Ghustle Down....... again
Old Dec 13, 2010 | 12:29 AM
  #121
cjandura's Avatar
http://forums.nycmaximas.org/showthread.php?t=57319
Old Dec 13, 2010 | 02:56 AM
  #122
Grand_hustle17's Avatar
Thank you but I've hit up almost everybody with the parts and the guy in NYC doesn wanna ship and all else just doesn't reply.... my part list is damn near done
Old Dec 13, 2010 | 09:13 AM
  #123
cjandura's Avatar
Good to hear bout the parts list almost done.ive just started on mine i found the 6mt when i took a trip to chester,pa junk yard i paid a bit much for it 690$ but it only had like 50k on it and i got both axles,hubs rotors and calipers with it.there was another one there but i couldnt find any vin plates to check it out.im going back down this week end if it is ill let you know.
Old Dec 13, 2010 | 09:46 AM
  #124
dnice02's Avatar
Are you doing the swap your self?I'm going Saturday to pick up a couple parts for my swap. found a local junk yard with a whole car,and they said everything's still in it.
Old Dec 13, 2010 | 02:44 PM
  #125
Naw, I'm not doing the swap and even if I could i'd be way too busy to tackle such task..... I'm sure labor is aroind $700
Old Feb 19, 2011 | 05:11 AM
  #126
Brining this thread from 6ft under.... just for everybody doing this swap... keep in mind that the 6spd trans mount comes in 2 peices I will snap some pics of the piece later but I believe the part bumber is 11253
Old Feb 19, 2011 | 03:38 PM
  #127
so the pics i said i was going to upload...
make sure the trans mount have this... it is only a $45 piece at the stealer
Old Feb 19, 2011 | 05:04 PM
  #128
dnice02's Avatar
You got your car back yet?
Old Mar 24, 2011 | 03:59 PM
  #129
update to the thread, the "green w/orange stripe" wire needs to be stripped and grounded to the car for it to start... now my key is stuck in the ignition and wont get out... help would be appreciated
Old Mar 24, 2011 | 04:44 PM
  #130
MoncefA33's Avatar
If the key is stuck, your steering lock probably kicked on. Jiggle the steering wheel and try and remove the key.
Old Mar 24, 2011 | 07:53 PM
  #131
Manny said the same... but will it have gottn stuck with the wheel straight??? Will try... that be pretty simple n silly
Old Mar 25, 2011 | 03:55 AM
  #132
Thas not the problem
Old Mar 25, 2011 | 10:15 AM
  #133
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
So the steering wheel turns fine?
Sometimes you have to manhandle it a little when it's steering wheel locked.
I take it you've also tried the key in every position?
Old Mar 25, 2011 | 02:25 PM
  #134
yea the steering wheel turned fine... it just came out with no problem now... idk why... like i went down there and they key just came out like there was never a problem
aackshun
Aug 31, 2012 04:30 PM
merovi
23458
Aug 18, 2012 06:35 PM
