Car not starting, getting fuel and spark.
Old Sep 17, 2010 | 07:08 PM
rkyat's Avatar
POST #17 for updates::
Sorry for the long post, but here goes:
So on the July 4th weekend, my motor spun a bearing and was dead. We swapped in a 70k DE-K motor in. After install, car started up, smoked a bit, but eventually ran smooth and clean. Def pulled a bit more than my old motor. I picked it up on a Saturday morning, drove it all day and then made it home.
Come Sunday the car refused to start. Had my mechanic come by and check it out, tested whatever it is that he tests, (i'm not very mechanically inclined as you can tell, lol) and it was showing that it is getting fuel and spark. Tried swapping a couple of sensors with a working 5th gen and same thing. Thought it could have been a fuel pump, since it was intermittently coming on. Swapped it out and same thing. The car cranks and cranks but refuses to turn over.
Checked the codes and pulled a few o2 codes and the Nissan Anti-Theft code. I then went to FL for a month, and came back. So i got the key reprogrammed, and still having the same issue. Cranks but does not turn over. I did search for similar issues, and results ive seen was crank pos. sensor, and cam sensor which i did swap both with no results. Any further ideas as to what the issue may be? Just trying to get some other possible ideas.
Doubt it makes any difference, but only mods on car is OBX headers and test pipe.
Old Sep 17, 2010 | 07:46 PM
Amave's Avatar
try a different key ...when you put the key in the ignition does the security light go out? if you have spark and fuel, it should run...no reason for it not to run if you have both...
if you have a security problem you wont have spark....
Old Sep 17, 2010 | 07:55 PM
rkyat's Avatar
After i reprogrammed the key, and put it in, the light does go out.
Old Sep 18, 2010 | 06:47 AM
Amave's Avatar
any dtc's?
Old Sep 18, 2010 | 02:42 PM
rkyat's Avatar
sorry not familiar with that abbreviation.
Old Sep 18, 2010 | 06:45 PM
Amave's Avatar
sorry any diagnostic trouble codes?
you know any codes being set by the engine computer?
Old Sep 18, 2010 | 07:54 PM
rkyat's Avatar
The codes i pulled before was the o2 codes (cause of the headers) and that NATS code. I havent pulled any codes since i reprogrammed the key since i dont have a reader.
Old Sep 19, 2010 | 12:15 AM
CMax03's Avatar
What's your fuel pressure?
Old Sep 19, 2010 | 09:24 PM
rkyat's Avatar
Update:
Towards the left of the valve cover (looking into bay) we unbolted the two bolts there, engine ground i believe, sanded down the surface, re-bolted it, also ran an 8ga wire (it's all i had at the time) from a bolt near the tranny to the neg terminal of the battery. After a little bit of struggling the car finally started. So we've concluded its a ground issue. Im gonna try a 4ga wire and use a connector to securely fasten it to the neg terminal and post results.
Old Sep 19, 2010 | 09:42 PM
CMax03's Avatar
Good find! Makes sense though!
Old Sep 19, 2010 | 09:48 PM
rkyat's Avatar
on a side note, engine was also a bit flooded from previous attempts to start it, and it backfired like a dam gunshot at one point, and with a bus stop in front of my house, it was quite epic to see people scatter.
Old Sep 23, 2010 | 12:11 AM
rkyat's Avatar
Random update:
I believe my starter died now, just hear a click. will replace it and update.
Old Sep 23, 2010 | 05:21 AM
ColdRain's Avatar
Originally Posted by rkyat
Random update:
make sure you get it tested, before buying new one. Reason it may be again Grounding issue. may need thicker wire.
Old Oct 1, 2010 | 08:25 PM
rkyat's Avatar
Update. I got it to start a few times, not consistantly, but eventually it did. that was before the starter went. So we put in a new one. However its back to the same ****. Cranks and cranks no start. also i ran the codes and im only seeing a P0180 code.
Old Oct 1, 2010 | 08:34 PM
nsnrider's Avatar
check your harmonic balancer. I had a few cars come in with bad HB and intermittent problems. Crank sensor reeds the teeth off the HB. Hope this helps.
Old Oct 3, 2010 | 04:30 PM
rkyat's Avatar
^ill mention that to my mechanic when he gets a chance to come by and check it out.
Old Nov 6, 2010 | 02:56 AM
rkyat's Avatar
bumppp
car is still down. According to the mechanic its the NATS thats not allowing the car to start. Started a few times, now it doesnt, and the security light stays on. any of you with similar experiences?
