Ghustle Down....... again
Old Sep 29, 2010 | 02:52 PM
  #81
NmexMAX's Avatar
dot dot dot ...
I'm like you, I've had an SES 2 months after I bought the thing, which was 6 years ago.
It's not the fact that we want you to use an MT ecu, but more-so how.
I know you said some other dude did, but I'd like to see how he made it work without going into limp mode and by-passing the TCM inputs from the ECU.
Old Sep 29, 2010 | 02:59 PM
  #82
Crusher103's Avatar
i say get the MT ECU and have it reflashed to work with ur key, just save urself some trouble.
Old Sep 29, 2010 | 03:25 PM
  #83
Grand_hustle17's Avatar
What trouble???......
Old Sep 30, 2010 | 06:36 AM
  #84
he posted it earlier
Old Sep 30, 2010 | 06:42 AM
  #85
NmexMAX's Avatar
dot dot dot ...
Well poopsicles. I even posted a boatload in that thread. I tell you, old age is setting in. damn, interesting.
That would verify my theory that the TCM and ECU are completely separate ... IIRC, Jime has also confirmed this.
Old Sep 30, 2010 | 07:28 AM
  #86
essential1's Avatar
My axles cry for mercy...
Congrats on finally deciding to do the swap hustle. It took me 3 autos in my 4th gen and 1 in my i30 to finally say EF it.
Old Sep 30, 2010 | 07:49 AM
  #87
gettn ready 2 leave....... im in nevada trick...
Old Nov 16, 2010 | 01:28 PM
  #88
lol so for most lemme see if this parts list is good enough
6spd ECU- Not needed
MT Tansmission
MT axle (driver side if LSD)
Transmission Mount
Clutch
Clutch line
Clutch pedal
Break pedal
Master cyl (from what i heard its not needed)
Slave cyl
Shifter bracket
Shift linkage
Shift ****
Shift boot
Shifter assymbly
MT starter
Flywheel
and off the top of my head this is all i can remember
EDIT: flywheel bolts
Old Nov 16, 2010 | 01:32 PM
  #89
phatboislim's Avatar
how is the clutch master cylinder not needed? its not a cable setup.......
Old Nov 16, 2010 | 01:33 PM
  #90
yea, you can scre the auto gear selector into the neutral position and it will start find i heard
Old Nov 16, 2010 | 01:42 PM
  #91
wow...ok...
Old Nov 16, 2010 | 01:43 PM
  #92
nelledge's Avatar
"I'm just sayin'..."
Are you talking about the neutral/safety switch? The master cylinder is what converts the mechanical pressure of your foot to the hydraulic pressure needed to engage the piston of the s/c which then moves the fork, which disengages the pressure plate.
BTW... don't overlook the flywheel bolts. They're recessed. I bought new from DaveB when I removed mine. You can't get away with hex head screws because of clearance, unless you want to do some machining and balancing.
Old Nov 16, 2010 | 01:47 PM
  #93
i didnt really include the flywheel bolts as its a very inexpensive "part" from the dealership and i wouldnt say its really included in the part list but i can respect that
Old Nov 16, 2010 | 01:51 PM
  #94
nelledge's Avatar
They usually aren't available local so it's not something you want to overlook. As far as 'nexpensive'? Those things are as soft as gold and they cost as much, too. The cluch line is half the price of 8 flywheel bolts.
Old Nov 16, 2010 | 01:52 PM
  #95
o.k bro man, i updated the list
Old Nov 16, 2010 | 01:57 PM
  #96
nelledge's Avatar
Sweet. I'm famous.
Old Nov 16, 2010 | 01:58 PM
  #97
Sweet. I'm famous.
Old Nov 16, 2010 | 02:39 PM
  #98
trooplewis's Avatar
Add ES bushings for the shifter linkage. For 20 bucks, a nice improvement over stock.
Red or black, your choice.
Old Nov 16, 2010 | 02:44 PM
  #99
not needed for a 6spd swap
Old Nov 16, 2010 | 05:09 PM
  #100
HotshotVQ35's Avatar
you doing this yourself or is a shop doing it..have you guessed what the price is gonna be..are the 2500+ prices accurate?
Old Nov 16, 2010 | 05:28 PM
  #101
trooplewis's Avatar
Non-OEM shift linkage?
Old Nov 16, 2010 | 05:40 PM
  #102
i wont be tightening a screw lol... well everybody should expect around the $2500 range i never really thought about how much total but mines should be around the $1700-$2100 range depending on certain parts
Old Nov 16, 2010 | 05:43 PM
  #103
if i go the lightweight flywheel route then that obviously bump the price up a lot
Old Nov 16, 2010 | 05:47 PM
  #104
thats not really too bad then, whats the eta till its done? or is there no rush at this point?
Old Nov 16, 2010 | 05:57 PM
  #105
if all goes to plan... the car will go into the shop the first or 2nd week of december but i dont mind having to wait longer... im use to it
Old Nov 16, 2010 | 06:06 PM
  #106
question to the massive.... why do i need a MT starter???? i looked em up and it didnt differenciate between AT or MT
EDIT: NVMD i saw it
Old Nov 21, 2010 | 11:31 PM
  #107
Unklejoe's Avatar
Get the black ones. They contain graphite which can help them self-lubricate.
Old Nov 22, 2010 | 12:18 AM
  #108
Oh o.k... ill order that tomorrow
Old Nov 23, 2010 | 06:11 PM
  #109
dnice02's Avatar
Keep us posted man. i'll be doing this as soon as i get on a job. My tranny is on it's way out and i'm not trading this one in or buying another auto trans. I went through that with my 2000. Dam i miss her.LOL
Old Nov 23, 2010 | 06:15 PM
  #110
i miss my 2K also... yea im still ordering parts... taking my time though
Old Nov 23, 2010 | 07:28 PM
  #111
dnice02's Avatar
Are you Planning on using the spec V trans or a max?
Old Nov 23, 2010 | 07:46 PM
  #112
most likely a maxima's
Old Nov 23, 2010 | 07:56 PM
  #113
dnice02's Avatar
Did you do a 6spd swap on your i30? Love your car dude!!
Old Nov 23, 2010 | 07:58 PM
  #114
5spd as thats what the VQ30's came with... you and the whole forum loves his ride
Old Nov 23, 2010 | 08:02 PM
  #115
dnice02's Avatar
LOL. Dat **** go hard.
Old Nov 23, 2010 | 08:12 PM
  #116
rroderiques77's Avatar
Demodded and Forgotten
I've got a tranny if you need one.
Old Nov 24, 2010 | 04:05 AM
  #117
damaxunv's Avatar
There's someone On Nycmaximas whose sellin a six speed swap for like 1300
Old Nov 24, 2010 | 04:10 AM
  #118
I have most the parts on that list and I did see the guy sellin that, he wants local pick up though, I sent him a pm about a week ago one 1 or 2 parts
Details n how much
Old Nov 24, 2010 | 04:13 AM
  #119
Parts left to get
Trans
Flywheel
Brake pedal
Starter
Shifer bracket
Clutch
  #120
Parts left to get
Trans
Flywheel
Brake pedal
Starter
Shifer bracket
Clutch
