Strange Rasp at Certain RPMs
Old Aug 23, 2010 | 09:26 PM
jowo9's Avatar
I have Cattman headers and 3" exhaust. There has always been a slight rasp under load around 2000 rpm... it sounds like it comes from the flex section of the y-pipe... I assume this is normal, but lately, just at VERY specific low RPMs under load, I'm getting a really loud rasp sort of noise... it SOUNDS like it's coming from the y-pipe area, but I could be wrong. I'm worried it could be something serious with the engine, but don't think so... could it be a collapsed flex section? What else could it be? Thanks for any help.
Old Aug 24, 2010 | 12:47 AM
McSteve's Avatar
Isn't that the good ol bees in a can sound? Did you notice a decrease in performance? I heard wrapping the flex section in header wrap has helped. However if you have a collapsed flex section, you can just get a new one welded on.
Old Aug 24, 2010 | 04:33 PM
yankeefan13's Avatar
I have the same problem as you such as it happening around 2000rpm. I found out it was the flex pipe loose, and its just loose but I don't think you can fix it without getting a new one.
Old Aug 24, 2010 | 07:27 PM
jowo9's Avatar
Huh. I'll have to get under there and see if it's loose. Strange that I'd be having problems with the y-pipe though... It's Cattman and only a couple months old!!!
Old Aug 24, 2010 | 07:57 PM
02Maximan's Avatar
I'd be curious also to know what you find out. I have posted recently in another thread concerning this same problem. An unfavorable sound is coming out of my exhaust also after I installed cattman headers. Not sure where its coming from.
Old Aug 24, 2010 | 08:00 PM
jowo9's Avatar
^^^ I shall update this thread if I find out what's wrong.
Old Aug 25, 2010 | 07:06 PM
Yea let me know what you find could be different then me obviously.
Old Sep 6, 2010 | 03:49 PM
jowo9's Avatar
Ha! I finally got around to checking out what the problem was. It wasn't anything wrong with the flex section after all! One of the 3 nuts on the rear header/y-pipe flange was gone! So easy fix. I do however, still have that slight "bees in a can" sound in my flex section that everyone has (not at WOT, just under load at lower rpms). I might just have to try wrapping the flex section in header wrap
Old Sep 6, 2010 | 10:10 PM
CMax03's Avatar
Sure it's not header a gurgling sound under part throttle acceleration or throttle lift.....that's what most sound like......I'm very interested in this find.....what did you use as a gasket @ that loose ypipe/header manifold flange? I'm sure the Cattman gasket was gone or burnt away....that's why I bought longer SS fine thread bolts to install lockwashers and my copper gaskets......
Old Sep 6, 2010 | 10:45 PM
jowo9's Avatar
Oh, is it just a header gurgle then? I just used the cheap crap gaskets that Brian sent with the headers... They actually seem to be holding up so far I think. I'll probably have to go a similar route as you someday and get some new gaskets, but as for now, they're fine.
Old Sep 7, 2010 | 12:20 PM
02Maximan's Avatar
What are you talking about by a header gurgling sound? Does everyone experience this with headers? and where did you get the copper gaskets from? I have been overall disappointed with the sound that I got from my Cattman headers. Impressed with the power though.
Old Sep 8, 2010 | 06:41 AM
CMax03's Avatar
The gurgling sound is very apparent during throttle lift and decelerating... three of my vehicles have headers and exhibit this....During part throttle acceleration you may experience a burbling (deeper) depending on what catback and intake you are running......The copper gasket I purchased online from Summit or Jeg's brand is SCE p/n 4220. I have them in the photo laying in front.....
Once you fix the gaskets (may require a little trimming of the bolt holes) you'll love the sh!+ out of these headers.....GL
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
