Exedy OEM vs Stage 1 (also, flywheel?)
Not trying to beat a dead horse here (I searched!) but it has come time to replace my clutch after 134,000 miles. After extensive searching, Im looking at the Exedy kits. HOWEVER, all that searching confused me more. I dont have any performance mods on the engine. My car is 98% daily driver (highway, traffic, etc) with some spirited driving. I know the stage 1 will handle, but is it necessary? I dont want to spend twice as much for something I dont need. Of course then comes the question of needing the stage 1 vs the OEM Exedy replacement. Ive read some people saying that the OEM is too soft and the stage 1 is too much for daily driving. What is the general rule here - specifically to those with these clutches?
Also, I have known from day 1 that the flywheel weighs too much, but it seems everyone is replacing the clutch and the flywheel at the same time. Why is that? Is it just a matter of doing it while in there anyway? Is it really an investment worth making at this point? (probably going to need to answer that one on my own) Isnt is also true that you need a "medical grade" environment when replacing the flywheel? I thought there was talk a while ago about making sure not to get even a spec of dust on it. - and finally, if I do the full replacement, other than the OEM TO bearing, what else do I need to get from Dave B for the install of the flywheel?
Oh, and the obvious, other than IRP on the clutch kit, is there anybody else worth checking with? Is Brian over at Cattman still around? (for the Fidanza flywheel)
Thanks!
Thanks!
A 350z HR clutch is just as strong as the Exedy stage 1 clutch, and it is cheaper.
Both have very good pedal feel.
You will need to replace the flywheel for any clutch other than an OEM replacement because the stock flywheel for the 6MT is a dual mass type. This means that the flywheel has some "spring" to it. Both the 350z and the Exedy stage 1 clutches have sprung discs, which means that you will have both a sprung flywheel AND a sprung disc, if you use one of those with a stock flywheel. This will cause drivability problems, such as chatter, as the drive-train will be to "springy".
You can get the Exedy OEM replacement clutch for $200. This is equivalent to stock, and it comes with an UNSPRUNG disc, so you can use this clutch with your stock flywheel.
Also, the stock flywheel cannot be resurfaced (no dual mass flywheel should be). Dual mass flywheels are generally considered a mantenence item, as the shock absorbtion material inside of them tends to wear out, but I don't think this is case for the Maxima's. I believe most people just reuse the stock flywheel and scuff it with some sand paper to remove any glazing. I know that's what I'm going to do.
i'm not running exedy i'm running competition clutch stage 1 and their lightweight flywheel...i love teh feel. whenever i've had to replace a clutch in my cars i always did the stage 1, just enough for the power i was planning on producing and grabs like a ****, great for a DD as well
Anybody got any info on how massive an udertaking the replacement of the flywheel is?
exedy stage 1 is MUCH MUCH stiffer than stock. i had it in my sc 4th gen. there is absolutly no reason why you should go for that clutch, not only its an overkill, its a waste of money and you will ruin the car as a nice DD.I highly recommend you stay clear from it, unless you have plans to go turbo or SC within a year or so. if not just get exedy OEM and fidanza flywheel. the flywheel is a must IMO and a lot of people throw it in while they are at it because its a GREAT performance upgrade and you dont have to worry about droppin the tranny in two months to toss the flywheel or resurface it again. I highly recommend the fidanza, the difference is night and day
Soooo, the 350 clutch kit and the Fidanza flywheel is good? Forget the Exedy stage 1 - I was pretty sure it was overkill. No plans to throw on a SC any time soon. Ill sell the car before that happens (upgrade to a 335i - dont hate!). But I will be using this as my DD for the next couple of years while I finish out grad school. Had it since new, and its paid off, so this wont hurt too bad
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
But keep talking, guys.
![Reading](https://maxima.org/forums/images/smilies/read.gif)
OP, your combo of a 350Z clutch and Fidanza flywheel seem right so far. Have you researched that yet? Prices, models, retailers, etc?
If I'm reading this right, it's the OEM 350Z HR clutch, right? http://www.courtesyparts.com/350z-pa...5_778_779.html Which runs $360 because the clutch and cover are sold together. And if I'm reading CourtesyParts correctly, it doesn't matter if it's the HR or not, because the part numbers are the same regardless.
If you can spring for a new flywheel, 350z clutch with Fidanza is the way to go.
If you can't afford a $450 flywheel, reuse the OEM flywheel and get the Exedy OEM replacement clutch.
I believe that this is the general consensus.
So I never got around to replacing my clutch. Instead of posting a new thread, I figured I would just revive this one.
Since I first posted, I have done some repairs and bolt on modifications. Today I replaced the spark plugs and gaskets and installed the NWP spacers (full kit). The clutch needs to be replaced bad. Is the 350Z and Fidanza still the best combo out there?
Honestly man, from reading the thread it sounds like you probly won't need a stage 1, or have the car long enough to justify the extra cost of the fidanza. Have you done mods other than the spacers?
Maybe the OEM spec exedy with your stock flywheel cleaned up would be your best bet.
Thanks for the response. I plan to keep the car for about three years at least. It still runs great and the problems have been sporadic but fairly easy to fix. Can you think of an org friendly site for the exedy?
Thanks!
litch
123
01-04-2024 07:01 PM
knight_yyz
11-01-2015 01:34 PM
atriuum
09-28-2015 01:19 PM
