Umnitza Orion v2 Wiring Install Help
Old Nov 14, 2010 | 08:04 PM
Rooney's Avatar
Hello Dearest Friends,
I would first like to say if this has been posted already please forgive me, I did multiple searches with none that had the same wiring that I have. I looked on Shiftice but that kit differs from mine and I can't seem to figure out how to wire this correctly.
I purchased this kit and I have started to put it into my headlights but i can't seem to figure out how to wire the angel eyes. I called Umnitza and never received a call back :-|.
Any help would be greatly appreciated. Thanks a bunch guys!
Old Nov 14, 2010 | 08:25 PM
jowo9's Avatar
The white and yellow wires are "trigger wires". Basically, you only NEED to use one, but they give you the option of 2. You just wire the trigger wire up to a switched 12V power source and when there's 12V running through the trigger wire, it signals the relay (the little black cube) to draw power from the battery. Quite simple. Now you just need to decide how you want to power the trigger wire. It just depends on what method you want to use to determine when the V2s are on. I have my trigger wire extended into the cab and tapped in to my cig lighter power. That way, the V2s are on whenever the ignition is on. I also put a hidden switch in line with that trigger wire so I can turn the V2s off if I want to (never actually do though...)
Hope that helps. If you have any other questions, feel free to ask.
Old Nov 14, 2010 | 08:29 PM
jowo9's Avatar
Oh, and I have no idea what that little white box is. My V2s didn't come with that... I thought that branch was for the driver's side angel eyes and the long branch was for passenger side? I dunno.
Old Nov 14, 2010 | 08:58 PM
Rooney's Avatar
Don't mind that white box, it does connect to the angel eyes I just disconnected them cuz i installed the angel eyes already on the driver side headlights. Thank you very much for that explanation! I will give it a try. I've been dying to see what they look like :P
I am trying to have the angel eyes hooked up with a SPDT switch as per the tutorial on Shiftice.
Old Nov 14, 2010 | 09:35 PM
Rooney's Avatar
Perhaps i'm doing something wrong but I just hooked up everything and i ran the white trigger wire to the parking lights and left the yellow trigger wire disconnected but it didn't work. Any ideas?
Old Nov 15, 2010 | 12:21 PM
jowo9's Avatar
No idea. That's how my V2's were set up. If I were you I'd probably just try different things on the battery (hold different wires to the positive terminal and see which combination works haha). Sorry I couldn't be of more help.
Old Nov 15, 2010 | 09:30 PM
Govols83's Avatar
Well, all that came on my v2 kit was the angel eyes themselves and the little white box that they plug into. I called Umnitza and they said that a wiring harness does not come with the Maxima kit??? I just wired the white and brown wires to my fog lights so that they come on with them. They seem to work fine, so I don't know
Old Nov 15, 2010 | 10:29 PM
Rooney's Avatar
What would be the point of the white box then? Does that Relay help the lights somehow? Please forgive me as I am electrically challenged.
Side note: Can someone please PM me how to remove my passenger side headlight, I believe it has Data Dots security but I am not sure, i pulled very hard without it coming out. Thank you!
Old Nov 16, 2010 | 10:54 AM
Govols83's Avatar
I think the white box is not a relay. It's just a sort of harness that the angel eye wires plug into. The white boxes that came with mine are the same that came with yours, but I have no idea how the rest of that wiring harness works. I don't know why they would send different kits to different people. Umnitza has a good product here, but they need to send everyone the exact same thing and instructions so there is not this kind of confusion
Old Nov 16, 2010 | 01:20 PM
M1RAG3's Avatar
Splice both yellow and white wires to a 12V power source. IMO they are both "spark" wires. The yellow wire is FOR SURE a spark wire for the relay hence the fact that it runs to the relay. If that wasnt connected to a 12V source then that would explain why your lights didnt work.
Old Nov 16, 2010 | 01:54 PM
Rooney's Avatar
I appreciate the help I will try it out tonight and give you some feedback. I didn't think it would be so difficult.
Old Nov 19, 2010 | 08:42 PM
Rooney's Avatar
Where would you suggest I connect both the two trigger wires? I hooked both the trigger wires to the parking lights and it worked like a charm. Thanks for all the help!
Old Dec 15, 2010 | 02:18 PM
marvinzon's Avatar
I have also recently purchased the Orion V2s and have recieved the same kit as the one in the picture. I was wondering if I was just able to hook both trigger wires to the parking lights for the moment (like 'rooney' has done) and then later on when it gets warmer in the Spring or Summer, to hook up one of the trigger wires to a spdt switch? Or is it the case that once I hook both trigger wires to the parking light, I won't be able to hook it up later to a switch?
Old Dec 15, 2010 | 02:20 PM
jowo9's Avatar
^^^ Just hook one up and leave the other one taped somewhere until you decide to use it.
Old Dec 15, 2010 | 02:22 PM
marvinzon's Avatar
But, didn't 'rooney' say just a few posts above that his halos were not lighting up when he didn't connect one of the trigger wires?
Old Dec 15, 2010 | 02:42 PM
marvinzon's Avatar
I also have an additional question concerning hooking up the halos to a switch. Since the halos already have an extra trigger wire, I'm guessing the dde switch 'how-to' from 'housecor' would differ slightly from this 'new Orion V2 kit'.
Correct me if I'm wrong, but my guess is that one of the trigger wires will stay on the parking light, while the other trigger wire goes to the switch. The second wire going to the switch will be one that 'splices' into the green/white wire on the parking light and the third wire would be the one hooked up to a 12V source?
Old Jan 4, 2011 | 11:18 AM
Rooney's Avatar
Marvin i have both my trigger switches hooked up to my parking light for the moment, until winter's over and it's not so cold I will be rewiring it up to a switch. Sorry for the late response!
Old Jan 10, 2011 | 04:09 PM
umnitza's Avatar
Former Sponsor
Sorry, haven't had time to read all the details on this, but wanted to chime in based on the photo.
WHITE = primary trigger, go off either Accessory for DRL option, or parking light to get them on with first click switch.
YELLOW = secondary trigger, go off either interior fade lights, or something that fades on and off with the interior lights, so when you unlock the car, your angel eyes will fade on and off.
Old Jan 10, 2011 | 04:55 PM
marvinzon's Avatar
Would you happen to know the exact wire that is the interior fade light? Or would anybody else know which one it is?
Old Jan 12, 2011 | 11:43 AM
Rooney's Avatar
i'd like to know as well because right now i have it hooked up to my parking lights but i'd like to have it set up like umnizta said.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Jamie Bowen
Sep 6, 2015 09:59 PM
jds22
Sep 4, 2015 01:52 PM
Johnny9595
Sep 3, 2015 05:18 AM
