Ghustle Down....... again
Old Sep 28, 2010 | 07:03 PM
  #41
LongIslandMax's Avatar
Goodsh1t, hustle. It will not be easy, but it will be worth it. I have been piecing together all of my parts for my swap over the last 6 months, and it really is a pita to find everything without paying top dollar. I still have no idea where to get 6spd axles or the tranny mount...
I'm sure you have prob. read these already, but just in case you haven't:
http://forums.maxima.org/5th-generat...you-shift.html
http://forums.maxima.org/5th-generat...ne-4-days.html
http://forums.maxima.org/5th-generat...care-only.html
Btw Ohhh Noesss, did harjit and TJ do your swap? I know they did a 6th gen 6spd swap not too long ago.... I've been talking to maximum tunning, but I would rather have someone who is more familiar with our cars...
Old Sep 28, 2010 | 07:09 PM
  #42
Grand_hustle17's Avatar
yea ive read through a couple of those threads, i know the axles will be a lil hard to find but the tranny mount ill search car-part or partstrain for em..
i'd love for em to do my swap also if they are willing, ill drive on the two gears i have up to NY just as long as i dont have to reverse lol
Old Sep 28, 2010 | 09:43 PM
  #43
CMax03's Avatar
Your mode list would be even longer if you include all the s/n's from all the A/T you've had......and you think it's the MD weather causing your problem.....???
Old Sep 29, 2010 | 03:04 AM
  #44
Lls I kno right.... naw its not the weather here, or at least I hope not... I just made that up as me, txmax, datdude, phantomv, and 1sxyleo is having issues woth the cars... motors and trans smh...
Old Sep 29, 2010 | 04:15 AM
  #45
NissanMan97's Avatar
seriously hustle 9 or 10 trans???
good luck bro. ill check around here for some cheap parts. we have a pull a part place not to far from my work
B
Old Sep 29, 2010 | 04:28 AM
  #46
B
Yep..... no exaggeration, 9 or 10 transmission.... thanks bro lemme know what u can come up with
Old Sep 29, 2010 | 04:36 AM
  #47
no prob. i need to ride out there and look for some spare parts anyway. its a huge place. you are specific about the year oy tranny are you? 02-06 (?) 6spd will work wont it?
B
Old Sep 29, 2010 | 04:46 AM
  #48
Shift_Max's Avatar
You can always opt to get the fidanza flywheel instead of the dual-mas OEM unit which is like 30 pounds.
If I were you, I would look for as many parts possible from a manual car. There are more differences between the auto and manual 5.5 gen cars then on a 4th gen or a 5th gen.
Old Sep 29, 2010 | 04:48 AM
  #49
B
do you also want me to look for the cluster out of a manual?
B
Old Sep 29, 2010 | 05:52 AM
  #50
B
The transmission part I have down pack already, I'm also thinking of a fidanza flywheel and exedy clutch, I'm just morre concerened with the misc parts... cables, brackets, pedals and such... I also already found a slave cyl....
Old Sep 29, 2010 | 06:01 AM
  #51
ok...ill look for some of that stuff. i also need a new cable and the like. ill see if i can find some cool HLSD pedals for you
i talked to dave b a while back and he seems to think the 350z clutch is the way to go. only problem he has heard off is a slight clearance issue...im talking like .0000001mm, but enough to where some one did the swap and on first start heard a loud bang and though they threw the tranny.
give him a call and ask him all the details. might be cheaper to go that route and he can tell you more detail about the clearance issue
B
Old Sep 29, 2010 | 06:04 AM
  #52
B
Greatly appreciated... ill be in vegas on vacation til the 4th but ill try to stay on via cellphone
Old Sep 29, 2010 | 06:11 AM
  #53
i might no be able to get there till next week anyway. ill call first and see if they have any before i make the trip.
does it have to be pedals from a 5.5gen? or can they be 4th, 5th or 6th gen pedals?
B
Old Sep 29, 2010 | 06:17 AM
  #54
B
Nope... long as it works..... I'm not in it for the bragging rights and whatnot I just don't want another auto and I'm not willing to get rid of my 5.5.... ill half a$$ the job honestly
Old Sep 29, 2010 | 06:21 AM
  #55
ok...ill check.
honestly PM me a list of **** you need/like to have/want and ill check. as for the tranny stuff just include the gens that will work with the swap
this place has everything from what i hear. im looking for a spare set of wheels.
B
Old Sep 29, 2010 | 06:49 AM
  #56
Crusher103's Avatar
That sucks, trans problems are the worst. but why dont u just go and buy a 6spd.
Old Sep 29, 2010 | 06:57 AM
  #57
Crusher103's Avatar
but if a 6spd swap is a must, if this hasnt been mentioned look into SpecV trans. they are the exact same except the bell housings. u can buy a bellhousing brand new off of Courtesy for $230, and a SpecV tranny out of a wrecked car is like $300-400. and ALL specVs have HLSDs.
I will warn u thou swapping bellhousings isnt as easy as 1-2-3, u got be careful of those small little parts in the trans make sure they are all where they are suppose to be.
I was looking at doing a 6spd when my VLSD went the way of the dinosaurs.
Old Sep 29, 2010 | 07:00 AM
  #58
Why do I need a cluster???.......
