Is there a CAI or WAI that...
Old Oct 20, 2010 | 09:24 PM
trooplewis's Avatar
...does not give up low or midrange power, and that is not noisier than the stock system?
I would just like to clean up all the plastic crap in the engine compartment, not looking for WOT increases or whistling intakes. Right now I am running with the air horn off but the filter box to the TB is still stock.
Old Oct 20, 2010 | 09:28 PM
Mr. Brett's Avatar
Hate to say it, but not really. Putting a heat sheild around the cone filter might reduce some noise.
I've also heard leaving the Helmholtz resonator in place will reduce the noise some, as well as keep a bit more midrange than just a straight up short ram or CAI-style setup. But any cold air-style intake is going to whistle regardless. And lose a little midrange.
I know that putting a velocity stack on my intake reduced the whistling sound a good bit, as well as smoothing out my powerband. But the added growl from the engine is still there with all the plastic pulled out of the engine bay.
Old Oct 20, 2010 | 09:38 PM
trooplewis's Avatar
Thanks SLC, guess I'll just leave it alone then. Sure looks better without all the black plastic. I've always wondered why improved air flow through a WAI caused a loss of midrange. The physics of that do not make sense to me...
Old Oct 20, 2010 | 09:58 PM
Mr. Brett's Avatar
The whole idea is resistance.
Same with the "backpressure" theory.
I'd explain it. But I'm too tired to think straight right now. Maybe someone else who's more awake can explain it. Or I can find the link to the explanation in the AM.
Old Oct 21, 2010 | 06:28 AM
NmexMAX's Avatar
dot dot dot ...
LRMAF(or any other larger than OEM MAF) + SAFCII + stock airbox = exactly what you're looking for. Except don't be an asshat like me, and DO connect your PCV properly.
We all know how intakes wail, so you can't get any closer than this. Under load inside the cabin you can't tell the difference to stock. Sounds more refined.
Old Oct 21, 2010 | 07:30 AM
trooplewis's Avatar
I was just looking to get rid of the stock intake plumbing, it is fugly.
Old Oct 21, 2010 | 07:41 AM
NmexMAX's Avatar
dot dot dot ...
You can remove the scoop, but it will be a bit louder, not by much. It will just be a big black box, and an open hole at the front of the box.
Have you been under there at all and removed anything?
Old Oct 21, 2010 | 08:06 AM
MintVQ35's Avatar
I don't see why you'd even be concerned with how the stock intake looks if you're not interested in increased sound or whistle from an aftermarket air intake, nothing under the hood of a Maxima is exciting or "nice" to look at IMO.
Old Oct 21, 2010 | 09:04 AM
Froggmann's Avatar
If you are looking to get rid of all that stuff then you will need to just deal with the consequences. As for your question the best setup I have experienced is just running with the Helmholtz connected to the MAF connected to a cone filter. This setup for me produces a minor growl that I can just hear inside the cab and nicely cleans up the engine compartment.
The only other thing I can think of that may quiet your intake down a little bit more would be the CAI through the bumper mod. But this being Fall going into Winter I wouldn't recommend it.
Old Oct 21, 2010 | 09:33 AM
Rochester's Avatar
Originally Posted by MintVQ35
...nothing under the hood of a Maxima is exciting or "nice" to look at IMO.
In your opinion. Fair enough.
Old Oct 21, 2010 | 09:39 AM
MintVQ35's Avatar
^^ Clean? Yes definitely and that's impressive that you keep it looking that tidy I just don't find a transverse-mounted V6 to be eye catching.
HOKUSMAX
Nov 13, 2017 04:34 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
