Squeaking from right strut area?
Old Dec 18, 2001 | 11:20 AM
CIRCO's Avatar
Anyone have this problem before. It sounds like a very squeaky bed!
Old Dec 18, 2001 | 11:24 AM
bcannon's Avatar
do you have a fstb? if so, my ftsb makes squeaky noises when I make really slow, tight turns...
djmaxski's Avatar
Yeah, but it only seems to happen when I pull out of my apartment complex onto the road.
Old Dec 18, 2001 | 11:27 AM
CIRCO's Avatar
I do have a FSTB but the sound seems to happen over bumps not when taking turns.
Old Dec 18, 2001 | 11:28 AM
Sprint's Avatar
what suspension setup are you running.. struts, springs, sway bars, strut bars.. i am not a psychic so i can't assume what the problem is..
Old Dec 18, 2001 | 11:29 AM
bcannon's Avatar
It's the ftsb sliding ever so slighty in it's brackets...no big deal...I get it all the time...
Old Dec 18, 2001 | 11:35 AM
CIRCO's Avatar
Springs, tokikos, and FSTB. Stock SE rims. I wonder if I should take my suspension out and see what if the problem still exists or should I take it to the place that installed my Tokiko's. I know that will be a ***** to redo my suspension.
Old Dec 18, 2001 | 11:55 AM
Sprint's Avatar
does it happend in the cold? or all the time? does it happend when turning? over bumps?
see my suspension squeaks when its cold outside.. or when i go over large bumps...
Old Dec 18, 2001 | 12:05 PM
bcannon's Avatar
no need to tear the car apart...I bet you a thousand $$ if you take off the fstb and go over the same bump or curb or whatever, you won't get the squeak...
Old Dec 18, 2001 | 12:11 PM
xinl2KMaxAutoSE's Avatar
Yeah, it is the FSTB. I had the exact situation.
I just tighten the FSTB a bit, and it is fine now.
Old Dec 18, 2001 | 12:20 PM
CIRCO's Avatar
Thanks guys I'll try tightening the FSTB and see what happens. BTW did any of you ever have you intake come off while driving. It happened to me and the car does not run because of the O2 sensor. I nearly freaked out, but was relieved when I found that it was the intake. Make sure its tight.
Old Dec 18, 2001 | 03:10 PM
max'n out's Avatar
If it's a high pitch sqiky sqik then it may be the strut rod. If it's not mounted properly it can do that.
Old Dec 18, 2001 | 04:28 PM
martinf's Avatar
I have the problem. Esp when I accelerate up a hill.
Old Dec 18, 2001 | 04:49 PM
csyeo's Avatar
so what torque did you guys put to make sure that the fstb does not make the squeaking sound? My fstb is coming
Old Dec 18, 2001 | 04:54 PM
20th maxstyle's Avatar
Check the 2 big bolts holing your assembly together behind the rotor. They have been known to lossen up.
Old Dec 19, 2001 | 12:18 AM
02VQ35's Avatar
I had that problem on an unmoded '96 Grand Am, it was the strut that was bad, had it replaced, no more problem.
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