Old Nov 6, 2010 | 03:18 AM
CPBOYZ's Avatar
YOU CHECK UR FUSES OR THE SENSOR ON THE TIMMING COVER? DOES IT START THEN SHUT OFF OR JUS KEEPS TURNIN OVER N OVER?
Old Nov 6, 2010 | 05:10 AM
maxima dude's Avatar
check ur ecm relay under the hood
Old Nov 6, 2010 | 04:16 PM
rkyat's Avatar
It starts whenever it feels like, lol. Not consistent. Other times it'll just crank and crank but wont turn over.
Relay was swapped and car started a few times but now its back to the same bs.
Old Nov 6, 2010 | 04:24 PM
CPBOYZ's Avatar
UM U CHECK UR TIMING CRANK SENOR ON THE TIMING COVER????? OR UR FLYWHEEL TEETH COULD B BENT AND THE CRANK IS NOT READIN IT RIGHT TWO OF MY FRIENDS THAT HAPPENED ITS WILL CRANK BUT HICCUP
Old Nov 6, 2010 | 05:45 PM
rkyat's Avatar
Yeah he checked the sensor and flywheel.
Old Nov 6, 2010 | 07:22 PM
trooplewis's Avatar
did you reset the ECM?
Old Nov 6, 2010 | 07:27 PM
bumppp
security light!... keep ur key on the ON postition and watch the security light until it blinks and goes off...it shuld take about 10 minz(or longer) and shuld start right up after that trust me on this...and if it starts up after that its something with the securtiy system i believe not reading the key or something
Old Nov 6, 2010 | 08:18 PM
CPBOYZ's Avatar
^^ NOT TRU MINE DONT BLINK EITHER DOES MY LIL BROS ITS ON 24/7 EVEN WHILE WE DRIVE BUT HEY IT WONT HURT TO TRY U KNO LOL ANYTHIN IS POSSIBLE WIT THESE CARS
Old Nov 6, 2010 | 08:28 PM
trooplewis's Avatar
you're killing me with caps, that is painful
Old Nov 6, 2010 | 08:30 PM
what i wrote is usually for the cars that wont start since the system wont let it cuz the security is messed up somehwere...if your car is starting then ur fine and f the security light is on on ur bros car tell him to get it checkd out
Old Nov 6, 2010 | 08:36 PM
dondadah88's Avatar
hey what's up. i just put a starter in my car. i had the same problem as you. where it would start when it felt like then one day it just wouldn't start at all. the starter was just replaced 4/28/10 and i was wondering what caused it. but anyways it died about a week ago again and we replaced it and now it's fine. but my check engine light is on. i went to autozone to find out what it is....
they said it is the crank postioning sensor. so now i have to change that when i can.
about your car not starting... i would check your starter again. i'm not really to sure but hey it's worth a shot. i know someone on here said he ground wire was garbage and killed his starter 2 times wiithin a 4 month period. i hope mines isn't in the same boat.
Old Nov 6, 2010 | 10:02 PM
CPBOYZ's Avatar
LOL BOTH OF OUR SECURITY LIGHTS R ON N STAY ON N THEY BOTH RUN HARD LOL BOTH START FINE LOL IM RUNNIN 14.5 UNTUNED VQ30 MY BRO RUNNIN 12.?? 125 SHOT VQ35 LOL IDK Y BUT THERE ON LOL
Old Nov 6, 2010 | 10:19 PM
rkyat's Avatar
Starter was checked, and car did start a couple days ago a few times. Then gave up again.
Old Nov 6, 2010 | 10:30 PM
CPBOYZ's Avatar
CHECK UR GROUNDS??? HEY TRY N BANG ON THE STARTER WITH SOMETHIN OR TOUCHING THE STARTER WITH A SCREWDRIVER N TRY N MAKE IT START ON THE POWER N GRND IT WILL SPARK LOL
Old Nov 9, 2010 | 01:41 PM
shrader22's Avatar
i have starting issues with my car also....except....when i go to crank it about 90% of the time it takes 5 to 10 seconds before it actually fires up. after that it acts like its missing for about 5 seconds then it idles great and runs great. ive replaced all the spark plugs and ignition coils and that didnt help although i did see a increase in power.
so im just wondering if anyone has had the same problem or has the same problem as me.
2001 nissan maxima se
Old Nov 10, 2010 | 08:32 AM
rkyat's Avatar
Grounds were checked, now we're leaning towards a computer issue.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
