What is this thing on my 5th Gen?
Old Sep 11, 2010 | 04:07 AM
  #41
ghostrider17's Avatar
Rochester and his Band of Merry-Men!!
--not to be confused with "Gay"--
Ok seriously -- where's the KNOCK SENSOR?!?!
gr
*Good Post as usual -- this is a cerebral group, the collective "brain-trust" of the .org, if you will.*
Old Sep 11, 2010 | 05:55 AM
  #42
Rochester's Avatar
Originally Posted by spock
This ain't show and tell!
Well, obviously. If it were, things would be clean, instead of being rusty and covered with grime, like many of these photos.
Put another way, Education and Pride have a functionally linear relationship. If you reverse that sequence, you won't learn anything.
Don't you have a copy of the FSM?
Yes. I referred to the FSM in the original post. But how do you look something up in the FSM if you don't know what it is?
Originally Posted by knight_yyz
all 3 are 02's the 4th one is hidden near the fire wall
Thanks, Ray.
Old Sep 11, 2010 | 06:00 AM
  #43
Rochester's Avatar
See the curvy, silver piping that's in the middle of this photo? It stretches across the entire firewall before disappearing underneath, then goes all along the driver's side fender... before disappearing underneath.
Is that part of the AC, maybe?
edit: identified by spock as high-pressure refrigerant return line for the Air Conditioning, page HA-160 in the FSM.
Old Sep 11, 2010 | 06:34 AM
  #44
JAY25's Avatar
gr
Knock sensor is under the lower intake manifold. to get to it you have to remove the manifold, then lower, injectors and when you lift that you will see the knock sensor.
Old Sep 11, 2010 | 06:41 AM
  #45
Rochester's Avatar
If you don't have the stock airbox apparatus in the way, you can actually see it pretty clearly without doing all that work. The big question is, can you replace it without doing all that work?
Some people have. You need a 12" socket extension, and one of those swivel connectors. Tape them all together so they don't separate, and put some putty or clay inside the socket so you don't lose the KS bolt. The only real concern is how to apply the proper torque, but the torque specs are pretty light, so hand-tight is probably reasonable. (Don't take my word for that, however.)
I haven't done it myself, but like I said, it can be done.
Old Sep 12, 2010 | 12:01 AM
  #46
NmexMAX's Avatar
dot dot dot ...
Control yourselves children ...
Old Sep 12, 2010 | 06:10 AM
  #47
Rochester's Avatar
OK, Dad.
So do you know what that curvy, silver piping is in the middle of this photo?
Old Sep 12, 2010 | 06:38 AM
  #48
spock's Avatar
High pressure liquid refrigerant line leading to the evapourator coil for the A/C.
Old Sep 12, 2010 | 07:02 AM
  #49
Rochester's Avatar
So it is air-conditioning piping! Thank you, Spock.
Old Sep 12, 2010 | 07:05 AM
  #50
Rochester's Avatar
How about this rectangular box below the Brake Master Cylinder?
edit: identified by essential1 as the ABS Actuator and Electrical Unit, page BR-39 in the FSM.
Old Sep 12, 2010 | 07:07 AM
  #51
essential1's Avatar
My axles cry for mercy...
On the 4th gen VQ30 and VQ35s you can get to it pretty easilly without removing the IM. The dek however has an extra water neck that is in the way which literally makes it impossible to even take a glimpse at the knock sensor.
Old Sep 12, 2010 | 07:09 AM
  #52
essential1's Avatar
Its for the ABS. I forget the proper name for it though. I would assume its something to the point of "ABS control module" or something of that sort.
Old Sep 12, 2010 | 07:30 AM
  #53
Rochester's Avatar
You're right... page BR-39 in the FSM.
Old Sep 12, 2010 | 07:33 AM
  #54
Rochester's Avatar
This is probably stupid obvious to someone, but I'm not so proud as to avoid saying I don't know what that single hose and piping is with the little black valve. I'm guessing it's part of the AC.
edit: identified by essential1 as the primary high-pressure refrigerant line for the Air Conditioning, page HA-160 in the FSM.
Old Sep 12, 2010 | 07:36 AM
  #55
essential1's Avatar
No problem. Keep 'em comin. I think I've plugged and unplugged every style clip nissan put in the maxima already. There's not much I cant identify. . At the very least, i'll know what it goes to or what it does.
Old Sep 12, 2010 | 07:38 AM
  #56
essential1's Avatar
Yup. That is the Low side A/C port. That's the port you use to fill the free-on. Most of the time, this cap will be a light blue/teal color with the letter "L" on it. But it does look cleaner with the black cap.
Also, just a suggestion for dressing up your engine bay. To the bottom right of your picture, on the inner part of the timing cover. there are 2 ground wires that seem to have a little rust on the metal ring connectors. You can replace these with new ones. But now that I think about it, the engine cover is probably gonna cover these when installed.
Old Sep 12, 2010 | 07:39 AM
  #57
zero2sixtyZ's Avatar
You embarrass me.
I <3 this thread.
Old Sep 12, 2010 | 07:53 AM
  #58
Rochester's Avatar
Thanks, essential1. I rather thought it was A/C. Page HA-160 in the FSM.
You're right about those 2 ground connections... one is gunked up, and both are less than optimal. I've got a side-project on the back-burner to clean up all the ground connections. There's a bunch of them.
And you're also right that it's hidden underneath the engine cover. (That didn't stop me from grinding down and painting that wire-bracket next to it, but I was on a roll a few weeks ago, painting things.)
