Opinions on new clutch, which one do you have?
Old Sep 23, 2010 | 09:36 AM
TMAXDOUT's Avatar
Well since my motor went bye bye this week (somehow the timing chain broke, really didn't know that happens but it happened to me) , I decided that while im replacing the motor, I will throw in a Light weight fly wheel and a new clutch.
Basically i wanted to know what clutch you guys have on your car?
Old Sep 23, 2010 | 01:41 PM
knight_yyz's Avatar
Toolie
with your mods a stage 1 exedy will do fine
Old Sep 23, 2010 | 02:26 PM
rosader's Avatar
Exedy Stage 1 and Fidanza flywheel is what I have. That is one bad a$$ looking car I might add
Old Sep 23, 2010 | 03:35 PM
TMAXDOUT's Avatar
Thanks, for the complements. I was debating on a Exedy or go with the Stock clutch from nissan
Old Sep 23, 2010 | 03:42 PM
TMAXDOUT's Avatar
a not too great picture of what it looks like now, i returned to stock grille also +2010 TE 19s
Old Sep 23, 2010 | 04:03 PM
rosader's Avatar
I'm having timing chain issues myself I caught it before it caused any valve damage but I'm out about a grand for parts
Old Sep 23, 2010 | 04:43 PM
TMAXDOUT's Avatar
i didnt have any warning signs really....
Old Sep 24, 2010 | 09:27 AM
rosader's Avatar
My warning sign was the "normal" rattle at startup getting worse. I pulled the engine opened it up and sure enough I had a bad tensioner. I decided to replace the chains, guides and tensioners as well as the water pump while I'm in there. In the process of removing one of the intake cam sprockets I damaged the cam and sprocket so now it's almost costing me as much as I could get a low mileage used engine I'll be happy when I get it up and running again tho.
Old Sep 24, 2010 | 09:51 AM
HDB Audio's Avatar
Fidanza flywheel and exedy stage 1. And if you are doing the swap yourself, make sure that you put the alignement hole on the flywheel at front. I made this error and put it on rear and have the redo evertything!!
Old Sep 24, 2010 | 10:07 AM
QT1 5MT AE's Avatar
Gram Lights addict
I would go exedy OEM replacement and fidanza. stage 1 is significantly stiffer than stock and not suitable for daily on an N/A platform. I had it in my SC 4th gen...
Old Sep 24, 2010 | 10:41 AM
rosader's Avatar
Yeah the stage 1 is stiffer but it just takes a little getting used to. The OEM is too soft IMO
Old Sep 24, 2010 | 06:49 PM
TMAXDOUT's Avatar
anybody have links on where to get either 1?
Old Sep 24, 2010 | 09:18 PM
knight_yyz's Avatar
Toolie
check the group buy section for the best deals
REDinLV
Aug 15, 2024 12:30 AM
user 11122324
42
Jul 18, 2022 03:35 PM
carlosvq30
Sep 26, 2015 09:44 AM
dvcamp
Sep 18, 2015 10:17 AM
