Anyone use Urethane exhaust hangers
Old Nov 3, 2010 | 11:31 AM
j23a45m9's Avatar
Has anyone used these on their car? I'm looking into them for the fact my stock hangers are worn and need to be replaced, and I would like something that will keep the exhaust system from major movement. Or can someone tell me the sizes of each hanger and I will order them and test them out!
Thank you
Sent from my ADR6300 using Tapatalk
Old Nov 3, 2010 | 11:47 AM
nismopc's Avatar
You could save the money and just zip tie your current ones. Works just as good if not better then the poly ones and will hold well over time. I don't have any pictures, but you zip tie the outer perimeter of the hanger so that it holds it's shape even when weight is applied to it.
Old Nov 3, 2010 | 12:19 PM
trooplewis's Avatar
I've never heard of anyone wearing out their exhaust hangers!
Old Nov 3, 2010 | 12:28 PM
j23a45m9's Avatar
thats odd. so your saying that they never go bad after 8 years of use, weather change, and a new exhaust change? I've seen and heard of plenty hangers getting worn and needing swapping out!
Old Nov 3, 2010 | 12:32 PM
trooplewis's Avatar
In 35 years of driving and owning probably 60 different cars and trucks, I've never messed with exhaust hangers. Do they make a lot of noise or something when they wear out? Maybe it's because I've always lived in So Cal, where we have no winter.
Old Nov 3, 2010 | 12:42 PM
j23a45m9's Avatar
they will sag/stretch out and you might hear your exhaust hit against you heat shield, lower control arm etc
Old Nov 3, 2010 | 03:58 PM
b13ownr2's Avatar
I've replaced them in my b13 with poly ones from kartboy.com Its mostly Subaru ones, but they made a special run for us on the sr20 forums. I'm replacing the exhaust and am going to try it with 3 leftover ones I have laying around. Hopefully, they are the right size. Made a world of difference, exhaust swaying is eliminated, and no banging around when rockin and rollin. Yes, they do wear out in a way. The rubber does stretch over time...... My 2 cents.....
Old Nov 3, 2010 | 04:11 PM
jaxter09's Avatar
I wouldn't say 8 years would do much but I'm sure couple more years would sag them up, I personally just changed my muffler and mines looked just fine for an 02 maxima and I'm pretty sure they were stock...
Old Nov 3, 2010 | 04:33 PM
Mr. Brett's Avatar
Easiest solution, and even better than zipties is wormgear clamps. That's how I cheated on my exhaust. Haven't had any issues since.
Old Nov 3, 2010 | 05:03 PM
MizzMaxine's Avatar
Zip ties suck... Plumbing clamps do the job.
Something like this:
Old Nov 3, 2010 | 05:21 PM
The6spdMax's Avatar
Originally Posted by MizzMaxine
Zip ties suck... Plumbing claps do the job.
I am using it and recommend it as well. Go to homedepot and buy a pack. No more sound from hitting the rear beam.
Old Nov 3, 2010 | 05:23 PM
Mr. Brett's Avatar
^ Like I said. Wormgear clamps.
AKA plumbing clamps.
AKA C clamps.
Any other names I missed?
Old Nov 3, 2010 | 07:54 PM
The6spdMax's Avatar
Hose clamps.
Old Nov 4, 2010 | 10:14 AM
RobertColianni's Avatar
Originally Posted by The6spdMax
Hose clamps.
Old Nov 4, 2010 | 10:32 AM
Rochester's Avatar
Those worm clamps are going to rust and snap before the year is out.
If you're going to settle on clamps, get some t-bolts.
Old Nov 4, 2010 | 10:36 AM
BlackMacks's Avatar
I thought this was a C-clamp?
Old Nov 4, 2010 | 10:44 AM
MizzMaxine's Avatar
Its been 6 years since I've had mine on.
Old Nov 5, 2010 | 10:42 AM
Care to tell me where you found them?
KabirUTA13
19
Oct 17, 2015 02:15 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
