Bubbles don't stop coming out of Radiator
Old Sep 4, 2010 | 11:39 AM
YUOnDaGround's Avatar
I flushed out my cooling system to day and I went to refill it and I had the front end jacked up and the engine warmed up using one of the 'no spill' radiator filler funnels. Then I thought I had all the air bubbles out after about 15 minutes. Then more bubbles came and more and more. Just little bubbles one after another. In my experience with other cars this means that the head gasket is blown somewhere on the compression side of the cylinder. What are your thoughts? I have not done a leak down test yet.
Bruce
Old Sep 4, 2010 | 01:24 PM
auveeb's Avatar
Head gasket or water pump. Go to a shop to see if there are any hydrocarbons in your radiator to rule out the water pump.
Old Sep 4, 2010 | 02:22 PM
maxipower's Avatar
head gasket blown,,is there any white smoke coming out the tail pipe,,
Old Sep 4, 2010 | 03:45 PM
Absoulutely no white smoke whatsoever.
Old Sep 4, 2010 | 03:53 PM
Amave's Avatar
why did you flush your cooling system?
maintenance? was it running hot? does it overheat now?
if you just drain and fill it, there shouldn't be bubbles in your coolant, unless there is air
Old Sep 7, 2010 | 01:23 PM
I had been over heating so I changed it. By bubbles I mean about the size of peas not just little foam bubbles. Update: the car is in the shop now, water pump or maybe a head gasket.
Old Sep 8, 2010 | 02:58 PM
Amave's Avatar
well, since the VQ isn't known to have water pump problems, it sounds like a blown head gasket even though you have no white smoke from the tail pipe...could be a hole in the gasket on the combustion side ..
keep us updated
Old Sep 8, 2010 | 03:00 PM
Crusher103's Avatar
keep us updated
yea right. VQs have water pump problems and i bet thats what it is.
Old Sep 8, 2010 | 03:13 PM
Amave's Avatar
i read someone post saying that they're Nissan dealer had never sold a water pump ( yeah i know ) because they never go bad ( according to the post )
if it locked up ( timing chain driven ) then the chain would have gotten locked...i could see if the water pump was belt driven on the outside it could overheat...unles the water pump blades were somehow stripped or came apart and the pump is just spinning w.o blades thus causing it to overheat ...
i'm curious to know what they found ?
if he had done a combustion chamber leak test it would have confirmed or denied the water pump
Old Sep 9, 2010 | 06:42 AM
njmaxseltd's Avatar
Overheating + Bubbles/Air in the cooling system = blow head gasket.
Old Sep 9, 2010 | 07:50 AM
Ok here is the latest. Mechanic said that the hydrocarbon test was negative so at this time he cannot confirm a blown head gasket. He took it driving to try and replicate the overheating and he cannot make it overheat. So his thought is to drive it some more and see if it will over heat for him. He seems to think that I just didn't get all the air bubbles out of it when I changed the coolant.
Old Sep 9, 2010 | 08:02 AM
SteveB123's Avatar
That was me. Local dealer doesn't stock the water pump (that I thought I needed), but DID have the oil cooler water pipe in stock (that I DID need!).
Old Sep 9, 2010 | 08:07 AM
why did you need a oil cooler water pipe?
Old Sep 9, 2010 | 08:23 AM
SteveB123's Avatar
Leaking from rust.
Old Sep 9, 2010 | 09:38 AM
Amave's Avatar
phew! looks like you dodged a bullet....
Old Sep 9, 2010 | 12:37 PM
Well here is some more information about the hydrocarbon test... He said that if it is positive, than it is 100% that the head gasket it blown. If it comes back negative, which it did, that it is NOT 100% accurate that the head gasket is blown. So right now I am at the point where he has had it for three days and knows as much as I did when I gave it to him.
Not that I don't trust him but I want to get the maxima out of the shop and give it back to my wife so I can have my Tahoe back...woman is killing my gas mileage.
Old Sep 9, 2010 | 02:13 PM
Amave's Avatar
hhhhmmmm i've always known the combustion leak test to be 100% accurate, the liquid turns yellow when it detects combustion chamber gasses....
unless he's not doing it correctly
Old Sep 9, 2010 | 03:04 PM
Yeah I've got nothing...I am at a loss.
Old Sep 9, 2010 | 04:56 PM
So I just got the car back tonight and everything is fine and all he did was fill and burp the coolant system and do the dye test. I am thinking that maybe it is a warped head or a hairline crack of some sort that needs the head to have a good bit of heat in it before the metal will expand enough to manifest the symptoms i.e. bubbles in the coolant.
Old Sep 11, 2010 | 05:34 PM
Well I finally fixed it....I sold it.
Old Sep 11, 2010 | 06:46 PM
Amave's Avatar
what did you do to fix it?
Old Sep 11, 2010 | 07:23 PM
nelledge's Avatar
"I'm just sayin'..."
Old Sep 11, 2010 | 07:26 PM
Amave's Avatar
Originally Posted by nelledge
ah ok now i understand ..he just got rid of it
Old Sep 12, 2010 | 05:13 AM
I could literally see the "WTF" look on your face as your wrote this.
Old Sep 12, 2010 | 08:15 AM
CMax03's Avatar
That seems to be the way ppl cure their problems these days....But that's what happens when you ignore dealing with an overheating car with an all aluminum engine....or any other type of problem that's neglected/ignored.
Old Sep 12, 2010 | 03:36 PM
Unfortunately for me that is exactly what the guy did who sold it to me...I just didn't find out about the overheating problem until later.
Old Sep 12, 2010 | 03:44 PM
Amave's Avatar
i would have probably just bought a long block VQ and swapped it out and parted out the motor with the blown head gasket to help fund the long block..
but then again i have the know how/tools/space to do something like that
Old Sep 12, 2010 | 04:38 PM
Tools - yes
Know how - yes
Space - yes
TIME - HECK NO
Work and school full time with a wife and child. Sell it (made a profit) and buy something else.
Old Sep 13, 2010 | 01:19 AM
CMax03's Avatar
Tools - yes
Know how - yes
Space - yes
TIME - HECK NO
Smart move for your situation....Too bad you did business with a liar the first time ...he'll get his!
Old Sep 13, 2010 | 03:46 AM
SteveB123's Avatar
Depends if he informed the new buyer about the issue at hand.
rbuswell
Nov 17, 2016 04:54 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
acw
Aug 7, 2015 04:20 PM