BTW, here's the diagram on AC from the FSM, showing the main coolant line, and the little return line that I asked about yesterday:
Old Sep 12, 2010 | 08:10 AM
  #59
Rochester's Avatar
There's another sensor wiring harness right behind the Power Steering Fluid Reservoir... does anyone know what this is?
For that matter, why was it clipped to the strut tower? Personally, I like it better tucked behind the reservoir, with those holes neatly capped.
edit: identified by bestpeto as the passenger-side ABS sensor harness, page BR-42 in the FSM.
Old Sep 12, 2010 | 01:02 PM
  #60
jowo9's Avatar
I've unplugged that before, and when I did, the ABS and slip lights came on, so it could have something to do with the TCS/ABS system? I dunno.
Old Sep 13, 2010 | 10:34 AM
  #61
Rochester's Avatar
Here are 2 more harness connectors, on the transmission side of the engine. One is a sensor on the water pipe... coolant temp? IDK.
edit: identified by Froggmann as Coolant Temperature Sensor, and the other end of the Knock Sensor Harness -- pages EL-464/465 in the FSM.
Old Sep 14, 2010 | 05:28 PM
  #62
Rods03Max619's Avatar
Nice Thread!!
Old Sep 14, 2010 | 08:57 PM
  #63
Mr. Brett's Avatar
Bump for an answer to this harness connector. jowo9 thinks it's ABS.
Whatever that is, either it was something put on in later-model '02's, early '03's. Or it's a manual transmission component. I don't have it on my car. Just holes where it should be. I believe.
I'll have to double-check that statement now that I'm really thinking about it. I've never noticed a wire there before, though. I would think I would've bumped into it wiping the dirt off my strut towers.
Don't think it's ABS, though...
Edit: I was under the hood last night, and sure enough, that wire's there. I guess I've just always disregarded it in the past.
Old Sep 15, 2010 | 05:26 AM
  #64
Rochester's Avatar
3 sensor harness connectors still unidentified.
Here's a 4th. It resides down low in the front passenger side of the engine bay, left from where the 2 water pipes are collected. This isn't the best picture, but if you go look where I'm describing, you'll see it on your 5.5 gen.
Old Sep 16, 2010 | 03:51 PM
  #65
bestpato's Avatar
From the placement near the strut, I was almost sure it was the ABS sensor of the front-right wheel... and I just checked it on the FSM, page BR-42. There should be another similar connector on the driver's side.
BTW this is my first post
Old Sep 16, 2010 | 04:05 PM
  #66
Rochester's Avatar
Would that be this one, near the ABS control module?
That's a pretty impressive first post. Well done!
Old Sep 16, 2010 | 04:12 PM
  #67
Rochester's Avatar
BTW, I was showing this photo to a friend at work, and he made a pretty insightful suggestion, responding to my WTF comments about how that wire was clipped to the strut tower.
His premise is that part of car design (today) includes manufacturing considerations, and that the brakes were likely installed before the supporting Power Steering parts. Therefore, the cabling was secured out of the way so that the PS Reservoir could be easily installed without compromise.
That makes a whole lot of sense to me.
I'm going to remove the PS bracket, do some painting, replace the bolt hardware, and tuck that wire behind the PS Reservoir bracket. That should look a lot cleaner.
Old Sep 17, 2010 | 06:48 PM
  #68
spock's Avatar
Cleaning up a few rusty bits b4 the evil salt weilds it's rust saber again?
Old Sep 19, 2010 | 07:03 AM
  #69
spock's Avatar
While we're at it, what's that cane handle shaped hose on the bottom right of the picture? I thought maybe a vent of some kind?
Old Sep 19, 2010 | 08:07 AM
  #70
Rochester's Avatar
That's the Transmission Air Breather Hose, page MT-13 in the FSM.
Old Sep 19, 2010 | 10:30 AM
  #71
spock's Avatar
My auto tranny has the same one. That's why I wondered when I saw one on your manual.
Old Sep 19, 2010 | 11:09 AM
  #72
findingnismo's Avatar
Hey guys! Lots of good information here.
I am looking at replacing the intake system. Sorry for not having a picture atm, but what is the plastic contraption under the air intake. It is connected with the intake. It is a transparent plastic box. Thanks
-D
Old Sep 19, 2010 | 11:50 AM
  #73
03VQMAX's Avatar
Not so much of a "what is this thing", but is this metal ring looking thing in the inside suppose to be right next to the sway bar bushing? Can't remember it being there when I replaced them last year. Just curious. Thanks in advance.
Old Sep 19, 2010 | 01:26 PM
  #74
Rochester's Avatar
-D
That's a stash box. But the transparent ones... they don't work so good.
Pictures, newbie... pictures.
Old Sep 19, 2010 | 02:07 PM
  #75
here you go...
Its under the battery and like i said, its connected to the intake. thanks.
Old Sep 19, 2010 | 03:11 PM
  #76
HomerOwns's Avatar
Hello everyone, I found this hose lose when i got the car 2000 Maxima SE was just wondering where it connects to.
the other end connects here
Old Sep 19, 2010 | 03:24 PM
  #77
03VQMAX's Avatar
^^^ I believe that's the transmission breather hose, I have the same thing on mine.
Old Sep 19, 2010 | 03:30 PM
  #78
knight_yyz's Avatar
Toolie
the clear plastic box on the 00-01 is some sort of water capture device. Any water sucked in through the scoop should end up there and evaporate.
Old Sep 19, 2010 | 03:35 PM
  #79
So in reality if i put on an intake, i can trash it all?
Old Sep 19, 2010 | 03:41 PM
  #80
Mr. Brett's Avatar
Correct me if I'm wrong, but that's only on the 5th, and not the 5.5, right?
I never noticed any sort of box on my intake when I pulled it off and put my CAI on.
