Failed Curb Idle
Old Sep 30, 2010 | 09:54 AM
ill87's Avatar
Failed Curb Idle
Passed ASM2525
HC ppm 58/53
CO% 0.32/0.19
NO ppm 435/311
RPM 1442 VALID
Dilution 15.5 VALID
Curb Idle
HC ppm 150/398
CO% 0.70/9.22
RPM 720 VALID
Dilution 18.8 VALID
Any ideas?? 2001 AE A/T 193k. Had codes Pxx071 and Pxx075 which was a bank too lean and a bank too rich.. Flashed and hasnt come back in over 250+km...
Old Sep 30, 2010 | 10:28 AM
J-Rod's Avatar
I assume you mean it failed inspection?
If you did a few things to get checked would be MAF, knock sensor, all O2 sensors, and the run some premium in it. Seems to me (I'm def. not a expert on the numbers) but just some street smarts say you are running rich. CAT might be suspect as well.
Old Sep 30, 2010 | 06:44 PM
ill87's Avatar
I always use Shell 91 0% Ethanol.
Replacing MAF.
I Had Pxx071 and Pxx075 (dont recall exact number) but they are x Bank Too lean, y bank Too Rich... any prognosis on that?
Old Oct 1, 2010 | 01:02 PM
J-Rod's Avatar
How is it running? Have you noticed the funny sound on start-up, like its misfiring? If the codes haven't came back after you cleared them, and now your having trouble it could be intermident. Sometimes failing the inspection, also shows stored codes from past. Well at least here in Texas, they can tell if you reset it prior to coming in for so many drive cycles before every sensor checks in to the ECU. I wish you could provide some more info...
Old Oct 4, 2010 | 08:42 AM
ill87's Avatar
OK After 500~ KM, SES is now back, I need to go scan it.
I'm not exactly sure how a misfire sounds, I've had it choke on very cold starts, (when id give her gas, it would at first feel like i didnt press the pedal down, and then suddenly jolt into gear), but is rare.
I dont believe Ontario tests do any sort of indepth failed code ECU kinda thing.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
