Poor Gas Mileage, what to check?
Old Sep 13, 2010 | 09:29 AM
jgilbs's Avatar
I have an '03 Maxima automatic, and my gas mileage is bad - its averaging 15.9mpg according to my dash gauge. What does everyone else get? What are some things I can check that might be causing this? It seems to run fine, and the pickup is decent. I dont drive with my foot to the floor all the time. When I'm on the highway, I get 20mpg(if I reset trip computer while on the highway). All of this is not using AC. My pulley belt looks a little cracked, could this be causing my poor mileage.
Old Sep 13, 2010 | 10:27 AM
VQP0WER's Avatar
I don't think this topic has never been discussed before.............
Old Sep 13, 2010 | 10:42 AM
Chris Gregg's Avatar
Get Off My Lawn
First, you need to understand how UNreliable the trip computer is at averaging your fuel economy. The only true way to measure this is by filling up, resitting your A tipometer, then filling up near empty (or 1/4 to 1/8 tank). Divide the miles traveled by the number of gallons used to fill up. That simple.
Then IF you are still getting that poor economy, you need to look at overall maintenance. NGK platinum plugs? What grade gas you using? Anything lower than premium will begin to reduce mpg performance. Several other things, but until you really verify the miles you are getting per gallon, I can't be sure you really have an issue. You should (in an automatic) be getting 330 miles per tank or more. I average 21-22 mpg. When I've run Lucas fuel additive (I get the big bottle)...I typically run 22-23 mpg on average.
Definately, do a search for some great references on this very topic.
Old Sep 13, 2010 | 11:06 AM
fflint_18's Avatar
I get just over 20 mpg around town running Plus. Jumps up significantly on the hi-way when I can run in 6th.
Car just turned 100k today (yippee) so I will be puttin in Iridiums next week and we'll see if I get much of an increase.
Old Sep 13, 2010 | 11:20 AM
phatboislim's Avatar
probably a banana in your tailpipe
Old Sep 13, 2010 | 02:56 PM
Amave's Avatar
start with any dtc's, in the computer and go from thee...a full tune up couldnt hurt and dont ever go by the mpg monitor its not very accurate
Old Sep 13, 2010 | 03:05 PM
Doomztown's Avatar
I probably shouldn't do this but I will anyways:
Clean MAF
Clean Throttle body
PCV Valve
Spark Plugs
Tires
K&N Filter
Seafoam
Lighten out car load
Old Sep 14, 2010 | 09:38 PM
AEMAXIMA01's Avatar
Check your tire pressure.
Old Sep 15, 2010 | 02:25 PM
Specd_out's Avatar
Tire pressure is the biggest culprit. Also if you havent done so do a tune up. Also depending on the mileage the cats could be clogged.
Old Sep 15, 2010 | 08:11 PM
JustinXtlr's Avatar
I have been having the same problem. I get about 200 miles to a tank. Brand new maf, and air filter,fluids every where, just had the tires worked on so pressures should be right. Anyone one got any ideas for me?
EDIT<and i have a new hi-flow cat still nothing.
Old Sep 15, 2010 | 08:12 PM
jgilbs's Avatar
Given the grinding noise coming from the driver's side, and the rough ring on my rear rotor, I'm starting to think it might be partially due to a stuck caliper (also have extreme judder when braking)
Old Sep 15, 2010 | 09:25 PM
bullet187's Avatar
Is your check engine light on? A while back I had a bad catalytic converter that caused me to get really bad gas mileage. After I got it fixed my gas mileage improved about 5 mpg.
Old Sep 16, 2010 | 06:09 AM
ColdRain's Avatar
regarding grinding noise and stuck caliper, shouldn't you be able to smell some burning after driving for while?
regarding bad cat, i believe you can drill hole pre and past cat to do pressure testing. search youtube on videos of such (user scottykilmer has good info).
p.s. is it just me or Post quote reply is gone?
Old Sep 16, 2010 | 06:23 AM
Specd_out's Avatar
the ones that will clog first will be the precats in the exhaust manifolds
Old Sep 16, 2010 | 08:42 AM
JustinXtlr's Avatar
Ahh good to know, I haven't even looked at that. How do I go about cleaning those. Or do I have to change the headers?
Old Sep 16, 2010 | 09:12 AM
bullet187's Avatar
Have you looked at your check engine light for any codes?
Old Sep 16, 2010 | 12:03 PM
JustinXtlr's Avatar
if your asking me, yes i have and i have no codes. ive checked numerous times.
Old Sep 16, 2010 | 12:29 PM
bullet187's Avatar
Since you have no codes your CAT is still good.
Clean MAF
Clean Throttle body
PCV Valve
Spark Plugs
Tires
K&N Filter
Seafoam
I would try all of these before I did anything else.
Old Sep 16, 2010 | 01:03 PM
mandyfig's Avatar
Tire pressure must be at least 34 psi. Anything less affects the rolling resistance, hence more gas burning.
Old Sep 16, 2010 | 06:25 PM
JustinXtlr's Avatar
my car has burned out a maf completely with throwing a code, and it has done that twice. i dont really trust my ecu.i think it might be a little slow.. but im still going to try all these like yall are saying.
thanks for the help!
Old Sep 16, 2010 | 09:55 PM
jgilbs's Avatar
Ses is not. Plugged in a scanner, and there were no stored trouble codes. Is a burning smell a prereq of having a stuck caliper? I don't smell anything, and the rotor doesn't feel any hotter than the front one, bout the outer edge of the rear rotor is scored, and very rough. Could this just be a bad pad?
Old Sep 16, 2010 | 11:51 PM
bullet187's Avatar
I would say your rear rotors need to be resurfaced or replaced and have the break pads looked at. It wouldn't affect your gas mileage though.
Old Jan 2, 2011 | 05:42 PM
bad beat's Avatar
if you have not messed with the TB check your vaccum lines for cracks. if you cleaned your TB a relearn procedure may help. I was having a mileage and other problems and I removed the cable from the positive terminal for aboutg thirty seconds. This causes the computer to reset. It helped the gas mileage a lot and also cleared up my other problems. my vaccum lines were dry rotted and cracked.
Mar 12, 2020 12:06 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
slowlifer
Sep 8, 2015 05:53 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
