rear door stuck closed
Oh so frustrating. Searched forums, no real clues. Please... desperate for any thoughts!
Have the panel off, push rods for lock and handle working. Can't tell whats happening at lock end, sealed unit, can't see, can't feel! Don't think the child lock is on but can't move it with the door closed! (can't open door from inside either).
Is there any way to open a door from the inside?
What do you wreck when you kick a door open from the inside? What's a guy to do?
Break in
Does anyone here have experience opening the door latch from the inside?
I have reached in and got nowhere from inside the door and it will NOT open!
It seems impossible so, if you have any experience with this kind of thing...?
rear driver side door is the same on my car, have not tackeld that yet but i play to this weekend.
im going to take out the back seats and the door panel and then go from there
anyone have any tips on removing the seats and door panel with the door closed? Good luck man, let me know how you go about fixing it, and if i get mine done first ill let you know lol
How to open a rear door when all seems lost....
As per my original post nothing was working but finally got it open by doing this:
1. remove rear seat by pulling 2 tabs at the front of the seat, forward which releases the bottom of the seat. It then pulls up and forward.
2. Remove door panel by removing screws in armrest area.
3. Remove trim around door handle- be careful- it will break!
4. Pull/pry door panel straight towards you to "pop-out" the retainer plugs.
5. remove panel by lifting upwards so the lip of the panel comes free, by the window.
6. Inspect to make sure the problem is not that the push rods are off. It happens.
7*** Reach inside towards the door latch mechanism and you will feel what feels like a flat washer riding a verticle rod. Slide the flat washer thing upwards and this will open the latch.
It now works so I believe my issue was one of lubrication. We'll see.
Good luck.
Good luck.
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Huttig2009
Sep 25, 2015 03:31 PM
wingsfan24
Aug 15, 2015 07:35 PM
BobMax
Aug 15, 2015 12:35 PM
