Engine Whining and Smoke
Old Sep 5, 2010 | 12:27 PM
rosader's Avatar
Last week my engine was whining but it only lasted a few minutes but today it's back and whenever I come to a stop it starts to smoke slightly and and there's a burning smell. I opened up the hood and the smoke seems to be coming from the passenger side of the engine. After doing some research I'm guessing it might be my tensioner??? Does that sound right? Is that an expensive fix? I have a shop at my house with a car lift and cherry picker (came with the house but I have never used it) my brother used to be a diesel mechanic so he can probably do the work but how much should i expect to pay for parts?
Old Sep 5, 2010 | 01:24 PM
Z-Powered's Avatar
Check your power steering fluid. The resovouir is on the passenger side of the engine, and it might smoke if it's leaking onto something hot. And it tends to leak on Maximas...
Mine just started leaking a few days ago.
Old Sep 5, 2010 | 01:38 PM
rosader's Avatar
I'll have to check on that when i go home but my steering felt fine so I don't know if that would be it
Old Sep 5, 2010 | 03:34 PM
rosader's Avatar
Power steering fluid is full although I forgot to mention it was low a couple of weeks ago but I topped it off and it's still full so I don't think there is a leak or anything
Old Sep 7, 2010 | 06:54 AM
rosader's Avatar
I had a mechanic look at it and he says he thinks it's the timing chain tensioner, it makes rattling noise on startup and when rpms come down. Checked the oil and it isn't low so he's pretty sure the tensioner is the problem.
How much will parts cost to fix this?
Old Sep 7, 2010 | 05:41 PM
rosader's Avatar
progress, I haven't ordered parts yet I need to look and see if it's just the tensioners or if the chains need replacing too.
Old Sep 8, 2010 | 03:22 PM
spock's Avatar
Tensioner shouldn't cause smoke. Rattle likely, but not whine. Is that your engine pulled in the pic?
shilov
Feb 19, 2024 09:40 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
ballerchris510
Sep 10, 2015 09:35 PM
