I'm changing my cat converter, what to get and from where??
Don't know anything about this.
I would like to get a high-flow cat and I would like to know if it will pass emissions...
If I get the shell from custommaxima, will that pass emissions?
They don't stick anything in my tail pipe for the check if that helps at all and where would my O2 sensors go and will I get a CEL???
Some advice would be nice...
There aren't any sensors on the main cat on 5.5 gens. Swapping it out for a test pipe will be just fine, and won't trigger a SES light. Just make sure you find a way to make it look like a converter so you can pass emissions.
If you want a true cat and not a test pipe, you can do OE replacement or get a Fastcat from Cattman. The Fastcat apparently flows better than any other true cat. It's $200+ though...
I would go with Fastcat for the OE replacement is also $200+.While you and I don't have tailpipe testing, some garages may fail you if they don't see a cat so a testpipe. You could go the CustomMaxima cat "shell" route, but then your exhaust will smell bad.
any gains at all from the test pipe?
RWCreative
Sep 21, 2015 11:01 AM
DayHeyZeus
Sep 11, 2015 03:17 PM
carid
Sep 9, 2015 05:06 AM
Justin Kroll
Sep 2, 2015 11:06 AM
