chrome exhuast finisher
Old Aug 30, 2000 | 11:05 AM
F1 Rox's Avatar
For those you who has SE or GLE
I just bought a chrome exhuast finisher for my GXE. When I tried to install it, I noticed that I can only push it half way in. I was wondering if it is normal, or I have to force it all the way in?
Does it suppose to stick out of the bumper? If not how can I get it in, as the stock muffler is spongy due to the rubber mount...
Please help by checking your stock exhaust...
Thanks all!
Old Aug 30, 2000 | 11:21 AM
Dany's Avatar
My tip on my 2000 SE looks like it somewhat hiding past the bumper
if I look straight down on the car I can't see the tip, it is hiding under the bumper slightly.
Old Aug 30, 2000 | 11:58 AM
PIONEER's Avatar
Re: My tip on my 2000 SE looks like it somewhat hiding past the bumper
yes yes the tip is about 3inches behind the bumper edge. is it a factory tip U R trying to install?
Old Aug 30, 2000 | 12:46 PM
F1 Rox's Avatar
Re: Re: My tip on my 2000 SE looks like it somewhat hiding past the bumper
yes yes the tip is about 3inches behind the bumper edge. is it a factory tip U R trying to install? [/I][/QUOTE]
Yes, it is the factory unit which the two pipes are joined together by a thin sheet wrap around it. I can only push it in half way with my own strength. Should I try to hammer it in? The metal is very soft and I don't want to damage it. The unit tapers off and there is no area that I can use the hammer...any thoughts?
The unit came with no screws, so it must be very tight. So I guess the two pipes must be aligned with the slightly larger pipes within the unit?
Also, is there anyway to secure the muffler? When I tried to bang on it, the rubber mount is doing a very good job dispersing the vibration...
Old Aug 31, 2000 | 03:29 AM
mingo's Avatar
bolt
there shulda been a bolt. when i took my tip thingy off for to install the borla tips, i had a hell of a time prying the thing off. i tried putting it back in too and i had to pound at it.. there should be a metal peice welded on in between your two tips (at least there is on my se) where the bolt should go. when u force the chrome thingy in, take a towel, make it nice and thick and wrap it around the outside edges of the tip, take a rubber malet and slowly pound it in.. i am in no way responsible for the dents you might make.. it worked for me, but not sure if it'll work on ur car.. oh for prep, spray the tips with wd-40 and wipe it clean, then spray a lil more on there. that should help
Old Aug 31, 2000 | 06:36 AM
F1 Rox's Avatar
dents...
... i am in no way responsible for the dents you might make.. [/I][/QUOTE]
Heheh, you know about the dents? The parts didn't come with a bolt, but since I had to hammer it in, the possibility of it coming off is slim...
Old Aug 31, 2000 | 06:50 AM
mingo's Avatar
so i see you got it on?
did u dent the tip? or no?
Old Aug 31, 2000 | 09:09 AM
F1 Rox's Avatar
Yeah dents!
did u dent the tip? or no? [/QUOTE]
I never thought it was this soft... At the time of the installation, I couldn't get a hold of a hammer. So I used a CLUB to bang on a u-shaped metal bar press against the inner pipes of the housing. And I dent the two inner corner at the bottom...slightly though! I then found a hammer at a friend's house and hammered it in with 10 folded napkins! Where are the tools when you need them!
Mahmuth
Aug 16, 2024 08:23 PM
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
Redfox
Sep 28, 2015 10:41 AM