Old Sep 29, 2010 | 07:16 AM
  #59
phatboislim's Avatar
doubt you will..you'll probably just have a flashing "D" light
Old Sep 29, 2010 | 07:28 AM
  #60
dnice02's Avatar
Im interested in doing this swap also Ghustle. Are you gone post up a parts list and what ever else it takes to get the job done? my tranny is on it's way out also. i got rid of my 5gen because of that bs auto tran. not getting rid of my 5.5 Lol. keep us updated. gl with your swap bro.
Old Sep 29, 2010 | 07:29 AM
  #61
NmexMAX's Avatar
dot dot dot ...
There is no OD light in A33B's. Only a tranny check light, bottom right of the cluster.
The At has P,R,N,1,2,3,4 I believe n between the Tach and speedo, and light a green light to w/e gear it's in. That would obviously not be there anymore, or wont be lit.
On the right side of the pic.
Old Sep 29, 2010 | 07:49 AM
  #62
just incase you didnt want the auto cluster anymore
B
Old Sep 29, 2010 | 08:50 AM
  #63
Crusher103's Avatar
Dust ur damn steering wheel.
Old Sep 29, 2010 | 09:09 AM
  #64
HotshotVQ35's Avatar
just out of curiosity, how many people have done the 6spd swap successfully? and props to you hustle, i would never keep a car if i had to put more than 1 tranny in it, let alone the 8-10 you did!
Old Sep 29, 2010 | 09:35 AM
  #65
sho off's Avatar
Welp congrats on trying to convert to 6sp. But, I must requote you "reliablility who cares about that,lol). Next autos are not a fail if properly set up. Let me be the example 250k original trans. I have only a mild very mild vb mod from rob at nrh, next I have a cooler in which I told all yall to buy $40 at adavance. Let me point out that Dnene shift kit/vb mod is too harsh for the stock tranny #1 and she had no cooler. I dont know which one you have? Umair the one you raced has a vb w/ no cooler. the fenwicks blow trannys no cooler. but, I have seemed to keep my same auto all this miles.
Old Sep 29, 2010 | 10:02 AM
  #66
NmexMAX's Avatar
dot dot dot ...
I thought it was over 4 cars? Still , that's an average of 2.5 tranny's per car.
Old Sep 29, 2010 | 10:42 AM
  #67
3 cars... my 2K never gave any problems........
Old Sep 29, 2010 | 10:44 AM
  #68
Crusher103's Avatar
MTs are more fun anyway.
Old Sep 29, 2010 | 10:59 AM
  #69
B
Old Sep 29, 2010 | 12:56 PM
  #70
O.k maybe I need to break it down to you... everybody wants a reliable car, the context in which "who cares about reliability" was different... dmv was talking about track times and after a member whooped up on ur times you jumped out sayin I have the most reliable car in the dmv, as if having a reliable car is some kinda major event or copetition, so I then said who gives a ish about reliability, other orger beat ur times.... there is a lot of ppl with a transmission cooler who still kill there transmission you are just the one lucky 1... again maxima auto trans are weak and I never really cared for it, this just gives me all reason to do what I really wanted...............
Old Sep 29, 2010 | 01:04 PM
  #71
+1 drove datdude's 6spd while it ran out of gas and I was more fun than driving all 4 of my maxima's
Old Sep 29, 2010 | 01:12 PM
  #72
t6378tp's Avatar
Turbo 3.5
Don't forget the 6MT ECU.
Question?
why can't he just use a 5gen mt ecu
Old Sep 29, 2010 | 01:19 PM
  #73
NmexMAX's Avatar
dot dot dot ...
Originally Posted by t6378tp
Question?
You mean 5.5 gen MT?
Old Sep 29, 2010 | 01:41 PM
  #74
t6378tp's Avatar
Turbo 3.5
Yes
Old Sep 29, 2010 | 01:56 PM
  #75
NmexMAX's Avatar
dot dot dot ...
Yes
Oh yeah, that's what I suggested. So, to elaborate, I mean for him to get a used one from a JY, and have the dealer reprogram it for his key.
Save some $$.
I'm curious how the CAN/VSS/TPS/APPS etc. will be by-passed if the AT ECU is somehow used.
Old Sep 29, 2010 | 02:03 PM
  #76
MoncefA33's Avatar
Can you confirm that the 5.5 even uses CAN? I thought only the 6th gens had CAN.
Old Sep 29, 2010 | 02:05 PM
  #77
NmexMAX's Avatar
dot dot dot ...
Only the AT's do. I had to deal with that when I severed my ECU wire bundle.
Old Sep 29, 2010 | 02:21 PM
  #78
MoncefA33's Avatar
Well then. Get a 6MT ECU fo cheap.
Old Sep 29, 2010 | 02:22 PM
  #79
NmexMAX's Avatar
dot dot dot ...
It may be possible to by-pass the TCM, but hopefully the AT ECU wont look for signals from the TCM. it be interesting ti know this for sure.
Since if I ever go this route, I wont have to pony up for a TS-F-Spec in 6MT trim. I just have a hard time seeing with all of the APPS/TPS stuff that it would appreciate using an AT ECU while MT.
Old Sep 29, 2010 | 02:34 PM
  #80
I won't be changing the ECU.... I actually want to use my auto ECU, less parts to get ... again I don't care about the CEL.... save on install time... onlything I'm getting new is probebly a clutch, flywheel and starter, shoot ill take used mounts.... moncef can u make me a sticker?... let it have the writing "rust" and a bucket under it.... I understand everybody prefer a 6mt ecu and I would if I even care but I don't, ill be buying another car and this will literally be a beater.... I'm over this car really, I love it darely but not enough to even put one more mod on it.... just sold my LR maf to tookrzy
