Thumping after suspension change
Old Oct 3, 2010 | 05:44 AM
cjandura's Avatar
I went and replaced all my struts with Blues and tein springs last night.this morning i took it for a test ride and there is a very pronounced thumping comming from the right front ive pulled the wheel and dont see any signs of wear or rubbing.this noise happens at all speeds and when i turn left or right i checked for loose hardware and things i may have forgot to hook up but nothing looks wrong.any suggestions on what it could be?
Old Oct 3, 2010 | 05:47 AM
phatboislim's Avatar
even through search you wont find a definitive answer...most of what people are going to say is that its the strut mount/bearing...do some searching and you will see whats spoken of.
search 'clunking noise'
Old Oct 3, 2010 | 06:46 AM
cjandura's Avatar
everything is new.New mounts,bearing,boots,bump stop
Old Oct 18, 2010 | 07:37 PM
Switch's Avatar
Did you make sure to seat the bump stops in the new dust boots? The bump stop is made to ride inside the raceway at the top of the dust boot. My brother forgot to press his in and had a similar noise to what you are describing. As it turned out he had his bump stops upside down. He took them off and flipped them over and seated them fully. It takes some pressure and a good bit of twisting but they fit. A little dish soap or WD-40 should make it easier. Hope this helps.
JB
Old Nov 11, 2010 | 06:33 AM
ghostrider17's Avatar
Dunno if this is really ADVANCED SUSPENSION....but i'll bite:
Did you make sure the Spring/Strut Hat that says OUT is facing out?!
Very common mistake.
gr
Old Nov 12, 2010 | 04:31 PM
cjandura's Avatar
gr
Yup got that covered.Im going to replace all the bushings and links except for the ball joints with Moog and ES products.I hope it helps
Old Nov 12, 2010 | 04:33 PM
cjandura's Avatar
JB
Took care of that after trimming 1.5 inches off the stops and used armor all to slip them in.
Old Nov 13, 2010 | 12:24 AM
roggeezy's Avatar
When I had a thumping side from the right side, it was a bad motor mount (upper right one).
Old Nov 13, 2010 | 06:34 AM
Replace your Stablizer/Sway Bar END LINKS and Bushings FIRST.
It's easy and relatively cheap, comparatively.
Buy MOOG Links, NOT OEM. The OEM Bushings are Ok, and ES if you want to stiffen-up the Stab/ Bar, handling.
Just did mine -- AGAIN. Got rid of MOST of my clunking.
gr
Old Nov 13, 2010 | 07:09 AM
OnOiShNo0dl3Z's Avatar
Same happened to me when I got new tires. My suspension was shot though so I had it replaced and sound went away. Couple weeks later started hearing it, turned out to be tire pressure. From summer to fall, the pressure dropped and when i pumped it up again, sound went away. Try to check that first? Cheap and easy anyway.
Old Nov 16, 2010 | 03:16 PM
cjandura's Avatar
gr
I got Moog links and ES everything else but the motor mounts going to install this weekend.You ever changed the Motor Subframe Bushings - Front Mount p#7.1116 is this the front to rear subframe that connects to the rad support or is this something else?
Old Nov 16, 2010 | 04:06 PM
sschwarz25's Avatar
I had this problem and I got real crazy with it and found it real quick. The shock strut itself (as in the piston inside the coil) is a simple gasket pressure system and when the inner gasket blows the whole strut is shot. It will start to thump. I took mine into my garage to repair, pulled off the whole strut assembly, compressed the spring (nervously), pulled the strut out and put a new one in. Mine was so weak that I could move it in and out with zero effort, where as the new one was pretty damn hard to move down and stayed pushed out. If you haven't found your answer, roll down to autozone and buy it for $150 and replace that strut; or take it somewhere and pay them about $1K. Either way, I bet that is your problem.
**Addition** The thump comes from the inner piston smacking off the inner walls.
Old Nov 16, 2010 | 04:56 PM
cjandura's Avatar
This was after replacing with HP's and Tein S-tech Springs and all new hardware and mounts
Old Nov 16, 2010 | 05:37 PM
sschwarz25's Avatar
Lol, not sure how I missed that. Well, that was my two cents. Next to that I am not sure where you would get a thumping from. If you replaced yourself then you know that there really isn't much to make any thumping. I am sure you checked, but is your coil sitting on the shelf correctly? That little rubber cover on the bottom wouldn't be a cause for that, but if it is sitting wrong it could be clicking but in a low tone. Not sure.
doctorpullit
Jul 20, 2019 09:31 PM
f.matejaiii
Sep 21, 2015 12:09 PM
RWCreative
Sep 21, 2015 11:01 AM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
