ABS Light on - how to diagnose which component is at fault?
Old Sep 2, 2010 | 09:37 AM
kingrukus's Avatar
no more maxima...
My ABS light came on yesterday. This was shortly after I had work done to the right rear of the car (had the flange between the B Pipe and muffler removed and replaced with a piece of straight pipe because it had rotted out).
I suspect that the work done to the right rear may have messed up the right rear ABS sensor or sensor rotor, but I am not sure.
How can I diagnose the ABS system to see exactly where the fault is occuring (sensor, rotor, module, wiring, etc)?
Old Sep 2, 2010 | 09:50 AM
NmexMAX's Avatar
dot dot dot ...
Find a place with a code read that reads ABS codes.
Old Sep 2, 2010 | 04:16 PM
YUOnDaGround's Avatar
I am going to have to subscribe to this thread because this light just came on after a stop at walmart. No recent work has been done. Let us know what you come up with.
Old Sep 2, 2010 | 04:28 PM
SteveB123's Avatar
Chances are its a sensor. Test procedure in the FSM.
Look for occillating resistance when you spin the wheel, IIRC.
Old Sep 2, 2010 | 04:30 PM
djblackout's Avatar
check and see if the wire that connects to your wheel sensor could have been snagged. I had a problem on a non nissan, but it's possible.
mvm062
Nov 30, 2020 09:00 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxima30
Sep 7, 2015 06:13 PM
maximusrising
Sep 2, 2015 09:55 AM
