing 17 degrees would that help or should just go for the SAFC? the NEO has the 1in17out setting right?
Old Nov 11, 2010 | 03:01 AM
  #187
Idk about the neo
Old Nov 11, 2010 | 06:38 PM
  #188
rayac88's Avatar
i just bought a neo is has setting up to 26in/out so im hoping this will take care of it. all the wires are the same color from the vafc2 so ii think i dont have to re-splice everything just unclip the extended harness and connect it to the NEO. but im going to quadrouple check it before i do that.
Old Nov 22, 2010 | 02:32 PM
  #189
rayac88's Avatar
the neo is not a direct harness swap i had to rewire it. it was too easy to tune i set it 1-17 and tuned it with a handful of runs... i think the vafc tuned so much for idle affected my fuel pump cuz when i go into gear now the revs drop low and sometimes it stalls.
Old Nov 22, 2010 | 03:21 PM
  #190
jowo9's Avatar
Nice to know that the sensor type settings are the same on the SAFCII and NEO for a larger MAF (1 IN 17 OUT). No one seemed sure about that before. Only problem is if I ever decide to get a bigger MAF, I'll have to get rid of the VAFCII I just bought ... Oh well, I'll probably never go for a BBMAF...
Old Nov 22, 2010 | 04:44 PM
  #191
rayac88's Avatar
i will work with the vafc2 but you got to tune for more gas. i havent been to the track to see the difference in times between the vafc and the neo... i dont really know if there will be a difference.... maybe in my 60ft times
Old Jan 20, 2011 | 05:13 PM
  #192
rayac88's Avatar
well im bumping this thread.
i changed my valve covers today and when i put everything back together and started the maxima up it started to run lean. around 18.8 a/f ratio. so i looked around to see if things werent connected correctly but everything was good. so i decided to mess with the sensor type on my NEO. it was at 1 and 17 then i put it to 1 and 1 and it was running even leaner.
i changed it to 1 and 4 WOT was about -8 points. now it is at -12 from about 3500 rpm. with my previous settings everything before the VI kicked in was 14.7 until The VI hit and then it gave me the ability to tune. now i can tune it from anywhere as long as im in WOT. At WOT before the VI kicks in the a/f is around 13.8 which i never saw under 4k rpm.
do any of you experts have any idea why that happened?
Old Jan 30, 2013 | 10:06 PM
  #193
so nasty nismo's Avatar
Samething is happening to me ever since I installed nwp spacers and new valve cover. What's going on? It idles at 17.0 to 18.0
Old Jan 31, 2013 | 08:47 AM
  #194
NmexMAX's Avatar
dot dot dot ...
It sounds like an obvious vacuum leak as air is getting in unmetered and causing a lean condition. Look for vac leaks, and if you need to go back and check everything.
Old Jan 31, 2013 | 08:54 AM
  #195
Thanks bro. Me and mechanic friend went over it and it seems like the kinetix manifold does not line up that good with the nwp spacer and I may need to make an additional spacer out of cork car will go under the scissors ASAP. Lol
Old Jan 31, 2013 | 08:55 AM
  #196
Is it safe to drive like this by the way?
Old Jan 31, 2013 | 09:18 AM
  #197
NmexMAX's Avatar
dot dot dot ...
Seems a little lean to me. What are your normal driving AFR's?
Old Jan 31, 2013 | 09:20 AM
  #198
TunerMaxima3000's Avatar
Need a pinout for the MAFS on the VQ35DE, assistance?
The FSM's I've checked give pins that don't seem to be correct, looking for verification
Old Jan 31, 2013 | 09:31 AM
  #199
NmexMAX's Avatar
dot dot dot ...
What do you need?
  #200
Originally Posted by nmexmax
seems a little lean to me. What are your normal driving afr's?
14.7 15.1
