Procedure to replace 2K Max pre-cats.
Old Oct 24, 2010 | 03:52 PM
rbourne's Avatar
Can anyone provide steps and possibly pictures?
Tks,
Bob
Old Oct 24, 2010 | 03:58 PM
datsunzcar84's Avatar
Correct me if I'm wrong but doesn't a 2k max have a cat in the y pipe and not pre- cats as the 5.5 gen on does?
Old Oct 24, 2010 | 04:04 PM
Nelsito65's Avatar
As far as I know, some 2k's, like my California Spec, have 2 pre-cats, just like the 5.5 gens. Federal Specs have only one pre-cat.
To the OP, I'm not sure if there's any How-to for the pre-cats in these forums.
Old Oct 24, 2010 | 04:50 PM
Lol me= fail I didn't even think of the Cali spec..
Old Oct 24, 2010 | 06:32 PM
trooplewis's Avatar
What makes you think the pre-cats need replacing? Throwing a code?
Old Oct 24, 2010 | 07:03 PM
foodmanry's Avatar
Da Roller Coaster!
Not sure, but make sure you are in need of pre-cats before replacing them. They aren't cheap...
You can replace your rear pre-cat with an aftermarket y-pipe which removes the cat in the process. It should not give you an SES code, and you should still pass smog just fine as long as the car is warm prior to smogging.
The front pre-cat is different and will throw a code if you eliminate it, I believe P0420 or P0430 (one of these is front bank and other is rear bank). If you are replacing the rear with a y-pipe the front is easy, just have to remove three bolts and you will have it off.
The y-pipe removal and installation is pretty straight-forward as you remove it from the bolts on the exhaust you see just below the car and then you have three bolts up top which will take a long socket extension to reach. I would suggest using wobble extensions or angle extensions to get to them.
Still...be sure you have to replace them before taking on the task.
Old Nov 13, 2010 | 01:21 PM
daveybert's Avatar
To replace the bank one cat, must you replace the whole y-pipe or can you chop out the bad cat and weld in a new one?
Old Nov 13, 2010 | 02:26 PM
trooplewis's Avatar
Usually when the topic comes up folks are gutting them, not replacing them; I don't think I've seen info on that around any Nissan forums.
Old Nov 13, 2010 | 07:39 PM
foodmanry's Avatar
Da Roller Coaster!
Gutting it is the cheapest way. This pre-cat is not needed by the car, except for warming up. It shouldn't throw a code if you do this.
The alternative is to purchase an aftermarket Y-pipe. You can even get some performance gains out of an aftermarket Y-pipe.
CRizz
41
Jun 7, 2021 05:42 AM
FlaMark
25
Aug 28, 2015 10:15 AM
erictown
Aug 20, 2015 08:01 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
jholley
Aug 11, 2015 09:38 AM
